ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Whaler Performance Horsepower Differences by Firmware
Author | Topic: Horsepower Differences by Firmware |
pcrussell50 |
posted 08-10-2011 01:34 PM ET (US)
In another thread it was brought up that that some makers of modern outboards make two identical motors, offered in different power levels. A feat they ostensibly achieve by using different [engine control module] calibrations. what precisely it is they change from one to the other? There is fueling and spark advance. Maybe some cam timing in the case of complex four-cycle outboard engines. Fueling is tough to mess with, because mixture less than ideal--you can cut power by fueling over rich, but that will ruin you emissions status. You can mess with timing--a little--but not enough to create a 25-percent difference in power and still have it run acceptably. The only other thing I can think of is possibly building the motors really peaky, with a big wallop of power at the very top, and put a rev limit on the lower powered motor, denying it the big slug of power at the top. I suppose they could combine that tactic with the paperwork slop allowed in claiming a certain horsepower. Maybe the (hypothetical) 115-HP is allowed to make 120-HP and the 130-HP is allowed to make as little as 125-P, then you can fudge out the remaining 5-HP with tuning. -Peter |
Tohsgib |
posted 08-10-2011 03:41 PM ET (US)
You are correct in many fashions but what about the engines that are identical blocks and redlines but different power? That could be what you are saying in your last paragraph but I doubt it. The Suzuki 40 and 50 are identical, except for ECM, I believe. You might have to parts look and see if a larger throttle body is used but I doubt that as well. All I can tell you is I know a couple people with the same boat as me, setup almost identical but with the 140 Suzuki and they see no more performance than my 115. |
dgoodhue |
posted 08-10-2011 03:42 PM ET (US)
Manufacturer definitely can limit power safely. In the new Camaro he after market tune gained only like peak 10-HP on a 425-HP motor, but the lower [engine speed] of the tune it gained 90-HP. I was at the track with friend years ago and he quickly set his timing with out a timing light. His times were slower than expected. We went home, checked his timing, and it found it was down 7-degrees. We gain 0.6 in the quarter mile next time, that was in the range of 20-HP. |
pcrussell50 |
posted 08-10-2011 04:08 PM ET (US)
What I am asking, this time without the speculation on my part is, what ECM tuning changes do the manufacturers make to two otherwise identical modern outboards than can possibly cause a real verifiable, 25 percent difference in horsepower? Feel free to talk specifics with me. I do my own ECM tuning on my race car motors. Dgoodhue. A 90-HP difference on a 425-HP-class car, just by ECM tuning is on the order of 20-percent. I do not see how that is possible unless the factory calibration was way off, which it wasn't if the car was emissions compliant when it left the factory. You are talking about a 20% increase in power from a PCM calibration that cannot hold a valve open longer, or higher, and cannot make an intake or exhaust port larger. If the motor was totally, 100% stock when your people changed the ECM tune and it picked up 20% more power than an emissions-compliant, professional tune, I'm just gonna have to remain skeptical. Do you have dyno sheets you can scan and show me? Tuning notes from tuner? Who was the tuner? It also seems a little unusual that someone would pay for a custom tune on a bone stock motor, when there are already many off the shelf aftermarket tunes for that same, bone stock motor. Usually people who rent dyno time for custom tunes are trying to optimize mods they have performed, (meaning the motor is no longer stone-stock). -Peter |
dgoodhue |
posted 08-10-2011 05:07 PM ET (US)
I will find and post the info for you. |
Jefecinco |
posted 08-10-2011 08:13 PM ET (US)
Peter--In the case of a 135 HP L4 Verado it can be up-tuned to a 200 HP L4 Verado by changing the ECM. That's around a 50-percent increase. Imagine how much the L4 135 HP Verado is detuned and what impact that could have on longevity. I believe the supercharger and its boost setting is the primary factor. Butch |
posted 08-10-2011 09:21 PM ET (US)
I know very little about engine design, but it seems obvious that the more fuel you pump into the engine the more power it will produce. In the case of an engine like the modern Evinrude E-TEC direct-injection engine, it is estimated that with their fuel injector they could push about 90-HP per cylinder from their 3.3-liter V6, or about 540-HP, based on the amount of fuel the fuel injector could supply. With the 3.3-liter block they made 200, 225, and 250-HP variants. I think the power is controlled by how much fuel the injector is permitted to supply. The injector timing is all controlled by software. It is not hard to see how you could vary the power easily. The Mercury VERADO L6 is sold from 200-HP to 275-HP with what I believe is the same mechanical configuration. The power output is likely influenced by supercharger boost pressure. (And the more power the shorter engine life, as far as I can see.) These old dock-talk tales about extra horsepower went out with the tide when the EPA got involved. Emission is based on power produced. The more power produced, the more emission you are allowed. The lower the rated power the lower the emission must be, and the harder to meet the limit if your engine is supposed to be making an extra ten percent more power. These days when you buy a 225-HP engine, you get 225-HP and not any more. If you want more power, you buy the 250-HP engine and pay more. |
contender |
posted 08-10-2011 10:09 PM ET (US)
Not to get off the subject, but this is what I like about the diesel engines, I can get more torque and horsepower just by changing the chip and then exhaust if I really want to go high end |
pcrussell50 |
posted 08-10-2011 10:29 PM ET (US)
With all due respect, Jim, I'm not following you. If you try to make a powerful motor less powerful by injecting less fuel without a corresponding reduction in air flow, do you avoid dangerously lean conditions? If you try to make a less powerful motor more powerful by adding more fuel without adding more air, how do you keep the mixture from becoming rich. Further, even. slight increase in enrichment brings devastating increases in HC emissions. And Butch, if you wanted your 135hp Verado to become a 200hp Verado, you could not get there on an ECM change alone... unless the blower had a magnetically variable drive that the ECM could control the boost output with. Otherwise, you are looking at changing the pulley, belt, and (probably) injectors. Unless Jim is somehow right and you can simply vary the fuel tables to your hearts content, and the correspondingly appropriate airflow somehow be there. Somebody's got to bring more meat to this table. Jharrell? You've got to know this stuff. Nick? You too, mate. -Peter |
dgoodhue |
posted 08-11-2011 09:21 AM ET (US)
I found the article was in GMHTP, it was a 2010 stock Camaro 2010 L99/automatic 399hp. At 3300 rpm is was down 95hp and slowly went up from their to 44hp down at 4000rpm. Peak hp was up 10hp. The article meantioned that stock it had really low timing in the 3000-4000rpm range ( no numbers given though). Many you have probably experience a car with torque management (slow shifts with reduce power). Manufacturers do this to reduce warranty claims. I believe the Verado has a boost controller to bleed off boost. So those would be easy to control. As I mention above timing can control the hp. I don't know if any outboard motor has a variable intake. Which basically is plate that opens up at higher for high end hp. The lower rpm has smaller passages that promote low end torque. My daily driver has it. The switch normally open up at 4800 rpm. If I disable it my engine is winded by 5500rpm (instead of going strong to 7000rpm) and is down a good 30-40hp. Obviously any motor is cam timing control by a computer could easily affect the hp. pcrussell is correct that you just can't change the fueling without doing other change. Just taking away fuel will create a Lean condition. Initially taking away fueling will actually increase hp untill it experiences detonation. Running richer would be the better way to reduce hp but I doubt manufactures are doing that either. |
tedious |
posted 08-11-2011 10:06 AM ET (US)
How about reducing power by skipping cycles on the fuel injection and ignition? I'd think this would be hard to make smooth, but rev limiter circuits do this anyway. Skip 10% of the bangs and you'd drop 10% in power, right? Actually you'd maybe drop more than 10%, because you'd have to be compressing the air, but getting nothing for it. Tim |
Jefecinco |
posted 08-11-2011 10:35 AM ET (US)
Peter, For more information on the HP increases available on the Gen 2 Verados by simply changing the ECM search veradoclub.com. As stated, I believe boost control is the key. If anyone has a Gen 2 Verado L4 200 HP ECM they'd like to get rid of let me know. Please. Butch |
jharrell |
posted 08-11-2011 11:39 AM ET (US)
Peter, Superchargers can have variable waste-gate like valves to control boost. I believe the Verado has an electronic boost controller based on this. With a boost controller you can pulley the supercharger for higher boost at lower RPM's and have the boost controller bleed off boost based on conditions. This almost gives you the equivalent of a variable displacement engine. So boost control along with EFI or DFI and some VVT can give you quite a lot of computer control over the engine parameters. Whether a stock Verado 135 can become a 200 with just different software I don't know. Usually a engine manufacturer will take advantage of the lower horsepower using less expensive, and lighter weight components. So even if the 135 and 200 have the same specs, if you ran the 200 programming on the 135 it might be more likely to blow, maybe the crank is cheaper or whatever. If they truly are the same then the 135 is a very overbuilt engine for it's horsepower, which can be a good thing, usually companies avoid overbuilding though as it cost them money. The trend is definitely more electric control over all aspects of the engine, there is already work being done on electric valves which would provide infinite valve timing per cylinder. Then there is this prototype from Lotus which should make two-stroke fans happy: http://www.youtube.com/watch?v=fIG9pWldO8U |
Tohsgib |
posted 08-11-2011 11:50 AM ET (US)
I had a 2004 GTO when they came out with the 350hp LS1 and 6 spd trans. My friend had the same engine in his 2002 Vette w/auto. He had the programmer and changed a bunch of settings and the car came alive, especially midrange and shift points. For my car with the 6spd all it would do was change the rev limiter which was not worth $400 to do. With my Jetta & Jeep diesel it is easy to get more hp even though my Jeep is direct injected. It basically just dumps more fuel in it and changes turbo boost. Set on #10 I could literally melt the Turbo if I ran it too hard for too long like multiple track runs. That may be why I had to replace my turbo hoses at 55k miles. It would change the Jeep from 160hp & 300torque to 250 & 450....it was an animal. The cool thing was you could set it from inside the car from Economy mode(which I ran 99%) or 1-10. When I was towing the 19 I would set it at 4 or 5 and that way it was not struggling at takeoff from lights. Seemed to make it like I was towing a 17 instead. Worked great until it got stuck on around 7-8. She would fly but even at low speeds the black smoke was embarassing. One guy flagged me over saying my truck was on fire. So I removed it at about 40k and 3.5 years ago. Pity because it cost $520. |
tedious |
posted 08-11-2011 12:53 PM ET (US)
OK, it's easy to see how they do it with boosted motors, but how do they do it on naturally aspirated motors? |
pcrussell50 |
Pulleying up to build more boost than you need, and blowing off the excess with and ECM controlled blowoff valve, (BOV)? It's technically feasible, by placing the air meter after the BOV, but so complex and inelegant that I'm not sure any OEMs actually use it. The first issue with that approach that comes to mind is that with a positive displacement, (PD) supercharger, you will be heating the daylights out the intake charge air, to levels you would get with high boost, and only using a little bit of it. It's so inelegant, factory auto engineers basically don't do it, (unless something like it is being done VERY recently with some kind of modern technology DFI system. If so, I haven't heard of it. The Caddy CTSV has a PD supercharged powerplant. Somebody can correct me if I'm wrong, but I'm pretty sure it does not employ this tactic. The wildcard with the Verado is, it's cooling system. With virutally unlimited access to cool water, I suppose its feasible to cool the superheated intake charge air with sea water. But how much space is available after the BOV and before the air meter to put in a water-to-air, charger-air cooler? Sounds HUGELY complex, if that is what they do. Anywhow, the Verado is unique in this class and should not be the focus of our discussion.
quote: I'm interested in how you make a 75hp and a 90hp E-TEC, (say) out of two mechanically identical motors, with only a change in ECM calibration. Specifics please. We've heard of simply injecting less fuel, but that doesn't account for or reduce the amount of air the motor is ingesting. -Peter
jharrell |
posted 08-11-2011 02:41 PM ET (US)
I believe supercharger boost control is done regularly now days, here is a replacement diagram for a 2005 Pontiac 3.8L booster controller showing the actuator and control solenoid: http://ww2.justanswer.com/uploads/goodwrench9124/ 2009-11-07_141159_supercharger_valve_1.gif These are typically bypass valves in the case of a roots, and if fully open will simply "freewheel" the supercharger not heating up anything dropping parasitic loss off. With centrifugal superchargers it's basically the same as a turbo BOV, still taking power off the engine. Some are simple on off, but they are doing modulated variable boost regulation as well Mercury mentions their system all over the place but I can't find much detail: http://www.mercurygovsales.com/technology/verado.php
quote: |
pcrussell50 |
posted 08-11-2011 03:38 PM ET (US)
Traditionally, BOV's are/were designed to vent the surge when the driver of a turbo motor making boost suddenly closes the throttle. Without a BOV, the inertia of all that air moving is (hard to imagine, but true), is very hard on equipment. No BOV I've heard of is rated for continuous duty, (always on), venting boost on a continuous basis. The wikipedia article on BOV's makes no mention of them being used as a continuous duty, "boost regulator": http://en.wikipedia.org/wiki/Blowoff_valve As for the Verado, maybe. They must have some kind of magnetic decoupling of the supercharger drive system that the ECM is in control of. But DAMN! What extraordinary, eye-watering complexity for an outboard motor. This cursory description of the Verado's variably boosted PD supercharging makes it look considerably more sophisticated than say, that for the Corvette ZR1, whose PD blower's BOV system is pretty much on or off. Makes you wonder if there will be ANY 2011 Verados still running in 35 years, like there are old Evinrude v4's still running today. My amazement at the apparent complexity of the Verado's supercharging system aside, I still don't know how (say) Evinrude does it between the (supposedly) mechanically identical 75 and 90 E-TEC. -Peter |
tedious |
posted 08-11-2011 03:57 PM ET (US)
If the motors are truly mechanically identical, and it's just a software change, the implementation mechanism has to be skipping fuel injection cycles - it's pretty simple logic, if you think about it. Tim |
knothead |
posted 08-11-2011 03:58 PM ET (US)
Just a guess Perhaps the exhaust system on the etec 75hp and 90 hp are tuned differently. Back when the etec first came out I remember reading about some type of exhaust valve that Bombardier had patiented for some of their other 2 cycle engines. Ahhh, my memory is old, I'm old, the information is old. regards---knothead |
pcrussell50 |
posted 08-11-2011 04:15 PM ET (US)
Tim, you may be onto something. With ordinary EFI, skipping firing would be a recipe for all kinds of trouble, from HUGE cylinder wear, to HUGE increase in emissions (if done through timing). But with DFI, you can avoid the dangerous cylinder washing that occurs when you have fuel not ignited, washing the lubricating oil off the cylinder walls... IF the E-TEC can selectively not fuel a cylinder, but still spray a jet of lubricant into it, this trouble would be avoided. Otherwise, each non-fire cycle will have the rings sliding up and down a dry cylinder wall. Sooo, if they can do this, the only thing left to worry about is the rough running you would get from each intentional misfire. In my 3 years as a boater, I have noticed that outboards tend to have very soft rubbery motor mounts that do an amazingly good job of smoothing out misfires from the perception of the people in the vessel. It seems extraordinarily inelegant, but certainly possible. Knot, you are suggesting small mechanical differences that add up to relatively large changes in performance. That is how they made the difference between the old Evinrude 9.9 and 15. The 15 had different carbs, a different exhaust manifold and tuning pipe, and made the rest of it's power difference at higher rpm. There were some other small mechanical differences, too. These of course means that the 9.9 and the 15 are NOT mechanically identical, even if the basic naked powerheads are identical. -Peter |
dgoodhue |
posted 08-11-2011 05:36 PM ET (US)
Jharrell is taking about a turbo charger wastegate is used to control boost. Bov/surge valves are for spikes caused from closing the throttle plates. |
tedious |
posted 08-11-2011 05:53 PM ET (US)
My logic is: The different motors have to be flowing the same amount of air, as they have the same displacement, the same RPM, and the same induction system. They can't be monkeying with the throttle butterfly opening; that would make the throttle control feel different, as most of these motors are still directly cable-controlled. The fuel / air mixture can't vary much without causing other problems, such as pre-ignition or smoke, which neither the 2 or 4-stroke variants of this technology exhibit. The rev-limiters already have the means to chop off injection / ingition cycles, so it's cheaper to use that and to reprogram it rather than adding something else. They can't just be cutting out the ignition cycles and flowing the fuel - even though it wouldn't cause fuel washing problems due to the separate DFI oiling, that would result in motors of different power using the same amount of fuel, and blowing unburned fuel out the exhaust. Neither of those things happen. So I am betting on skipping fuel injection cycles, on a rotating basis across cylinders. It probably does not matter whether they are skipping ignition cycles too, as it's not going explode clean air. Tim |
pcrussell50 |
posted 08-11-2011 06:11 PM ET (US)
Yebbut Dgood, a wastegate has no applicability to a belt-driven positive displacement supercharger. It works on exhaust gases: from the wikipedia article on wastegates: quote: They are a fabulous way to control boost in turbo systems, which is why PCM calibration changes, (chips, if you will), are so very effective in turbo cars/trucks. I'm pretty sure J was talking about Mercury's (apparently little understood, and neccessarily hugely complex), variable boost system they use in their Verado. Tim, I'm totally following you. You make a convincing argument. I think a system like that is ugly, (personal opinion), and would think that other engineers would too, but I won't swear you wrong. Over on the fast outboarders forums a discussion got going on the difference between the E-TEC 130 and the E-TEC 115HO. They appear to be identical, same weight, same external parts, same dual-path exhaust bypass. Some over there are claiming that the 130 produces a nominal 130hp, and that the 115HO produces a nominal 127'ish. Now this IS believeable from two different ECM calibrations, and is the going theory over there. They say the two different calibrations produce a different ramp or shape of the power delivery curve from each other. One even said that the 115HO felt quicker than the 130, even though he admitted it was more a seat of the pants sensation rather than verified by instrumentation. Note the 115HO (high output) is NOT the regular 115. It looks different and weighs more. -Peter |
jharrell |
posted 08-11-2011 10:42 PM ET (US)
I would say a variable duty cycle bypass valve on a positive displacement supercharger for regulating boost is not ugly IMO its as elegant as a waste gate on a turbo. Here is a description of how it works on a Cadillac , I am sure the verado is similar in operation: http://www.cadillacforums.com/forums/cadillac-forum/t-203271.html |
number9 |
posted 08-12-2011 12:06 AM ET (US)
quote: The amount of fuel is very easily controlled without affecting mixture or emissions. These are not limited like other motors that usually require a change to a larger venturi sized carburetor to boost power in these amounts. The ECU only has to open the throttle control valve more, vary time injector is open and adjust the timing if required. If the engine were to have electronically controlled variable vale timing that too could be controlled. |
number9 |
posted 08-12-2011 12:07 AM ET (US)
pcrussell50 |
posted 08-12-2011 04:34 AM ET (US)
Ok, "drive-by-wire" throttle can certainly behave the way you describe. But I thought I read somewhere here on CWW that E-TECs do not have ECM-controlled throttle blades. Throttling can certainly reduce airflow so that you can (and should), then introduce less fuel. BUT throttling is very bad for economy, because a throttled motor suffers from large "pumping" losses. IOW, it's harder to turn a motor that is throttled than one that is not, because of the restriction. That is in fact a secondary benefit of EGR systems in street cars. By introducing spent exahust gas back into the induction side, you not only cool the combustion, (producing less NOx), but you also displace some air/fuel mixture, so that the driver has to open the throttle more, to get the same amount of power he would have gotten had there been no EGR. This has the effect of actually improving fuel economy, because for any given speed, the throttle opening is greater, when EGR is flowing, and thus, the pumping losses are less. Not saying it isn't done the way you describe, because it certainly can be done that way, but having the lower powered motor of the two, running around at "full power", with a partially closed throttle is ugly and inelegant, (right, Jharrell :) -Peter |
pcrussell50 |
posted 08-12-2011 04:59 AM ET (US)
J, That post on the Caddy forum was lifted from another web site, two years earlier, when the similar engined ZR1 came out. My take on that system is that it is there for overboost protection under the circumstances listed, in which case, it cuts the boost to zero, or if intake air goes above 248degF, it goes to 62% DC, to cut boost down to a little more than half. IOW, mostly a safety valve rather than a full authority, full time, boost-curve-regulator. If I'm right, and I won't swear to it, then there should still be at least -some- small hardware differences between the 135hp Verado and the 200hp Verado. Anyway, we already agree that there is likely -some- ECM control of boost in the Verado, and regulation of boost by ECM could very well make the difference between two blown motors of different rated power. Whats still a mystery to me is, how is it done by ECM alone in the 75/90jp E-TECs? IF indeed it IS done strictly by ECM. What do you think of 'niner's theory, that the lower powered motors run around partly throttled, at "full power"? -Peter |
tedious |
posted 08-12-2011 08:02 AM ET (US)
While it's true that the amount of fuel is easily controlled, I think number9 has overlooked the fact that you can't just throw more fuel at a motor and expect it to create more power - that's because the fuel / air mixture is only going to burn properly in a relatively narrow range of concentrations. So modifying the fuel alone is not going to do it - you'd need to modify the air flow as well. With respect to the dropping injection / ignition cycles, it actually seems like an elegant solution to me. Consider the eTec 75 / 90 triples. To go from nominal 90 to nominal 75, you might want to drop 1 in 8 cycles (12.5%). The cylinder firing map would look like: 123123123123123123123123 which neatly rotates across the cylinders for even wear; since it's a very regular pattern, you wouldn't even notice the skipped cycle. I did check my F70 manual, and it does cut out both ignition and fuel injection to do the rev limiting - so the technology is there, they just have to change the software. Tim |
pcrussell50 |
posted 08-12-2011 12:31 PM ET (US)
Tim, in 'niner's defense, I don't think he was suggesting merely cutting fuel, without cutting the corresponding air to match. I think he said that on these modern motors, the throttle plate is controlled by the ECM, so in the case of the lower powered motor, the driver might "floor it", but the throttle will only open, say, 75%, and the ECM will fuel appropriately for that (reduced) amount of air. The motor would appear to run nicely, too. There are efficiency problems with this, that I went over a couple of posts ago. -Peter |
tedious |
posted 08-12-2011 01:35 PM ET (US)
Yes, my apologies to 9 if I misread. As far as I can tell, on the EFI motors with which I am familiar (Yamahas) the throttle plate is controlled mechanically - although I will have to look at my motors to make sure. But if it's a true "drive by wire" setup and the throttle butterfly is controlled by an actuator, then the easiest way to achieve the reduction would be to just back off the gain on the actuator. It would also suggest that a mechanical or electrical amplifier on the actuator would gain back the "lost" power - I have a hard time believing they'd make it that easy. Tim |
captbone |
posted 08-12-2011 02:39 PM ET (US)
With modern EFI engines, it does not matter if it is a mechanical throttle plate or electronically controlled. The ECM/PCM is controlling the timing, injector pulse width, and boost if equipped with a supercharger like the verado. The engines are using MAP sensor to judge how much air is flowing (similar to a mass air flow sensor) and adjust accordingly. While the fully fly by wire engines have an advance of being able to control the air intake, mechanical engines simple compensate with timing and fuel timing at a given point. |
pcrussell50 |
posted 08-12-2011 02:48 PM ET (US)
Yes, and sooo... back to square one. How do two mechanically identical outboards make 20% difference in horsepower to each other, just from different ECM calibrations? -Peter |
number9 |
posted 08-12-2011 05:11 PM ET (US)
I thought when venturi size was mentioned folks would understand that the throttle valve functions more like an air control valve on modern EFI engines. It ultimately controls the amount of power it can produce at a given rpm. It indirectly controls the amount of fuel and fuel/air mixture. This is done in different ways than a carburetor. On similar carb motors unless other mods such as larger carbs are installed the only way to get more power and keep the correct mixture is to increase rpm. It will suck more air through the fixed sized venturi with a corresponding increase of fuel. More power but over max rpm. I think most agree to substantially increase power output to an engine's maximum potential at a given rpm requires more fuel and air. That's how it's always been done and electronic/computer controls don't change physics. Easiest example to help explain would be motors with electronic throttle control like Verados. Same motors with different control units and produce different hp at the same rpm. The Verados are also motors that have supposed been confirmed to only require the ECU/ECM to upgrade power. Verado L6 & L4 + 33%. L4 75-90 + 20% same rpm and 75-115 + 53% max rpm + 400. On the lower hp models the ECU/ECM will under some power demand situations limit the amount of throttle valve travel to limit the amount of air entering the engine. Primarily this keeps the mixture correct but also is one part of the system that prevents reaching it's potential higher hp rating. Programming will keep the mixture correct up to a predetermined position. To prevent tampering with the throttle to get more air in an attempt to trick more power output the programming will prevent more fuel from being added even if it senses further opening and more air. It would eventually go into a safe mode or shut down. Obviously MAP, OAT and several other sensors are also sending info to the ECU/ECM and affect fuel flow and mixture. On the highest hp models the programming will allow further opening of the throttle which allows the additional air needed to increase power. The higher hp controller will increase the fuel flow and maintain mixture up to it's higher max power rating at the same rpm. Peter's original topic/inquiry was how can a simple box change and it's programming vary the hp output of two base motors by 25%. I don't profess to have all the answers or detailed knowledge of all these engine's controls, sensors and programming. Attempt to put into terms we understand of how a relatively simple engine is controlled by complex electrical/electronic components and a computer controlled processor. A Merc 75hp L4 53% power increase to 115hp is a result a timing change and +400rpm? |
pcrussell50 |
posted 08-12-2011 08:21 PM ET (US)
Niner, that was a good writeup, full of good remedial info for the casual reader. I understood you the first time. There is a rather significant efficiency issue when a power valve is only open part way. Take any yard tool you have, and pull the rope start with the throttle fully closed. Then do the same with the throttle fully open. It is much easier when the throttle is fully open. Now imagine how much harder it would be a 5000 rpm, with a rapidly moving column of air. The rampup in pumping loss is non-linear with rpm. Thus, while you could very easily keep power down by having only a partial throttle opening, and have the ECM fuel appropriately, you would be incurring significant pumping losses, and hurt fuel economy significantly. A quick google search on "pumping losses" would be a good read for most here. Again, not saying they don't do it the way you describe, but it's a pretty sucky way to do it, from an efficiency standpoint. -Peter |
