ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Whaler Performance Outrage 18, 150-HP, REVOLUTION4
Author | Topic: Outrage 18, 150-HP, REVOLUTION4 |
face |
posted 08-19-2010 11:22 AM ET (US)
On an OUTRAGE 18 with a single 150-HP engine, has anyone tried a Mercury REVOLUTION4 propeller? I know most will say it's too much propeller, not needed, wrong application, but I am wondering if anyone has actually tried it. If so, did this propeller perform better in choppy seas than three-blade props you've tried? I'm going to try a 17-pitch REVOLUTION4.-Joe |
18 Ventura |
posted 08-19-2010 03:51 PM ET (US)
Not a direct comparison for sure, but I switched to a 15P Revolution4 on my Ventura 18 with 135 OptiMax. On my boat, yes, the Revolution4 holds much better in choppy seas. Quite a noticeable difference, actually. I’m quite pleased with the results. |
face |
posted 08-19-2010 05:54 PM ET (US)
18 Ventura, not apples to apples but are you propped correctly for WOT with the 15-pitch? I'm thinking the 17 will be a good place for me to start. I'm spinning a 19-pitch 3-blade right now. -Joe |
Peter |
posted 08-19-2010 07:02 PM ET (US)
I have a 17-pitch Revolution4 (used on my Whaler 27 WD), and a Johnson 150 on an Outrage 18 and have never seriously considered trying that combination out. The 19-pitch SST propeller performs very well in a chop such that I don't think there is any need for the additional traction that the Revolution4 might provide. Prior to the SST I was using a 17-pitch Mercury MIRAGEplus. I switched to the SST because the MIRAGEplus produced a lousy ride in a chop. It would lose its grip and then have a terrible time getting it back. I don't get any of that with the SST. What 19-pitch propeller are you currently using? |
face |
posted 08-19-2010 07:33 PM ET (US)
Peter, I was hoping you might chime in. I've read and searched this forum so much in the last few weeks. You helped my dad and I decide on the Rev4 for his 27WD. I have yet to test the boat and props, but dad is loving them and reporting greater fuel economy, holeshot, top speed, and even sound. (Numbers will be posted to the appropriate thread when dad sends them to me.) After searching this site thoroughly I couldn't find any results for the Outrage 18/Revolution4 combo. I recently acquired an almost virgin Outrage 18, no bottom paint, 1989 Johnson 150 VRO with very low hours for next to nothing. I've spent almost no money on the boat so I want to experiment a little with this prop. After reading as much as I can find about the Rev4 it doesn't seem to lose top end like the general rule that a 4 blade will lose top end over a 3 blade. My current prop...embarrassingly, I don't have the specifics here with me. I hate to come to the discussion with no data. It's a black painted aluminum prop with some dings in the leading edge. The motor is currently set at one hole up. I'll test there and then go up one more hole to test again. Results to be posted when the prop arrives. |
face |
posted 08-19-2010 07:43 PM ET (US)
About the Mirage Plus, I must have read that it lost grip or ventilated during the transition on to plane dozens of times here at Continuous Wave. I suppose it has a relevant application somewhere but I'm not eager to try it. |
Ric232 |
posted 08-19-2010 07:54 PM ET (US)
The Mirage Plus is most at home in an application with a big-block, Bravo I stern drive capable of 60+ mph. This is where it really shines. I know this from lots of personal experience. |
Tohsgib |
posted 08-20-2010 10:42 AM ET (US)
Face...just try one of your Dad's props and see. |
face |
posted 08-20-2010 02:13 PM ET (US)
Unfortunately his props/boat are in the Keys for a while. It won't be back in Maryland for a while so I won't be able to try his. It's okay though I have a friend in the industry that will help me with props. I won't have test results for another week or so but will post for this boat as well as dad's 27 (in that thread)when I have results. |
L H G |
posted 08-23-2010 12:09 AM ET (US)
In my opinion a Rev 4 is *WAY* too much prop for an 18 Outrage with a Johnson 150. For a starter, the engine gearcase won't handle it and you will get prop rattle and shift "clunk" you won't believe, since it's one of the heaviest props made. Secondly, the prop has too much stern and overall hull lift and could very well make the boat unstable at higher speeds. I suggest you go to Mercury's prop website and read the application descriptions of the various offerings. I would say you want a Laser II, Enertia or Vensura, in that order, and based upon what your performance objectives are. |
posted 08-23-2010 08:31 AM ET (US)
ASIDE re MIRAGEplus--The last two trips in my REVENGE 22 W-T WD we have been turning a MIRAGEplus. In earlier testing of that propeller (on a different motor) I also found it was finicky about holding its grip in rough seas, however on these recent outings--week-long trips--we have seen none of the earlier problem with the MIRAGEplus blowing out. And we have been in some of the worse seas that you'd want to try running in. Curiously the engine mounting height is now higher than before--one hole up from lowest--and the MIRAGEplus seems to stay locked-on, no blowout. Perhaps the engine gear case design plays a roll in this process. |
Peter |
posted 08-23-2010 09:05 AM ET (US)
I've run the Mirage Plus propeller on the Magnum gearcase (both my Evinrude 225s and my Johnson 150 are fit with the Magnum gearcase) and in both cases the Mirage Plus had the same lousy performance. It could very well be that the Magnum gearcase and the Mirage Plus propeller are not a good match. However, in the case of your (JimH's) prior experience, the Mirage Plus was not run on a Magnum gearcase. Motor height will have an impact on propeller performance in a chop. Years ago when I had my first Outrage 18, the Johnson 150 on the transom of that boat was originally mounted two holes up and was turning an OMC Raker (a bass boat propeller). The Raker is a propeller with significant rake and its blade shape is sort of a cross between the SST and the Mirage Plus. It had somewhat difficult time recovering grip in a chop to point where I lowered the motor to one hole up. The ride in a chop was improved by doing that but with a loss of top speed. In the case of my 2nd and current Outrage 18, the motor is mounted two holes up. In the case of my Whaler 27 WD, the motors are mounted one hole up but its difficult to determine what that means relative to a boat without a Whaler Drive given that there is a step in the hull form about three feet in front of the motors. The Mirage Plus I have yields a lousy ride in a chop on both boats. This is a result of its abrupt (like dropping a clutch) on-plane transition characteristics. I also observe in the case of your Revenge 22 WD that you've added about 80 lbs to the stern with the repower. That is likely to make the transom sit lower in the water and provide better grip. My belief, based on observing the static trim of the Revenge 22 WD with a single 450 lb outboard is that Whaler expected that boat to have the weight of twin 115 to 150 HP outboards (about 700 to 800 lbs) on the transom. I agree with Larry. The Rev 4 propeller is too much propeller for the Outrage 18. I also disagree with Larry, the OMC gearcase can handle the propeller no problem. From the propeller testing I've done on the Outrage 18 plus Johnson 150, I've found that good overall performance (a blend of speed, comfort, efficiency, shifting quietness and durability) can be had from the 14 1/2 x 19 OMC SST II. These can be found in good condition on eBay for under $200. |
18 Ventura |
posted 08-23-2010 11:19 AM ET (US)
face asked: "...Are you propped correctly for WOT with the 15-pitch?" Yes - I'm just about at 5500 RPM at WOT. |
L H G |
posted 08-23-2010 06:31 PM ET (US)
Peter - You should ask Jim how his old 225 Evinrude 3.0 liter carburetor engine handled a Mercury Revolution-4 propeller. I assumed a 150 would not do any better. Here's a 19" Mercury Laser II running on my 1975 Outrage 19. http://smg.photobucket.com/albums/v429/lgoltz/Outrage%2019/?action=view& current=Merc150.mp4 The engine is up about 1-3/4" and I get no ventilation at all, under any conditions. |
posted 08-23-2010 08:06 PM ET (US)
A REVOLUTION4 on my V6 OMC made such a KLUNK I thought the gear case was broken. You see, normally an OMC gear case on a OMC V6 shifts beautifully, particularly with an OMC rubber-hub propeller--there is no clunk at all. When you put 17-lbs of REVOLUTION4 propeller on, with a lousy FLO-TORQ II plastic hub, you go from no clunk at all to about as much KLUNK as a Mercury gear case makes normally. I think the reason the REVOLUTION4 isn't such a problem for Mercury motors is the gear case shift KLUNK is already so loud you don't notice much of a change when you have a REVOLUTION4. Also, the 17-pitch was too much for my motor. Mercury discovered it was too much for the L6 VERADO motors, too, so they whipped up a 15-pitch REVOLUTION4 propeller so that the single-engine VERADO powered 22 to 24-foot boats could use one. I would not mind trying a REVOLUTION4 on my E-TEC 225-HP if I could get a hub adaptor with some torsion bars to take the KLUNK out. Apparently the KLUNK was too much for Mercury, too, so they whipped up all these fancier FLO-TORQ hubs with titanium torsion rods to try to fix their problem. An extra $100 for the better FLO-TORQ hub kit is worth the money to get rid of that clunk. |
L H G |
posted 08-25-2010 06:26 PM ET (US)
Jim - I think a 15" Rev-4 or a 17" Enertia would be the prop of choice for your setup, and better than a Mirage Plus. If Peter is correct, your new engine's new design gearcase should handle the Rev-4. Mercury only makes the Flo-Torq-4 hub for L4 Merc Verado's and 2.5 liter 2-strokes. (but will fit a Yamaha also). The large Opti's and Verados do not need it and the regular Rev-4 hub (with rear support bushing) works well. So it should work for you, too. |
Peter |
posted 08-25-2010 08:18 PM ET (US)
The old OMC V6 gearcase can handle the Rev 4 propeller, its just that Jim's hearing could not because he was used to the super quiet shifting action of the OMC gearcase with a rubber hubbed propeller. The Rev 4 CLUNKS on the otherwise very quiet Magnum gearcase as well, so Jim make sure you have your hearing protection ear plugs in when shifting. If one taps the Rev 4 propeller with a hard object like the shaft of a pen or pencil, the Rev 4 propeller ring like a bell. That bell like resonance probably amplifies the clunkiness of the Rev 4 / Flo-Torque 2 hub combination. |
Tom W Clark |
posted 08-25-2010 09:50 PM ET (US)
Well face, have you tried the REV 4 yet? I agree it is not the right prop for an Outrage 18 and a 150. I do not agree that it "is *WAY* too much prop", merely not optimal. The Revolution 4 in a 17" pitch weighs 17 pounds with its hub kit. I don't care what outboard you put it on, it will "clunk" when you shift into gear with a standard Flo-Torq II hub kit. There is nothing about an OMC or BRP V-6 gearcase that prevents it from handling a Rev 4 propeller. I have tried a couple of different set if Rev 4s on my own Mercury 150 HP outboards and they clunk when shifted. No surprise there. For an Outrage 18, I recommend the aforementioned Laser II, Stiletto Advantage or Turbo 1, all very similar propeller designs. The MIRAGEplus is a great propeller, made for many, many years is an incredibly broad range of pitches which is a testament to its versatility and popularity, but I agree, it is not the best prop for an Outrage 18. |
L H G |
posted 08-25-2010 10:31 PM ET (US)
Tom - My experience with the Rev-4's on any of the older gearcases is not so much the shift clunk, but prop rattle at low RPM in gear. It can be such an annoyance and heavy vibration that nobody would want to use one. That was what I remember when JimH tried one out. On mine, I solved it by switching to the Flo Torq IV hub which calms it down. This guy seems to have really good prices, and cheap shipping, on Mercury Quicksilver branded props such as the Lightspeed. From what I can tell, the Lightspeed's are the same as the newer Laser II's, except they are made from the previous casting which has the older style square venting, instead of the newer PVS system of variable venting inserts. http://www.dansdiscountprops.com/BuyNow/QuicksilverSS.cfm#QuicksilverSS |
face |
posted 08-26-2010 12:57 PM ET (US)
Hey guys, I haven't tried the Rev4 yet. My prop came in but was the wrong rotation...I'm also on vacation in the OBX for the week. I will be sure to post results but I think it will be another week on a Tuesday or Wednesday. I also have "rough" results from my dad with his Rev4's on the 27wd but I won't post until he is more thorough.
Even if I lost 2knts top speed, which doesn't seem to be the case from other's results, the boat will still be scary fast. I'm not too worried about the shift clunk, a little more concerned about prop rattle at idle (trolling). I also see no problem with the hull lift/stern lift. It seems to me it would ride better above the chop and also allow me to keep the bow down and into the waves if desired. Again, I was hoping someone had tried it. Rest assured, I will and will post results. |
face |
posted 09-10-2010 03:51 PM ET (US)
Kind of lame, but I think for now I will return the counter rotating (mistake) prop and just hold off. I need to finish my Bertram 28 restoration so this expensive experiment will have to wait. I would still love to hear results from someone that can try it (Peter?). When my dad brings his 27 back north I will try one of his on my 18. Not sure when that will be. -Joe |
crbenny |
posted 09-11-2010 12:28 PM ET (US)
This is what I learned when I put the old Laser II up against the Enertia. I run the Laser II for the 18' Outrage and I don't believe you can do better.. http://continuouswave.com/ubb/Forum4/HTML/007207.html Chris |
