posted 09-03-2009 09:29 PM ET (US)
OK, a 2001 21' Outrage with a (presumably 2001) Mercury OptiMax 200 and a 15-1/2" x 17" MIRAGEplus propeller.The MIRAGEplus is a good all around prop, but it will ventilate (NOT cavitate) on acceleration and turning on some boats where the motor is mounted up a bit, which itself is good for top speed, cruising and fuel economy, but not for turning.
For water sports, a prop with better grip will be more satisfactory.
The obvious best grip choice is the Mercury REVOLUTION4. I would try a 14-5/8" x 15" REVOLUTION4 first. It might be underpropped for cruising but you will have very good acceleration.
There is no 15" x 16" MIRAGEplus, only a 15-3/4" x 15" size, so forget about that; it won't offer any better gip, though the acceleration would be awesome.
Also consider the Mercury Enertia, which in my experience grips extremely well. You may even be able to step up to 18" pitch in this model.
