ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Whaler Performance Effect of South Florida on Boat Performance
Author | Topic: Effect of South Florida on Boat Performance |
vin1722or |
posted 01-17-2011 05:04 PM ET (US)
I have a [1994 Boston Whaler OUTRAGE 17] with a [1994 Yamaha 115-HP two-cycle outboard motor]. I have the boat in [New Jersey] most of the year and in the [Florida Keys] in [December]. The boat ran at 43 to 44-MPH in [New Jersey] and only 39-MPH in the [Keys]. I checked everything, and all checked out.[The engine speeds] were at 5,400-RPM at [maximum throttle], like in [Jersey]. I spoke with a mechanic in [Florida], and he said, "not to worrythe water here is saltier than up north and most boats run slower down here.". I have heard that in the past and always blew it off. Has anyone ever had or heard of this? I am going to splash the boat here in [Jersey] as soon as the weather gets better to see if she runs at 43 to 44 again. |
contender |
posted 01-17-2011 05:34 PM ET (US)
I thought the more salt in the water the boat would float more, less drag. I have never heard of a boat being faster up north than down here because of the water, maybe because of the air temp and humidity down here. |
posted 01-17-2011 05:35 PM ET (US)
Your mechanic has his Physics confused. It is not the salinity but the temperature of the water which affects performance. |
Tom W Clark |
posted 01-17-2011 06:29 PM ET (US)
It is not the temperature of the water but the temperature of the air. The warmer the air, the less dense it is and the less power a given motor will generate. Saltwater is denser than freshwater. The greater the salinity, the denser it is and higher the boat floats and the faster it will go. |
L H G |
posted 01-17-2011 06:35 PM ET (US)
My experience is that boats run faster in salt water, *PROVIDED* the air is cool and dry, not sultry tropical. Florida's typical weather in Dec, Jan and Feb should produce faster speeds than fresh water. If it is hot and humid, in FL or anywhere, any internal combustion engine can lose up to 15% of its horsepower and top end speed. So much so, that you might even need the next lower pitch prop. So if it was warm, or the humidity was higher, what happened to you in FL could have been normal. Cool, dense, dry air is what makes an outboard run well. |
posted 01-17-2011 08:46 PM ET (US)
The density of ocean water varies with temperature and perhaps with salinity, however between the ocean water of New Jersey and the ocean water of the Florida Keys, I doubt that there is much difference in salinity. I suspect that there is a greater difference in temperature. Therefore, I stand by my original statement: the Mechanic had his Physics wrong. Colder saltwater in New Jersey affected the performance of the boat to a greater degree than any change in salinity of the water. The air temperature also affects the performance, any everyone knows that cold, dense air improves an engine's performance, probably even that mechanic in Florida. He just failed to articulate it. |
posted 01-17-2011 08:52 PM ET (US)
Also, boat performance declines in South Florida because of relativity. There are so many much faster, much nicer, and much more expensive boats in South Florida that the performance of any boat towed down--especially one towed down from New Jersey--will suffer in relation to the South Florida boats. When I towed by own boat down to Orange Beach, Alabama, it suddenly seemed much slower, smaller, and less luxurious compared to the 65- to 75-foot custom sport fishing yachts tied up to the same pier. |
posted 01-17-2011 08:55 PM ET (US)
Further, in the initial posting the author says the engine operated at the same engine speed, 5,400-RPM, in both locations. This means that the propeller turned at the same speed in both locations. Any influence on boat speed must be related to the water density, not to air density. I think my initial observations were precisely on target. I will stand by for rebuttal comments from those who would make an alternate argument. |
posted 01-18-2011 12:07 AM ET (US)
Here is an interesting calculator that computes water density as a function of salinity and temperature: http://www.csgnetwork.com/h2odenscalc.html We know that there can be significant different in water temperature between the Florida Keys and New Jersey, but I have not seen any good data about salinity differences. One source says salinity in the Atlantic varies from 33 to 37 parts per thousand, or a variation of about 4 parts per thousand or 0.4 percent. When I enter a variation in salinity in the calculator above, say from the default value of 39000 PPM to a value of 39156 PPM, I see only a slight change in density, from 1027.014 kg/ml^3 to 1027.133. On the other hand, if I enter a change in temperature from 50-degrees to 80-degrees, I see a change in density from 1030.106 to 1025.871. Comparing the change due to salinity (0.119) with the change due to temperature (4.235), we see a much greater change due to temperature. The change in density due to temperature is 35-times greater than the change due to salinity. We have yet to establish in any meaningful data that the water in the Keys has greater salinity than in New Jersey, but, even allowing for the maximum variation in salinity cited above, we see that salinity is only a minor influence on water density compared to water temperature influence on water density. Again, I think my comment is correct: the mechanic had his Physics wrong. It was not the water salinity that affected the boat speed, but the water temperature. |
RobP |
posted 01-18-2011 07:23 AM ET (US)
You [are] talking about 4 to 5-MPH difference. Other environmental factors might come into play such as wind or tides. Also how much gear, fuel and passengers were on board might come into play. |
seahorse |
posted 01-18-2011 09:11 AM ET (US)
Hee is a chart of worldwide ocean salinity if anyone is interested. |
adlert |
posted 01-18-2011 09:41 AM ET (US)
Thanks RobP! There are too many other undescribed variables potentially at play here. Also, just how precise were those rpm observations... Jim, you propose that a temperature-induced water density change of about 0.5% can significantly account for an ~ 10% speed change? |
L H G |
posted 01-18-2011 06:08 PM ET (US)
Very interesting chart, Seahorse. From my boating experiences I have always thought SE FL was "saltier" than either the Northeast or Pacific Northwest, and this chart shows that to be true. I have also noticed that the Bahamas are even worse, because of increased evaporation over the extensive flats. It's also why the most weather beaten boats in the country are located in FLorida! That climate and year 'round exposure to saltier water really is hard on boats and aluminum outboards. |
adlert |
posted 01-18-2011 08:53 PM ET (US)
I think "weather beaten" likely has more to do with UV light exposure and enjoyment than salt exposure. 1-2 parts/thousand up or down of salt concentration is not a huge difference (0.1 - 0.2 %). Most significantly in my opinion is that Florida boaters are blessed with so much wonderful weather. They have the option to use their boats so much more than many and they tend to do so. Their boats therefore tend to age more quickly in general due to run time, exposure to salt, and exposure to the wonderful, and intense sunshine. |
Tohsgib |
posted 01-19-2011 12:16 PM ET (US)
I always thought the water in Nj was worse than here. When you came out of the water up there it left salt residue on your skin, not here. Maybe it just evaporates faster but as we all know, salt does not evaporate. |
vin1722or |
posted 01-19-2011 02:18 PM ET (US)
Thanks for all the reply's.I took the prop to my prop reconditioning guy to have it checked even thought it is new to see if a blade bent somehow.He called me this morning and the prop is 100%.So there may be something to the water density suggestion.I just think 3-4 mph is alot to loose to water density.I have been going there with a 14 McKee Craft skiff for 9 years and honestly never noticed and performance difference prior to this season with the 17'Outrage.I do know that i never really looked at performance with the 14'.The whaler i bought in the spring and was running at only 39mph with a 17" s/s yamaha prop and was mounted all the way down to the transom,i raised it 1 hole up and installed a 19" s/s prop.My performance went from 39 mph at 5700rpm to 43mph at 5,400 rpm.This is why i had a hard time seeing my performance change.More to come.Thanks for the reply's. Vinny |
vin1722or |
posted 01-19-2011 02:24 PM ET (US)
Reading Jim H's remarks about water temp and I just thought of something that changed from the last few seasons in the Keys.The water temp is always 68-75 degrees.But this year when we arrived it had dropped to 57 degrees because it was the coldest december down there since they have been keeping records(1875).This is the only thing that may make sense.Just a thought. |
posted 01-19-2011 05:28 PM ET (US)
Vinny--you appear to have completely misunderstood my remarks regarding the influence of water density as a function of water temperature on boat performance. |
Wiscbw |
posted 01-19-2011 09:14 PM ET (US)
I thought some of the difference in air density between Florida and New Jersey was due to the geostrophic wind since the Coriolis forces are less in Florida. Depending on time of year this might also be impacted by a lunar perigee. |
Russ 13 |
posted 01-20-2011 01:22 AM ET (US)
The real density problem in Florida is the extensive Southern migration of Northern folks. With so many additional out of town boaters, the ability to run fast is severly reduced. Thus the above speed reduction. |
adlert |
posted 01-20-2011 08:47 AM ET (US)
I think that if all other variables are identical (motor trim, boat loading weight, fore to aft and port to starboard weight distribution, winds, chop, tides, currents, speed measurement inaccuracies, differences in wind drag to passenger positioning or bimini use/non-use, fuel ethanol content, fuel octane, etc...), then the most dominant factors affecting your relative boat speeds will be the air temperature and humidity differences as already suggested by Tom. Changes in air density have large effects on all normally aspirated internal combustion engines' maximum outputs. I presume that the ~0.5% differences in water density will contribute very little to the ~10% difference in top speed you are apparently experiencing. I have not chased down the math to support this notion. Maybe JimH will do that for us :). Is is clear however that, in addition to variables such as those listed above, air density and humidity differences can easily produce the sort of results you are seeing. |
adlert |
posted 01-20-2011 08:58 AM ET (US)
To be fair, I don't think we know for sure yet whether or not Vinny is boating in fresh or salt water in New Jersey. |
posted 01-20-2011 09:39 AM ET (US)
The initial question is to the truth of the observation that the cause of a change in performance was from a change in salinity of the sea water. Suggestions that the motor needs repair are speculative, particularly so because the account given has the motor turning the same speed in both New Jersey and South Florida. Suggestions that the warmer (and less dense) air affected performance are contradicted by the engine turning the same speed. Also, less dense air should reduce air resistance, which should have a (very small) positive effect of boat speed. Water which is colder is more dense. If the propeller turns at the same speed in both locations, then the weight of water being thrown from the propeller will be greater in the colder water. A greater weight of water being thrown will produce more thrust. More thrust should make the boat go faster. The general theory that water temperature, and thus water density, would influence boat speed, however, is shattered by the later report that the water temperature in South Florida was very cold and about the same as in New Jersey water. There is agreement that the salinity of the water in South Florida is likely higher than in New Jersey. This should also produce greater density, although the change in density from salinity seems very small. At first glance it looks like change in density from salinity is not as great as change in density from temperature. However, we are now given a report that the water temperature was almost the same in both locations. This leaves salinity as about the only influence. Unfortunately the influence is in a direction opposite to the observed behavior. If the engine turns at the same speed in both locations, the boat should be faster in the water with higher salinity (Florida); in this case it was slower. |
posted 01-20-2011 09:44 AM ET (US)
Higher water density also helps improve performance because the hull will have less draft in denser water. This will reduce wetted surface, reducing friction, and improving speed. |
weekendwarrior |
posted 01-20-2011 10:00 AM ET (US)
Denserwater is harded for the lower unit to push through, creating more drag. Think about air vs water. Air is less dense, much less drag. The same applies to more and less dense water, obviously on a different scale. Hot air and dense water equate to less horsepower and more lower unit drag. |
Tohsgib |
posted 01-20-2011 10:58 AM ET (US)
Not with boats...the dender the faster due to displacement. I guarantee a boat is faster on the Dead Sea than on Lake Ontario. |
posted 01-20-2011 11:47 AM ET (US)
I will be very pleased to make a comparison between the effect of water density and air density on the performance of propeller drive craft, as has been suggested by weekendwarrior. I find that the comparison is completely analogous to my initial representation. As air density decreases, performance of aircraft propellers decreases. In fact, we see that aircraft driven by propellers all tend to have a maximum altitude or service ceiling, above which they cannot operate, because the density of the air is too low to permit flight. This analogy is very good to boats operating on hydroplane. Denser water produces more thrust from the propeller, and denser water provides more lift for the hull. I believe when weekendwarrior suggested this comparison he was expecting the conclusion to be drawn was completely opposite. |
Tom W Clark |
posted 01-20-2011 12:10 PM ET (US)
Air temperature will have a much greater influence on a boat's performance than water temperature. Less dense air should offer less resistance and allow greater boat speed? Common, surely you jest. We all know that as air density declines, so does the power output of an internal combustion engine. Warmer air is less dense. Gearcase drag in denser water might increase but insignificantly so. Denser water makes a boat float higher and thus there is less drag from the hull's surface area in contact with the water and greater boat speed. Furthermore, I suppose a propeller will have greater grip in denser water and offer a greater apparent pitch, but again I am sure it is also completely insignificant in the context if this discussion. We don't need to argue theories about why a boat might be slower or faster in fresh vs. saltwater, the difference is demonstrable. My boat is 1-2 MPH faster in saltwater than in freshwater. Seattle is bordered on the West by the saltwater estuarial waters of Puget Sound and on the East by freshwater Lake Washington. Most boaters here understand boats are faster in saltwater. There is a very significant difference in water density between saltwater and freshwater elsewhere too and it is equally demonstrable. Last month I was on the West coast of Mexico. In the ocean I could just float on my back without swimming, but hiking upriver to swim in the river pool at the base of a local waterfall in freshwater, I could not float at all; I sink like a rock (I have very low body fat). However, we are talking here, not about fresh vs. saltwater but the saltwater of New jersey vs. the saltwater of Florida. The difference in salinity is very small but it is Florida that has the saltier water yet it is Florida where the boat apparently is slower which is the opposite result of what we would expect so I reject the notion that it is the salinity of Florida's water that is slowing the boat. Jim made the observation that the RPM was reported to be the same in both locations and with both boat speeds. This is telling, however it does not merely refute the notion that warmer air is the cause of less power, it also refutes the notion that warmer water or greater (or less) salty water is the cause of the slower speed. Anything that slows the boat will cause the RPM to decline with boat speed so I strongly suspect a measurement error is actually the cause for this odd mystery |
Tom W Clark |
posted 01-20-2011 12:37 PM ET (US)
Here is a handy online horsepower calculator that takes into account air temperature, humidity and pressure. http://www.csgnetwork.com/relhumhpcalc.html Used in conjunction with Jim's "Crouch's Speed Calculator" we can actually estimate the difference in speed of vin1722or's Outrage 17 between New Jersey and Florida. [urlhttp://continuouswave.com/cgi-bin/crouchcalc.pl[/url] If we assume air temperature is 50 degrees with 50 percent relative humidity in New Jersey and 80 degrees and 90 percent humidity in Florida, the expected loss in boat speed is 1.3 MPH. |
adlert |
posted 01-20-2011 01:04 PM ET (US)
"Anything that slows the boat will cause the RPM to decline with boat speed so I strongly suspect a measurement error is actually the cause for this odd mystery" Dead On. Thanks Tom. |
Jerry Townsend |
posted 01-20-2011 05:55 PM ET (US)
In addition to some of the above comments: There is insignificant change in density in water between 50 and 70 F. There should be a change in density due to the salinity - if it exists. Air temperature will change the performance of an internal combustion engine - as Tom and others have stated. But - there are other factors in play here as well. That is, the warmer air increases the density - which increases the drag. We don't know the difference in the water conditions, the wind conditions (velocity and direction), the load on the boat - or the fuel consumption. The mere fact that the rpm was about the same - only indicates that the engine rpm was about the same. But, realize that the engine/prop performance (at any given instant) is at the conditions where energy input is equal to the energy output - by definition. Of course, the energy input is from the fuel consumption. The energy output is based on the thrust from the prop and the air/water resistance - which are also balanced. And in addition - as indicated just above - the accuracy of the tachometer is probably not all that good - and perhaps in the range of 3 - 5% at best. And the speed - if measured by some speedometer - the accuracy is probably not all that good either. Speed measured via a GPS is believable. ----- Jerry/Idaho |
Tom W Clark |
posted 01-20-2011 06:12 PM ET (US)
Actually Jerry, warmer air is less dense, not more dense. |
Waterwonderland |
posted 01-20-2011 07:14 PM ET (US)
Just think about your house. Warm air rises to the ceiling. The reason why is that it is less dense. |
posted 01-20-2011 10:28 PM ET (US)
Tom W Clark writes (sarcastically):
quote: The influence of air density on the air resistance of the hull has an influence on boat speed. I made no observation about influence on engine performance. In the case under discussion, the engine speed was the same in Florida as in New Jersey. The engine appears to not have been affected by any air temperature variation. It seems quite difficult to say that air temperature affected the engine when the engine ran at the same speed in both places. I will need an explanation of how the air temperature affected the engine, but somehow the engine ran at the same speed. |
posted 01-20-2011 10:32 PM ET (US)
Tom also writes:
quote: Yes. I agree. The data presented is contradictory, and there is no good fit for the data into the principle of propulsion and Physics. This leaves the gravitational attraction of the moon as about the only possible explanation. By the way, I am serious about that. Very large crude carriers can sail faster toward the moon. |
Jerry Townsend |
posted 01-20-2011 10:55 PM ET (US)
Tom and others - Oops - just running numbers through my head and not thinking. Thanks for pointing that out. --- Jerry/Idaho |
AZdave |
posted 01-21-2011 12:11 AM ET (US)
I wonder whether water depth could be a factor. There is a very wide zone of shallow water surrounding the Keys. Waves travel slower in shallow water. You can see them refract around islands in aerial photos. This is mostly of interest with displacement hulls, but planing hulls still produce a transverse wave, and that wave should be traveling more slowly in shallow water. This effect seems to be large enough that olympic pools are deliberately made very deep to increase the chances of athletes setting new records. |
Wiscbw |
posted 01-21-2011 07:32 AM ET (US)
Florida and New Jersey also use different Ethanol fuel formulation. Florida has varying formulations with Broward, Dade, Duval, Hillsborough, Palm Beach, and Pinellas counties selling 7.8 RVP gasoline from June 1 through September 15. All other counties sell 9.0 RVP gasoline. I think NJ has a lower RVP value. This difference will impact engine horsepower. In what counties were the results observed? A good test would require using the same fuel at both locations. |
adlert |
posted 01-21-2011 08:11 AM ET (US)
The only possible and logical explanation is that: if the boat speed (over water) really and truly was reduced, and this speed reduction was caused by a net increase in drag (pick your favorite drag-inducing poison(s)), the maximum engine speed would also be reduced due to the increased load on the powerplant. Clinging to the notion that an engine can run at identical speeds yet push a boat 2 different speeds is nonsensical and undermines all attempts to solve this riddle. I hope you don't take my statements personally Vinny (or JimH). It just can't be so. A measurement error, or several measurement errors are at play here. |
adlert |
posted 01-21-2011 08:31 AM ET (US)
But wait! Now someone is going argue that a reduced water density will make it easier for the engine to swing the prop (less resistance), allowing the engine to actually rev faster than 5400 but!!...that same reduced water density will increase the hull's wetted surface, increasing drag, slowing it down and subsequently the engine down too from the increased load, striking a final balance of an identical engine speed associated with 2 different boat speeds... Have I got that right? :) Time to push the coffee cup away. |
RobP |
posted 01-21-2011 08:39 AM ET (US)
How was the speed recorded? From the Paddle wheeel/pitot tube or from GPS? If GPS, you will get an accurate speed over ground reading but it neglects the effect current has on the boat, either a slight boost or a drag. To eliminate the you will need to take two runs in opposite directions at the exact same RPMs and exact same trim settings. Then repeat it in the other locations exactly, with the same configuration (top up or down) and vessel loading (fuel, passengers, gear). Too many uncontrolled/unknown variables to draw an accurate conclusion. It is interesting to note that the water temperature in the Keys may have been as cold or colder than the conditions in NJ (which were not provided). That may also indicate that the air temperature was colder than most would expect as well. I can tell you that December here (not that far from the Keys) was much colder than normal. |
vin1722or |
posted 01-21-2011 04:21 PM ET (US)
Guys,I went over the boat and engine prior to leaving Jersey.Had it in the water for many run's to make sure everything was good to go.The engine was tuned up,carb's cleaned,plugs etc.As for a mechinal cause no way.I am going to splash it here in Jersey ASAP to see if I get my 43mph at wot @ 5400-5450 rpm with 1 adult and full fuel which is how the boat was loaded in all test run's.Jim H i did misunderstand your water density suggestion.I thought being that the water being so dense that it would slow you down but now I see that is not the case.Also the readings(mph,rpm's) where correct,i made many runs with and against the current and ran on multiply days over a 3 week period and all the runs where the same results.I will post an update when i get her in the water again.Thanks |
posted 01-22-2011 09:46 AM ET (US)
The crux of this inquiry is as follows: A boat is driven by a propeller. The propeller is turned at the same speed in two locations. We assume there are no other variables in these two instances except for the location, that is, the boat condition, engine condition, weight, or other factors related to the boat are all the same. Even though the propeller turns at the same speed, the boat moves at a substantially different speed in the two locations. In one location (Florida) the boat moves at 39-MPH, and in the other location (New Jersey) the boat moves at 44-MPH. We can assume the atmospheric conditions are similar in both locations. We now ask what factor could account for the 5-MPH difference in speed. The most likely influence on boat speed that remains as a variable is water density. Water density is affected by temperature and salinity. We are told, however, that water temperature in both locations was nearly identical. This leaves salinity as the only possible influence. We know that water density varies with salinity, but the difference in salinity between the two locations is small, and the difference in density of water due to variation in salinity of a small amount is correspondingly small. The ratio of the boat speed in the two locations is 44/39 = 1.1282 We know from the work of George Crouch with moderate planing hulls that to produce a change in speed of a factor of 1.1282 we would need a change in horsepower of a factor of (1.1282)^2 or 1.2728. In order for the engine to produce 1.27-times more power output at the same engine speed, the engine would have to produce more torque at the same engine speed. More torque would imply the load on the propeller was greater. The load on the propeller must be due to having to turn in water that is more dense. Since the propeller turns at the same speed in both locations, we have to assume that the increase in boat speed is due to the propeller turning in water that is more dense and therefore creating more thrust. The propeller can create 1.27-time more thrust in only a few ways: --it can turn faster so it accelerates the water to a higher speed --if can accelerate more water --if can accelerate heavier water We are told that the propeller turns at the same speed, so the first option for increased thrust is not possible. It may be possible that when operating in higher density water a propeller becomes more efficient, however it is difficult to image that the efficiency could improve by a ratio of 1.27:1 due to a relatively minor change in water density. Therefore we anticipate that a propeller turning at the same speed will accelerate the same amount of water, more or less, without a great influence from the density of the water. This leaves the third mechanism, an increase in the weight of the water, as the most likely mechanism to produce more thrust while turning at the same speed. Since the temperature of the water is the same in both locations, we are left with salinity as the only mechanism to explain to difference. Water density increases with salinity. Unfortunately, the water has greater salinity in the location where the boat goes slower. This outcome is the opposite of the anticipated effect of salinity on water density. In summary, there does not seem to be any mechanism to explain the observations. |
adlert |
posted 01-22-2011 11:32 AM ET (US)
"We can assume the atmospheric conditions are similar in both locations. We now ask what factor could account for the 5-MPH difference in speed." Why is this? Did I miss something? I saw where Vinny noted the water temps were similar but was air temp and humidity noted as being similar? |
posted 01-22-2011 02:58 PM ET (US)
The effect of air temperature, density, or humidity on the boat are minimal, apparently so minimal that people laughed at mentioning it. The effect of air temperature on the operation of the engine is discarded in this case because the engine ran at the same speed in both locations. Atmospheric influences are not considered because the engine turned the propeller at the same speed. |
elenakagan |
posted 01-22-2011 04:31 PM ET (US)
The simple reason that boats run faster in New Jersey is due to the fact that that water contains a high percentage of medical waste. Amphetimine derivitives being dumped in the waters by dentists and illicit drug users cause this phenomenon. |
vin1722or |
posted 01-22-2011 04:34 PM ET (US)
The water temp in Jersey when I ran the boat in the late summer into early fall prior to leaving for florida was around 78-80 degree's,the water in florida was upper 50's to low 60's.Air temp was 80 in Jersey and in the 60's in florida.What bothers me is the boat ran at 34 knts when I bought it in the spring and repropped it,raised the engine 1 hole up and achieved 38.5 knts which is where I and many CW people thought it should be.I get to florida and 39 mph is all I get is 39mph.I am not a speed freak,i just like things to work the way there are supposed to and could not understand how a 4-5 mph difference is possible. |
adlert |
posted 01-22-2011 04:38 PM ET (US)
OK Jim. |
Tom W Clark |
posted 01-22-2011 05:00 PM ET (US)
quote: vin1722or -- It's not possible. No, let me be more clear. Ceteris paribus, it is not possible for a boat/motor with the same propeller to travel two radically difference speeds at WOT yet turn the same RPM. What is possible: - A boat can be faster in saltwater vs. freshwater. - A boat can be faster in colder air. We can correctly argue that colder air is more dense, that colder water is more dense, that saltier water is more dense and that density and drag are related. We can correctly argue that the pull of the Moon will influence boat speed. We might even to be able to argue that water depth influences water speed. But all these things are completely insignificant on the context of your situation. Discussion of them ignores the elephant in the living room: the difference in reported boat speed is 3-4 MPH. You reported that it is not a measuring error and I accept that. Boat speed and RPM have been measured accurately. You are not making this up. But as with most mysteries, there is probably a simple explantation. Nothing discussed above can accommodate such a great difference in boat speed...except this:
quote: I note that 34 knots is about 39 MPH. You inadvertently put the old prop on the boat before going to Florida. |
contender |
posted 01-22-2011 07:25 PM ET (US)
elenakagen: There are far more drugs in South Fla, than New Jersey, trust me.... The only two items that can make the boat go a different speed is the air temp/humidity, and maybe the salt water. The moons pull would be to small to calculate. And I do not think water depth changes anything. But the rpms being the same does not add up... Or your wife woke you up cause you were going to be late for work... |
Jorgen |
posted 01-23-2011 10:13 AM ET (US)
A combustion engine uses fuel + Oxygen + ignitor to work. Ambient pressure has direct influence on the density of the air containing typically 20,95 % volume Oxygen. If the ambient pressure goes up the air becomes denser and There for a combustion engine will perform better when the ambient pressure is higher. |
weekendwarrior |
posted 01-24-2011 07:57 AM ET (US)
Did you check speed in two directions? In some areas here the current runs an easy 5mph during tide change near some inlets. Also if you were in the Gulf Stream it runs north at 5-MPH in some areas. |
posted 01-24-2011 09:18 AM ET (US)
Variation in speed measurement units between statute miles and nautical miles would explain a great deal of this mystery. |
Waterwonderland |
posted 01-24-2011 09:45 AM ET (US)
I just hope someone can solve this mystery soon, so I can go back to sleeping at nights. |
Russ 13 |
posted 01-24-2011 07:33 PM ET (US)
WOW that is alot of theory, and not one "bite" on my too many people/boaters in Florida comment. I too would guess. 1) current/depth effect on the vessel. 2) air density/fuel difference effect on H.P. ... Solution: install a larger outboard so that boat will get up to 60 MPH. The owner will be too busy holding on to be concerned with 5 mph.:-) |
Waterwonderland |
posted 01-24-2011 10:37 PM ET (US)
Russ, I laughed at your first theory. Didn't you hear it? |
adlert |
posted 01-25-2011 08:42 AM ET (US)
I think I hear Vinny laughing. |
Tohsgib |
posted 01-25-2011 10:50 AM ET (US)
I call this whole thing BS being I live in FL and supposably I rig some of the fastest Whalers in the world. So far nobody has rigged a Newport with a 70 Suzuki 4S to do over 39mph like mine. Second my 19' Revenge with a 115 Suzuki 4S is faster than most here with Suzuki 140's at 40.5. Therfore I concur that Vin overlooked something like MPH or knots, etc or was just having a bad day. |
Binkster |
posted 01-30-2011 08:46 AM ET (US)
Years ago before the lake dried up, Salton Sea in California was the place where all water speed records were set. I believe the lake is in the desert in Southern California, which of course would be in a hot climate. the lake was/is salt water with the salinity much higher than the ocean. Also the records were always set at daybreak, when a mist was settling over the lake. The mist makes the atmosphere dense, and of course dense air contains more oxygen, which is one of the 3 requirements the internal engines need to run. I am stating this from memory, no, I have never been there, but if you care to you could check out the facts on the Internet. this would disprove any nonsense about more salinity and hot weather would make your boat run slower. |
Binkster |
posted 01-30-2011 08:54 AM ET (US)
This post is part of the above post. Apparently the lake (Salton Sea) is back. there even is a Speed Week for boats. Check it out http://www.nbclosangeles.com/news/sports/ Speed-Record-Set-at-125-MPH-on-Salton-Sea.html |
John McBride |
posted 01-30-2011 09:48 AM ET (US)
If running eastward nearer the equator, you'll be much faster due to the rotation of the Earth, duh. Westward is another matter. |
Waterwonderland |
posted 01-30-2011 10:27 AM ET (US)
The Salton Sea area does get warm in the daytime but is cold at night. This time of year the night will bring temperatures in the low 30s. Logically the racers would would want to run in the cool (dense air) mornings. Its low elevation (226' below sea level) would also provide denser air. The 25 percent greater salinity provides superior buoyancy. |
