Topic: How to Collect Misleading Performance Data
posted 09-10-2009 08:22 PM ET (US)
PrefaceI wrote this article as a completely serious article. Apparently several readers thought I was writing this so they could add nonsensical comments or make light of all my points. What I present below is completely serious and I belive important information. Many boats and motors are compared by tests, and the results are often lauded as proof of superiority. However, the performance data collected in many of these tests is not completely unbiased. This article tries to point out ways in which bias and misrepresentation can enter into comparative test data. As for the heckers' comments, I have deleted them all. Having been involved now for several years in the collection of performance data, I have found that obtaining accurate and meaningful data is difficult. It is quite easy to collect misleading and inaccurate data about performance. So many variables affect boat performance that it can be difficult to eliminate the influence of them and isolate the target parameter. Based on my experience, I can easily tell you how to collect misleading data. Weather Perform your testing under different weather conditions. To boost the performance, test on a cold day, in cold water, with low humidity. To decrease performance, test on a hot day, in very warm water, with high humidity. Water Perform your testing in different waters. Use favorable winds and currents to help boost your results if desired. To unfavorably skew results, use adverse current and wind. These influences can be substantial. If not controlled for in the testing, they render the results meaningless. To make things totally meaningless, use saltwater for some tests and freshwater for others. Boat Use different boats. By this I mean use the same model, but just use two different boats. Hull variations will tend to favor one hull over another, so pick the hull according to the outcome you wish to demonstrate. Hulls with more weight, less fairness, lack of stiffness, and irregularities in their surface will kill performance, which you can later attribute to another variable. Don't bother using boats of completely different types or models, as even the most naive boater understands that those comparisons are meaningless. Propellers Use different propellers. To boost performance, carefully select an optimized propeller. To kill performance, use an inappropriate or poorly chosen propeller. Trim Vary the trim on the boat. To boost performance, dial in the engine mounting height and trim. To kill performance, mount the engine too high or too low, and don't trim it for optimum. Speed Measure speed with a garden-variety GPS receiver. GPS receivers do not actually measure speed, but instead deduce speed from consecutive position fixes. Use a GPS with few channels, no precision augmentation, and slow updating. Pick the speed results to favor the desired outcome. Fuel Consumption Don't actually measure fuel consumption at all. Use your seat-of-the-pants estimate to calculate fuel consumption based on about how much fuel you bought during the week. If you do actually measure fuel consumption, use different techniques for each motor, and use different instrumentation. Adjust the numbers as you see fit, as no one can really question how you obtained them. Data Points Choose data points for comparison which emphasize the variations you wish to enhance. Choose optimum data points for a misleading boost of performance, and choose less than optimum data points to convey a notion of less performance. Selectively choosing data can be very effective in modifying the outcome of performance tests.
Buckda
posted 09-11-2009 09:05 AM ET (US)
Jim -The problem, then, becomes: where do you find an indoor, climate-controlled environment large enough to actually measure performance? There are always certain problems or challenges with any scientific study and the data collection methods. The very fact that humans collect the data introduces things like bias, error and other problems. I think that it would be a reasonable comparison to take two stock production motors and stock production boats (of the same model and options), weigh them and/or handicap one or the other to compensate for weight, fuel load, etc. I agree that some calibrated instrument should be used to measure fuel flow data and speed. To eliminate performance bias, have the vessel then set up by motor manufacturer's experts on scene, re-weigh the boats for accuracy and then run them with an unbiased third party expert operator. |
newt
posted 09-11-2009 01:03 PM ET (US)
Can two boats of the same model from the same assembly line differ enough to influence engine testing results? |
posted 09-11-2009 01:23 PM ET (US)
Boston Whaler performance reports generally include a disclaimer that the results apply only to the vessel tested, and not to others. |
posted 09-11-2009 08:38 PM ET (US)
One of the most enlightening articles which appeared in the now defunct BASS & WALLEYE BOAT magazine was a series by John Tiger in which an older bass boat was being rehabilitated. A great deal of time and money was spent on making this boat go faster. The single most influential improvement, that is, the thing that made the boat improve most in speed, was to fair the hull, stiffen the planing surface, and install stiffer motor mounts. The improvement in speed that resulted from these changes was greater than any other change, including changes to propellers--some which cost $1,200--and extensive engine modifications to improve horsepower. You can draw your own conclusions from that data. What I learned is that even very minor variations in hulls affect performance. |
Peter
posted 09-11-2009 09:43 PM ET (US)
What Tiger taught in that article is simply cause a change the variable with the highest impact in Crouch's formula MPH = [ ( HP / LBS )^0.5 ] x C namely, change C. As a matter of simple mathematics, Crouch's formula shows that speed is more sensitive to changes in hull shape than it is to changes in applied HP or weight. A 4 percent change in C, for example, will yield a 4 percent change in speed. A 4 percent change in HP, weight or combination of HP and weight will only yield a 2 percent change in speed.
posted 09-11-2009 10:02 PM ET (US)
Peter--That is a brilliant observation. Yes, the influence of the hull on speed is greater than either the weight or horsepower. It is all there in Crouch's formula. Thank you so much for pointing that out. It is really quite an important point which has gone mostly overlooked. |
R T M
posted 09-11-2009 11:31 PM ET (US)
I remember that article in B&W Mag. The engine mods done to that Evinrude were very minor, Boyson reeds. I don`t remember anything about porting, blueprinting, or exhaust changes. Solid mounts relate to handling, and if it was a poorly designed boat then fairing and stiffening the hull would help. Extensive engine mods would have made a major difference, but reliability would have been way down. I don`t think Tiger was by any means an engine builder.rich/Binkie
roloaddict
posted 09-12-2009 12:43 AM ET (US)
These techniques seem familiar. Are we realy talking about boat/motor combos? Or is it Health Care Reform? Or Climate Change? If it truly is a discussion of boats and motors, I have seen plenty of importance put on the color of the motor, sometimes trumping all data, misleading or not. |
posted 09-12-2009 09:00 PM ET (US)
[Deleted a number of replies which I thought were really an attempt to turn this discussion into a farce. I am quite serious about all of the points I have made regarding misleading performance data.] |
tbyrne
posted 09-14-2009 12:49 PM ET (US)
You forgot to add:Take the nominal propeller pitch as gospel truth. All 15" propellers are identical in pitch and function. Therefore, all calculations taken therefrom are accurate to four decimals. This rule is particularly true in regards to anomalous speed/slip calculations that can be rationalized away by merely asserting that the slip is actually negative in some cases. |
TransAm
posted 09-14-2009 01:59 PM ET (US)
It would seem to me that "fairing" or stiffening a hull, especially when speaking of fiberglass boats, would be far more involved and expensive then modifying a propeller or engine, even at $1,200 a pop. What exactly would need to take place to stiffen the planning surface? With good fiberglass technicians commanding labor rates upwards of $100/hour, that could become quite an expensive exercise. Or perhaps it more simplistic than I think. Although proper fairing the hull may provide the most influence on speed, it certainly seems to be the least practical and perhaps the most expensive undertaking unless it was considered during the original hull assembly. |
newt
posted 09-14-2009 03:10 PM ET (US)
I just find it hard to believe that two identical hulls, layed up in the same mold could possibly differ enough to influence performance data. Sure, the weight may differ some, but how could the surface in contact with the water be so different? |
Buckda
posted 09-14-2009 03:46 PM ET (US)
Newt -I don't believe that it does. The article JimH mentions doesn't run hull X with a Yamaha and find it goes slower than a similar hull with a Suzuki, and then improve performance of the Suzuki powered hull by making those mods. It simply shows what everyone knows - that hull modifications can help or hinder a boat's overall performance. That is why I disagree that pulling IDENTICAL production hulls that are outfitted the same with different motors and conducting a test is not legitimate - or somehow flawed. Of course, testers could eliminate this potential data corruption by then swapping motors and conducting a second head to head test the following day. I think the real place we see bias introduced in these tests is that the trim and outfitting of the boats supplied for testing is often different - even among the same model in many magazine shootouts - i.e. Running my 18' Boston Whaler with twin 90's against another 18' Boston Whaler with twin 90's would be flawed - mine has extensive mods to the deck (teak and rubber inlay), a forward platform built out of teak and I have a radar arch, flags and antenna dragging in the wind. Two stock 18' Outrages with identical build lists, one with a Merc 150 and one with a Yamaha 150 of the same technology would be a more clean comparison.
Jerry Townsend
posted 09-14-2009 04:26 PM ET (US)
There are several items that have my attention in this discussion.Firstly, Newt - there will not be a significant difference in the performance of two boats from the same mold - in the same water, wind, altitude, loading, et al. conditions. Certainly, the surface condition (fouled, painted, waxed/non-waxed) can make a difference in two "identical" hulls. Frankly, I put minimal significance to "user" test data because many are, knowlingly or unknowlingly, biased, one way or the other, and may be done or reported in accordance with one's interpretation, bias or desire. And then some "tests" are conducted with in-accurate instrumentation. Granted, some of my comments stem from my engineering experience regarding testing, instrumentation and accident analyses. Certainly, our instrumentation is not certified or traceable to the National Bureau of Standards - but it should be the most accurate instrumentation obtainable. Crouch's formula is but an empirical relationship and the coefficient "C", for that given test configuration, is calculated - and conveys all other test variables such as boat surface condition, altitude, wind, water conditions, temperature, wind velocity and direction, salt/fresh water, altitude, fuel energy content, et al. Therefore, to discuss a specific percentage change in Ctouch's "C" is meaningless. Having said that - conducting really meaningful tests is difficult - and must be done objectively. Certainly, I, and I suspect the majority of others don't have the elaborate testing faciltiy to conduct a perfect test. As such, I guess that I intreprete CW "test reports" and other "tests" in the boating world as interesting - but don't put much weight on the report. ---- Jerry/Idaho |
posted 09-22-2009 10:15 PM ET (US)
Fiberglass boats laid up in the same molds can still have some variations. There is opportunity for variation in the layup. Hulls could differ by weight. The laminate thickness could vary, which might also cause variations in strength and rigidity.Modern manufacturing processes with tighter controls may reduce variation, but this is not universal. Not every boat builder constructs boats which are identical. Measurement instrumentation does not have to be absolutely accurate for test data to be comparable, as long as the same instrumentation was used for all tests. For example, a scale might be slightly out of calibration, but if all boats are weighed on the same scale, the difference in their weights is probably meaningful and can be used for comparisons. In general the scientific method is to use controls and only have one variable. For performance data to have the most value, the number of uncontrolled variables should be as small as possible. However, even strictly following the scientific method does not guarantee meaningful data. Ask the physicists who said they measured evidence of cold fusion. |
Jerry Townsend
posted 09-24-2009 01:34 AM ET (US)
Jim - agreed - there will, in all probability, be differences in hulls made form the same mold - but those differences will generally be minor. That is, a difference of 10 - 20 pounds - which is a LOT of glass - is insignificant when one is dealing with a 1500 +/- pound hull.And doing a test with only one variable is very preferrable. If more than one variable, the test program and analyses are vastly more complicated. That is one of the "qualms" I have regarding tests by CW members - typically, there are many more than one variable - and only one or two data sets. Using the same instrument for all tests alleviates the accuracy problem. About all one can do is to use the best quality instruments possible and calibrate, as possible. Regarding the cold fusion fiasco. Those university professors or researchers made errors and then simply jumped to conclusions, wanting to be the first to produce cold fusion - an international goal. I obviously don't know, but I would guess that they were not using accepted research techniques/procedures. The first to produce cold fusion will probably be given the Nobel prize - et al. - and prehaps be the richest person in the world. Additional testing would have been a bit prudent! ---- Jerry/Idaho |
