ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Whaler Performance Cold Water Powers CONTINUOUSWAVE
Author | Topic: Cold Water Powers CONTINUOUSWAVE |
posted 06-16-2011 09:20 PM ET (US)
Earlier this week we were on a 60-mile run between ports on our cruise of Northern Lake Michigan. The seas were just about glass-smooth, with only a little ripple on the water. We had been running along for a while at optimum cruise--well, it is hard to say what optimum cruise is any more because there is a wide range of speeds where the fuel economy is more or less constant around 2.7 to 2.8-MPG. Just for fun, I pushed the throttle all the way forward, and the boat accelerated to 43.5-MPH. I think this is a new speed record for my Boston Whaler REVENGE 22 W-T WD with the 225-HP Evinrude engine, at least for the boat in cruising trim. We had plenty of fuel, all the canvas was up, and the boat was loaded with cruising gear. What seemed to be different was the water temperature: Lake Michigan was a frosty 45-degrees. The cold water must have been the difference. I was quite surprised to see the GPS receiver speed report 43.5-MPH. [UPDATE: 43.5-MPH was the highest speed I happened to see while glancing at the display, but the log on my display device says we hit 43.8-MPH as the highest speed.--jimh] The significant improvement in top speed while fully loaded seems like it is due to the cold water temperature. It is just another reminder of how many variables affect boat speed. Making rigorous comparison between boat speed tests must account for all the variables, including water temperature. Give me some cold water if you want to go for top speed. |
David Jenkins |
posted 06-16-2011 11:49 PM ET (US)
What is the theory behind the idea that boats will go faster on cold water? Is there a similar theory regarding the salinity of the water or the humidity of the air? To this southerner, 45 degrees sounds like the ideal temperature for beer not lake water. This is in June? |
Tom W Clark |
posted 06-17-2011 12:22 AM ET (US)
I doubt very much that cold water had much, if anything, to do with your faster speed. Air temperature, humidty and salinity, sea state, yes, those things will have a very significant affect on boat speed. Water temperature? Not so much. What propeller are you using on this trip? |
number9 |
posted 06-17-2011 06:45 AM ET (US)
Don't forget that the higher the barometric pressure the denser the waste. |
posted 06-17-2011 07:04 AM ET (US)
I don't have any record of the air pressure, but the weather was very fair and there was a high-pressure system over the Great Lakes. ASIDE: my Evinrude engine has an atmospheric sensor or barometer included in the engine, and via the NMEA-2000 network connection the engine reports barometric pressure. I modified one of the information display pages on my multi-function Lowrance HDS series display to show the barometric pressure. Next time I am recording performance data I will make a note of the barometric pressure as reported by the Evinrude E-TEC. Sea state was ideal for a speed run. The were no waves and just a little ripple on the surface. Air temperature was probably about 60-degrees-F. On land it was warmer, but in the middle of the Lake with the water still this cold, the air is still chilly. Yes, mid-June at 45-degrees-North latitude. The propeller was the trusty old MIRAGEplus 17-pitch. |
Jefecinco |
posted 06-17-2011 09:35 AM ET (US)
It seems you have an ideal engine/boat/propeller match. What was the engine RPM at 43.5 MPH? Butch |
Tom W Clark |
posted 06-17-2011 10:44 AM ET (US)
WOT engine speed? Let me guess: 5450 RPM. Barometric pressure, yes. Higher pressure, denser air, more power. Also, the cold water will make the air temperature cooler as well. The air inducted into the motor is probably air that lies closer to the surface of the lake. |
Binkster |
posted 06-17-2011 10:30 PM ET (US)
Boats will run faster in cold water, that is a known fact. The water is more dense as the molecules hang closer together for warmth and hence the boat will displace less of the dense water, and will ride cleaner in the cold water. The water as it gets colder will continue to become more dense, until it reaches 32 degrees and becomes solid. Now the boat will displace no water at all. |
David Jenkins |
posted 06-17-2011 10:56 PM ET (US)
quote: You are kidding, right? I thought that heat moved in one direction: from things hot to things that are not as hot. Your description of molecules makes them sound like they are alive.
quote: When I put water in an ice tray and stick it in the freezer, I had better not fill the tray to the brim because as it nears the freezing temperature it seems to expand (i.e., become less dense) and the full ice tray spills onto the freezer shelf. And my wife fusses at me. That seems to contradict what you say is a well-known fact, Binkster. Am I missing something? |
jharrell |
posted 06-17-2011 11:47 PM ET (US)
Heat is is energy transferred from one system to another. Temperature is mean kinetic energy or motion of the atoms in the molecules of the item in question. Just like one of those paddles with a ball a rubber band connected, the harder you paddle the farther apart they will get. The higher the temperature the farther part the atoms get in a substance get by bouncing off each other harder, but they are tied together by their chemical bonds or electromagnetic force like a rubber band. Temperature is just motion. Heat is an abstract quantity of energy transferred causing temperature to change. Heat is like water it flows downhill from high to low temperature, unless you have an aptly named heat pump to move it uphill, such as a air conditioner or refrigerator. Water has a special property like some molecules it forms crystals as the temperature goes low enough to phase into a solid. These hexagonal crystals push the molecules part slightly to fit together like puzzle pieces, this causes water to be most dense in liquid form at 39 degrees f then become slightly less dense as it turns to ice. |
Binkster |
posted 06-18-2011 06:15 AM ET (US)
David says "Your description of molecules makes them sound like they are alive." They're not? Oh, wait, I think I was describing cells. I better review my notes on this subject. After reviewing, my new conclusion is this: I think boats will go faster in warm water with a high salinity content--lots of salt. Why? I don't know, but most water speed records were set on the Salton Sea in the desert in California. It's a couple times as salty as the ocean, and it [is] also below sea level. Records were attempted at sunrise when the air was moist which makes the air more dense (more oxygen.) I guess that leaves jimh out in the cold (water). |
posted 06-19-2011 09:47 AM ET (US)
Fuel economy on this trip was also very good. The average fuel economy for about 270-miles of boating was just a hair below 3.2-MPG. Considering we used to feel good about getting 1.8-MPG with the old motor, I am extremely pleased. My 2010 Evinrude E-TEC 225-HP V6 low-emission outboard has just been a delightful improvement to my classic Boston Whaler boat. It has: --allowed me to cruise in the pristine fresh water paradise of the Great Lakes with the best, highest-rated, cleanest outboard engine on the market. No two-cycle smoke, no oil slicks, no air pollution; --allowed me to reach new high speeds--faster than a speeding bullet; --allowed me to reduce my fuel usage rate by a very significant amount, saving significant money on fuel; --allowed me to enjoy much improved running characteristics from the engine, such as faster starting, smoother idle, less throttle adjustment, less engine speed hunting, and a much wider range of economical operation; and, --allowed me to install and experiment with a modern engine data network that displays, computes, and logs all sorts of interesting information. Can you tell I am very keen on the Evinrude E-TEC engine? Yes, I am. It has been a wonderful improvement to my classic Boston Whaler boat. |
jimp |
posted 06-19-2011 10:50 AM ET (US)
JimH - Glad you had a good trip - bug-zapper and all. Makes boating fun again! (Well, it's always fun, but sometimes more fun than other times). I had the same feeling when I went from a 1989 225 Johnson on my 1990 Revenge 22' - W.T. to the direct fuel injection 2003 225 Mercury Optimax. From a "hopeful" 2.0 nmpg when partially loaded with gear to over 3.0 nmpg when loaded with gear. JimP |
pcrussell50 |
posted 06-21-2011 08:41 PM ET (US)
quote: Binks, you stepped in it again, brah. :) Moisture/humidity/water vapor makes the air less dense. It displaces oxygen. The runs were probably made early in the morning because the air is cooler, which is more dense with oxygen. On an interesting note, when a vehicle, (even a boat), starts to go fast enough that air resistance becomes a factor, it is not a given that you want to be as low as possible to get the denser air. Turbine powered aircraft are an example. The turbine engines still make a lot of power at altitude, but the vessel itself needs the thin air, to really get cooking in terms of speed. Certain turbocharged cars can run a little faster in Denver than at sea level because they can make almost as much power, and the air drag is less... a little less. -Peter |
an86carrera |
posted 06-22-2011 10:21 AM ET (US)
Water, H2O, is the only molecule that I know of that becomes less dense as it varies from it's freezing temperature in EITHER direction. So, yes you need to leave room in the ice cube tray for expansion, but it will require less and less room as the temperature approches 32 degrees F and the molecules become MORE dense until it reaches 32 degress at which point it will start to expand or become LESS dense. Carry on. Len |
an86carrera |
posted 06-22-2011 10:26 AM ET (US)
Cold water being MORE dense will also make the boat float higher because it needs to displace LESS of the heavier water. The converts to LESS wetted surface. Len |
Tom W Clark |
posted 06-22-2011 10:30 AM ET (US)
You want to take another run at that Len? |
an86carrera |
posted 06-22-2011 10:51 AM ET (US)
Tom, are you talking about the expansion of H2O above AND below freezing oops sorry 4 degres Centigrade? Do I need to? How about fact checking it first? From Wikipedia: Density of water and iceDensity of liquid water Temp (°C) Density (kg/m3)[17][18] The density of water is approximately one gram per cubic centimeter. More precisely, it is dependent on its temperature, but the relation is not linear and is not even monotonic (see right-hand table). When cooled from room temperature liquid water becomes increasingly dense, just like other substances. But at approximately 4 °C, pure water reaches its maximum density. As it is cooled further, it expands to become less dense. This unusual negative thermal expansion is attributed to strong, orientation-dependent, intermolecular interactions and is also observed in molten silica.[19] The solid form of most substances is denser than the liquid phase; thus, a block of most solids will sink in the liquid. However, a block of ice floats in liquid water because ice is less dense. Upon freezing, the density of water decreases by about 9%.[20] The reason for this is the 'cooling' of intermolecular vibrations allowing the molecules to form steady hydrogen bonds with their neighbors and thereby gradually locking into positions reminiscent of the hexagonal packing achieved upon freezing to ice Ih. Whereas the hydrogen bonds are shorter in the crystal than in the liquid, this locking effect reduces the average coordination number of molecules as the liquid approaches nucleation. Other substances that expand on freezing are silicon, gallium, germanium, antimony, bismuth, plutonium and other compounds that form spacious crystal lattices with tetrahedral coordination. Only ordinary hexagonal ice is less dense than the liquid. Under increasing pressure, ice undergoes a number of transitions to other allotropic forms with higher density than liquid water, such as high density amorphous ice (HDA) and very high density amorphous ice (VHDA). Water also expands significantly as the temperature increases. Its density decreases by 4% from its highest value when approaching its boiling point. The melting point of ice is 0 °C (32 °F, 273 K) at standard pressure, however, pure liquid water can be supercooled well below that temperature without freezing if the liquid is not mechanically disturbed. It can remain in a fluid state down to its homogeneous nucleation point of approximately 231 K (−42 °C).[21] The melting point of ordinary hexagonal ice falls slightly under moderately high pressures, but as ice transforms into its allotropes (see crystalline states of ice) above 209.9 MPa (2,072 atm), the melting point increases markedly with pressure, i.e., reaching 355 K (82 °C) at 2.216 GPa (21,870 atm) (triple point of Ice VII[22]). A significant increase of pressure is required to lower the melting point of ordinary ice — the pressure exerted by an ice skater on the ice only reduces the melting point by approximately 0.09 °C (0.16 °F).[citation needed] These properties of water have important consequences in its role in the ecosystem of Earth. Water at a temperature of 4 °C will always accumulate at the bottom of fresh water lakes, irrespective of the temperature in the atmosphere. Since water and ice are poor conductors of heat[23] (good insulators) it is unlikely that sufficiently deep lakes will freeze completely, unless stirred by strong currents that mix cooler and warmer water and accelerate the cooling. In warming weather, chunks of ice float, rather than sink to the bottom where they might melt extremely slowly. These phenomena thus may help to preserve aquatic life. Len |
David Jenkins |
posted 06-22-2011 10:58 AM ET (US)
This thread makes me laugh but I am not sure why I find it humorous. Is everyone in earnest? No doubt the idea that water molecules would huddle together for warmth was a joke—but what about Jim's original assertion that one reason why his boat went faster than normal was because the water temperature was 45 degrees. Do you really believe that, Jim? |
Tom W Clark |
posted 06-22-2011 11:00 AM ET (US)
quote: Len -- Ice is LESS dense than water, not more dense. That is why it floats. |
Tom W Clark |
posted 06-22-2011 11:07 AM ET (US)
David -- The mechanics by which cold ware can make a boat faster is well understood and exactly as Len explains it. Colder water is more dense, a boat floats higher and has less wetted surface and thus less friction. However, Jim suggests that cold watre can have a profound effect on the speed of his boat but the reality is that while colder water is more dense, it is not a lot more dense. The difference in density between 45 degree water and 75 degree water is *maybe* 1 percent. I do not think that a change in water density of 1 percent can add 2 MPH to Jim's boat speed by itself. |
an86carrera |
posted 06-22-2011 11:13 AM ET (US)
Not trying to get in a argument here but water gets LESS dense as it deviates from 4 degrees Centigrade in EITHER direction. Len |
jharrell |
posted 06-22-2011 11:25 AM ET (US)
Tom, I am pretty sure that's what Len is saying, water is most dense at 39F then between 39F and 32F it freezes forming a crystal lattice that pushes the molecules apart slightly lowering density. So water at 45F is near it densest point, salinity also affects water density, if salinity has an affect, so should temperature. Other substances get less dense in solid form, silicon, gallium, germanium, antimony, bismuth, plutonium and other compounds that form spacious crystal lattices when solid. |
David Jenkins |
posted 06-22-2011 11:30 AM ET (US)
Jharrell seems to agree with you Len. quote: So if 75 degree F water has a certain density (specific density of 1?), does it become more dense at it gets colder, then at 39 degrees F it is most dense, then it expands and gets less dense than the 75 degree water? It only overflows the ice bin as it nears freezing. Is that correct? So Jim's 45 degree water should be more dense than my 75 degree water. Right? |
Tom W Clark |
posted 06-22-2011 11:35 AM ET (US)
I am absolutely sure Len has it right but the way he phrased it initially was ambiguous. That is why I wanted it to be clarified for everyone reading this. If ice were not LESS dense than water, life as we know it would not exist; Earth would be frozen solid. Yes, as has already been pointed out, more dense water will be faster for a boat. Cold water is more dense. Saltwater is more dense. We are all in agreement here. But quantifying that difference is another matter. I do not see how 45 degree water can increase boat speed by 4-5 percent by desnity alone. |
jharrell |
posted 06-22-2011 11:44 AM ET (US)
75F water is actually less dense than ice all the way to 14F. I would say the difference between 75f and 39f is significant, more so than most ice to water. |
Tom W Clark |
posted 06-22-2011 12:00 PM ET (US)
Yes, I couldn't agree more. Mostly because the speed of a Boston Whaler is very poor in solid ice. |
jharrell |
posted 06-22-2011 12:08 PM ET (US)
Actually what I said was incorrect, the density chart is for liquid water only, the temps below 0C are supercooled liquid water not ice. Having a hard time finding a density chart for ice to compare to liquid water. But Wikipedia says: "Upon freezing, the density of water decreases by about 9%." and: "Water also expands significantly as the temperature increases. Its density decreases by 4% from its highest value when approaching its boiling point." So it would seem the 75F to 39F is not as significant as I thought. However I think would go quite fast on solid ice if you could get the prop to bite :) |
an86carrera |
posted 06-22-2011 12:24 PM ET (US)
quote: But not ON ice if you were to power a Classic 13' with a fan in airboat fashion;o) Len |
L H G |
posted 06-22-2011 05:22 PM ET (US)
Cool, dense air is what makes an engine more powerful, not cool dense water. And boating in Lake Michigan's cold water right now really provides this at surface level. As a matter of fact, from my direct experience, a boat will run faster in 75 degree salt water than it will in 40 degree fresh water, as long as the air is not hot and humid (which can sap as much as 15% of HP). Salt water bouyancy really helps with top end. |
posted 06-22-2011 08:30 PM ET (US)
I agree, the water density does not affect the engine, except negatively, as the engine has to drag its gear case through the water, and the denser the water, the more difficult it is for the engine to drag its gear case through it. Denser water does not help the engine produce more power. I don't think anyone said that or implied that, and I am not sure anyone inferred that from what's been said. Denser water helps the propeller produce more thrust. It helps the hull develop more lift. Denser air helps the engine. Although not intuitive, dry air is denser than humid air. Cold air is denser than warm air. Water at 45-degrees; air at very moderate temperature, perhaps 55-degrees, and air with low humidity all help an engine, a propeller, and a boat reach higher speeds. ASIDE: Looking at some notes, I see CONTINUOUSWAVE actually has been faster, hitting 44.4-MPH on a cold fall afternoon, but that was with the boat stripped of gear, no canvas, and just a few gallons of fuel. For full cruising trim, lots of fuel, and all the canvas up, the 43.8-MPH was a new top speed. |
L H G |
posted 06-22-2011 08:49 PM ET (US)
Jim - I think that's a very good speed for the boat, remembering that when I bought mine I was told by the factory people that Whaler Drive takes about 5 mph off of top end with same power when compared to a cut transom model. |
Binkster |
posted 06-22-2011 09:13 PM ET (US)
Here is where to go to find the fastest water on earth. Seems about 180 degrees off from Lake Michigan. Maybe their missing something. http://blip.tv/films-and-videos-from-the-lafco-bus/ salton-sea-boat-races-for-world-record-speed-on-water-1579714 |
posted 06-22-2011 09:21 PM ET (US)
If there were a body of saltwater with the same salinity as the Salton Sea but in Alaska, I am sure the speed records would all be attempted in Alaska. |
posted 06-22-2011 09:34 PM ET (US)
On the air density we had in the middle of Northern Lake Michigan, I think we may have gotten a boost from all the recently hatched flies. There were so many flies in the air--even in the middle of the lake--that the air being pulled into the E-TEC was probably increased in density by the biomass of all the flies coming along with it. |
Binkster |
posted 06-23-2011 08:57 AM ET (US)
jimh, I think the 250 ft. below sea level has a lot to do with it. Isn't air more dense the lower you are? Not to many lakes are below seal level, how about the Great Lakes, are they above or below the level of the oceans? |
weekendwarrior |
posted 06-23-2011 01:03 PM ET (US)
I am going with what has proven to be true for as long as motors have been on boats. Motors always seem to run better than they ever have just before they come apart! You were lucky to make it back. ;) |
Binkster |
posted 06-23-2011 10:25 PM ET (US)
Obviously my first post about the water molecules hanging closer together for warmth was made in jest. After reading all the posts on this thread, mostly written by chemical engineers that specialize in H-2-0, waiters, prop guys, a used car salesman and an out of work roofer, I have come to the conclusion that speed on the water is dependent on only two things, the density of the water and the salinity of the water. Salton Sea has the most of these two things. Water speed records set there were generally set in the fall or winter at sun up. I believe it is a bit chilly there on the desert in the morning at that time of year, even in southern Ca. and the 250 feet below sea level is even a bigger factor in making the air more dense. Then there is the salt content, which is over 2 times the salt content of the ocean. Everyone that has swam in salt and then fresh water can attest to the fact that it is easier to float in salt water. The cold 45 degree water in Lake Michigan probably made the air a little more dense, we don`t know the elevation of lake Michigan in relation to sea level. but we do know that jim's boat will displace more of that fresh water that if he was running on the Salton Sea. This can be proven if we all get together and sponcer a boat trip and a run on the Salton Sea for jimh and his family and Whaler. I predict he will go a little(not much) faster down there, and I will start the sponsorship off by donation the first $10. |
posted 06-24-2011 09:03 AM ET (US)
The Great Lakes flow into the sea. This may permit some observers to deduce the elevation of the Great Lakes relative to sea level. I have to observe that the effect of cold water is not limited to the boat. We should permit cold water to have its effect on other elements involved in the operation of the boat. For example, the air in the region near the surface of the cold water will also be affected by the cold water, and the effect should be for the temperature of the air to tend to change toward the temperature of the water. This phenomenon can be seen visually when the air temperature near the water surface decreases and causes condensation of water vapor in the air, often called fog. It is reasonable to assume that if the water temperature were in the range of 45-degrees-F that it would affect the temperature of the air close to the water surface, that is, the air the engine was ingesting for its combustion, lowering the air temperature and making the air more dense. |
posted 06-24-2011 09:07 AM ET (US)
On the day we observed the boat speed which is the topic of this discussion, I should mention that the wind speed was near zero. This may have lead to the air above the water being quite stable and stratified, and the air temperature in the layer near the water being substantially colder than normal as it was not being mixed with warmer air currents. |
Waterwonderland |
posted 06-24-2011 09:46 AM ET (US)
FYI - The Salton Sea air and water temperatures are relatively cool in December. http://www.idcide.com/weather/ca/salton-sea-beach.htm |
deepwater |
posted 06-25-2011 06:56 AM ET (US)
Maybe your Whaler was just being happy,,^@^ hey Max hey Serge |
