ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Whaler Performance Repowering 1970 Nauset
Author | Topic: Repowering 1970 Nauset |
jlundfe |
posted 11-17-2009 08:53 AM ET (US)
Does anyone have performance specs for putting a 70 hp on a Nauset? Don't want to be lacking power in any areas but don't want to spend the extra for a 90 if I don't have to. |
posted 11-17-2009 09:24 AM ET (US)
See the following article on re-powering of classic Boston Whaler 16 and 17-foot models: http://continuouswave.com/whaler/reference/16-17/repower.html |
jlundfe |
posted 11-17-2009 09:42 AM ET (US)
I saw that. Apparently the Nauset is a couple hundred pounds lighter than the Montauk though. Thanks |
Tohsgib |
posted 11-17-2009 10:51 AM ET (US)
I had a Suzuki 70 4 stroke on my heavier Newport and she did 39+. I think the newer and lighter 60-90hp Suzukis would be great on your rig. Many are very happy with Mercury/Yamaha/Suzuki 60hp on the ole blues as well if $$ is important. 50hp although OK is a tad lacking. I had a 60 2 smoke on my 68 hull and was really impressed. |
Fishmore |
For reference I run a 1993 75hp Mercury engine on a 73 smirkless hull set up Montauk style with no bow rail and achieve 38mph at WOT. Cruise at 28-30mph at 3800-4000 rpm. No problem pulling a tube. No problem getting on plane with me, my wife and 2 kids. Can troll down to 2mph with a 14 x 19 prop. Hope that helps. |
jlundfe |
posted 11-17-2009 12:31 PM ET (US)
Sounds like a 60 hp minimum so far. |
annapoliswhaler |
posted 11-18-2009 01:02 PM ET (US)
I have had one season with my '68 and a 60HP Yamaha 4 Stroke. I am very happy with the performance I have gotten from the Yamaha. If you typically carry four or more on your boat, I would go with more HP. I generally have 1 - 3 people on mine, and I am satisfied with the pick-up and cruising performance. With a larger load, the pick-up is slow, and it takes longer to get to plane. I use very little gas with the 4 Stroke, an added benefit! |
posted 11-18-2009 09:54 PM ET (US)
Don't discard the performance information I pointed to quite so fast. A difference in weight of 200-lbs is easily within the variance of weight to be anticipated from differences in fuel being carried, passengers being carried, gear being carried, or individual hull weights. |
jlundfe |
posted 11-30-2009 08:04 AM ET (US)
Hey Annapolis, can you pull Skiers with the 60 hp? (BTW - I'm in Severna Park) |
annapoliswhaler |
posted 11-30-2009 01:26 PM ET (US)
I have not tried to pull anyone skiing or on rafts. I never did any water skiing as a kid, and use mine for fishing and crabbing. If I tried to ski it would look something like trolling for alligators! I have no problem with two or three in the boat. During the summer I had five onboard once, and it was slower than usual getting up on plane. I suppose it has enough muscle to pull someone skiing... for what it is used for, I have been EXTREMELY satisfied with the 60. |
contender |
posted 11-30-2009 09:37 PM ET (US)
The worse thing you can do to a boat is under power a boat period. Really sit down and think about what you are going to do with the boat. How much gear and people are you going to carry? What do you want to do with the boat? Small motors are nice until you put some weight in the boat then they do not move. If you have a larger engine you can ALWAYS thottle back, But you CAN NOT get more power/speed out of a smaller engine. The amount of gas difference between the 70 to a 90 is so small its not worth talking about....To each his own... |
Tohsgib |
posted 12-01-2009 12:05 PM ET (US)
True but also consider how much stress/weight you want to put on a 40 year old transom. That boat was designed for 100hp in 1961, I bet a modern 70 would outrun one. |
macfam |
posted 12-01-2009 03:24 PM ET (US)
I had a 1964 Nauset. The last re-power was a 3-cyl Merc 70hp. Just great in my opinion. Fast enough, and pulled tubes and skiers with no problem Will send pics if you like. |
contender |
posted 12-01-2009 04:43 PM ET (US)
Looking at Jim's print out of the engines page I would go for the 90 Yamaha 2 stroke, more power to weight, and light on fuel, and will not hurt your transom...
