posted 05-13-2010 03:51 PM ET (US)
The point I was trying to make is that there is far more to propeller selection than the number of blades and pitch.Propellers are not generic pieces of hardware; each model of propeller has unique design characteristics that affect how it performs and makes it suitable for some applications and not others.
There are no rules of thumb about four blade propellers vs. three blade propellers except that four blade props will have more stainless steel in them and therefor will cost more and weigh more.
When they need repair they will cost more because there are four blades to check instead of three.
It is not true that any four blade prop will have better "grip" than any three blade prop. It depends.
To me "grip" means the ability of a propeller to resist ventilation during:
- Acceleration to plane.
- Extreme trim.
- During sharp turns.
You have an aluminum prop of unknown brand and model, but I can assure you that any stainless steel propeller you buy that is sized appropriately will offer far better "grip" than what you have now.
Your combination of boat and motor also means there are not a lot of propeller choices so the decision is somewhat easier. A 1973 Outrage 19 is easily driven and accelerates with little bow rise. You do not need a stern lifting prop on a boat like this.
The Johnson 115 four-cycle is a Suzuki DF115 and uses an intermediate gearcase prop. It also has a relatively low gear ratio that will do better turning a slightly larger diameter prop.
My first recommendation would be a 14" x 18" Stiletto Advantage or 14" x 18" Suzuki stainless steel three blade (they are the same prop).
I cannot think of a four blade model that would necessarily be a better fit on this boat/motor combination, but I have no personal experience with Solas or Vortek four blade props in this class of motor. I have never heard of the latter brand.
Mercury four blade props are by far the most common, but in the intermediate size, the only four blade stainless steel model they make is the Trophy Plus and I do not believe it would not be a good fit for this boat/motor.
I would also recommend the motor be set rather high on the transom to make good use of the recommended propellers.
