ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Whaler Performance Perfect PITCH and Non SLIP
Author | Topic: Perfect PITCH and Non SLIP |
posted 11-17-2011 12:14 AM ET (US)
There has long been a notion that a propeller must exhibit some attribute known as slip otherwise it could never work. A statement like that (or something similar) is often included in explanations of how propellers work. For example, consider this statement:
quote: Cf.: http://www.vicprop.com/propeller101.htm#3 This is actually one of the better explanations of why a propeller must have some SLIP in order to produce thrust. I've seen other explanations that simply say a propeller must have some SLIP to product thrust, but don't offer much explanation. The explanation of propeller pitch is generally likened to the rate of advance of a screw in a solid whose threads have the same pitch as the propeller blades. However, here is a definition that actually defines pitch in terms of advance when slip is zero:
quote: Again, from: http://www.vicprop.com/propeller101.htm#2 This is really a circular definition--perhaps fitting for a propeller. We can't determine the slip until we know the pitch. We define the pitch as the advance when there is no slip. How can we know one without the other? In the real world, we see this same problem when real world data of boat performance is used in calculations like those performed by the PROPELLER CALCULATOR. We can input propeller shaft speed and boat speed, and we can calculate pitch or slip, but the value we get for either one will depend on the value we use for the other. If we assume a propeller has a particular pitch, we can calculate the slip. However, we know that we must have some slip, and it must be a positive value. Yet when we use some propeller pitch numbers as marked by their manufacturers the slip values that result are very low or even negative. The obvious answer is the pitch value marked by the manufacturer must be incorrect--it must be too low, less than the actual pitch. |
posted 11-17-2011 12:25 AM ET (US)
The real purpose of the propeller is to propel the boat, and generally the faster the better. Instead of worrying about values of pitch and slip, we ought to simply look at boat speed. Consider two examples: With propeller A said to be of pitch 20, a boat goes 42-MPH with an engine speed of 5,700-RPM and a gear reduction of 1.86:1. This calculates to a slip of over 27-percent. With propeller B said to be of pitch 16, the same boat goes 42-MPH with an engine speed of 5,700-RPM and a gear reduction of 1.86:1. This calculates to a slip about 9-percent. Which propeller is better? Which propeller has its pitch marked more accurately? I think the answers are: --the two propeller are both producing the same thrust, because they both take the same horsepower from the motor and produce the same boat speed; and, --it is impossible to say which propeller has its pitch more accurately marked, because we really cannot measure the pitch or the slip from the test data. The propeller blade pitch perhaps can be measured from physical observation of the blades. However, we know that many modern propeller do not use blades with a constant pitch, and for those propellers we would have to develop some method to measure the overall pitch. |
Binkster |
posted 11-17-2011 08:01 AM ET (US)
For what it is worth here is a picture of my 105 Chrysler race motor exibiting 100% slip: the boat is tied down on the trailer, not going anywhere, the throttle is wide open but the engine is turning only about 3/4 of the normal RPM at wide open. The picture was shot for the sole purpose of proving the engine runs, when I sold it 1.5-years ago. http://s27.photobucket.com/albums/c191/floridaboy2053/ Chrysler%20105%20running/?action=view¤t=Chrysler105runningatramp. jpg |
posted 11-17-2011 09:27 AM ET (US)
The picture is not particularly valuable with regard to creating understanding of 100-percent slip. I think most people can grasp the concept without illustration. However, something else you said is very interesting and germane to this discussion.
quote: This is a very interesting observation. By inference, we can assume that the load on the engine was greater than it would be in the normal case, that is, when the boat is moving through the water. The engine speed is assumed to be proportional to the load. Under the normal load, the engine can accelerate to its normal full-throttle speed. In the test condition, with the boat held stationary, the engine must encounter a greater load, and it cannot accelerate to its usual speed. The load must be proportional to the amount of water being pushed aft from the propeller. Apparently when the propeller is not moving through the water it is trying to push, it pushes water aft more efficiently, and so its load become greater at a lower shaft speed. |
dg22 |
posted 11-17-2011 02:20 PM ET (US)
You wrote: With propeller A said to be of pitch 20, a boat goes 42-MPH with an engine speed of 5,700-RPM and a gear reduction of 1.86:1. This calculates to a slip of over 27-percent. With propeller B said to be of pitch 16, the same boat goes 42-MPH with an engine speed of 5,700-RPM and a gear reduction of 1.86:1. This calculates to a slip about 9-percent. One possibility is propeller A has too small diameter for the size of the boat, therefore slipping significantly more. If the diameters of these two propellers are the same and the pitch is somewhat accurate, propeller A is not the correct design for the setup. For example, if the engine is raised up quite a bit and the design of propeller A is not meant for running high, it will slip a lot. Anyhow, that would me my guess. |
posted 11-17-2011 08:10 PM ET (US)
If both propeller produce the same top speed, who cares what their pitch and slip values are when calculated in an inter-dependent manner? |
Binkster |
posted 11-17-2011 10:09 PM ET (US)
The way the motor was set up as to height on that race boat the center of the prop shaft was about 2" below the boat bottom, so that the top 1/4 of the prop is above the surface when on plane. I backed the boat down the ramp so the prop was in about the same position it would be when normally running on plane. Even with the top 1/4 of the prop breaking free of the water, the motor felt as if it was lugging and was turning about 4000, when normally it would run about 6500. the racing gearcase is 1:1 and the prop is a small 2 blade brass (forgot the pitch and dia.) The boat did not seem to have any push behind it either. Years ago I had a 24' Aquasport with twin 115 inline Mercs. I towed it with a 1/2 ton pickup and on the ramp we used when wet the rear tires of the truck would just spin and the truck could barely pull the rig up the ramp. But by running the engines which were deep in the water, I remember the engines would lug even when accelerated, but would easily push the truck up the ramp, so I figure there is a lot more power produced by normal props when they are fully submerged, but the lugging factor is still there. what all this means I don't know. Wait a sec., this all has to do with pitch. If suddenly the weight is increased less pitch needs to be used to maintain normal rpm. If you have 100% slip or close to it, you would need to just reduce the pitch to attain normal rpm. All this proves really nothing useful though, as far as prop slip. |
posted 11-17-2011 11:12 PM ET (US)
Binkster--you gave a good explanation of the effect of propeller immersion. When backed in on the trailer the propeller was probably much deeper in the water than when running on plane. I had not thought of that. |
jharrell |
posted 11-18-2011 01:06 AM ET (US)
There does seem to be a common way of measuring nominal pitch for propeller even with complex geometry: Propeller diameter X .70 X Pi X blade angle measured on chord line at .70 diameter = pitch. .70 or .75 diameter of the prop seems to be the "standard" point for measuring blade angle using a chord line from leading edge to trailing of the blade. More accurate pitch measurements can be made with a scanning apparatus, and there are in fact standards for propeller pitch measurements, at least for larger boats. There does seem to be some standards related to measuring propeller pitch, specifically ISO 484. http://www.ittcwiki.org/doku.php/structured_dictionary:propeller |
posted 11-18-2011 09:13 AM ET (US)
Perhaps we could have a (working) link to a description of an understandable method by which one could deduce the pitch of a typical outboard engine propeller by physical measurements of its blades. I did not find that information in any of the links above. It was interesting to see in one of the cited articles a mention that in the USA the manufacturing of propellers is generally not done in conformance to the ISO 484 standard. |
dg22 |
posted 11-18-2011 09:42 AM ET (US)
With my D classic hydroplane the prop shaft was level with the bottom of the boat so half the prop was breaking the surface. Until the boat was on plane the slip was huge but as soon as the boat would plane off you would feel the prop bite the water and off you go. I ran a 2 blade bronze which was very thin and sharp. So I guess the point I'm trying to make is that some props are designed to run with a lot of slip in the beginning not producing much thrust at all but once the boat gets on plane they start to bite and off you go like a bat out of hell. What I find puzzling about the example of Propeller A is it's almost like the prop never really started to bite the water, unless normal slip is about 27% with surface breaking props. |
dg22 |
posted 11-18-2011 10:43 AM ET (US)
I used the CW prop calculator to figure out the approx. slip of the prop used on my old d classic hyrdoplane and it was about 12 to 15%. |
Tom W Clark |
posted 11-18-2011 10:54 AM ET (US)
Propeller slip is not a goal by itself. There is no good or bad slip value or range of values for propellers in general. The goal is to find a propeller that allows the boat and motor to work together most efficiently to achieve whatever performance goal the boat owner has and that may be top speed but it is not necessarily top speed. Sometimes acceleration trumps the need for more top speed, for example. Calculating propeller slip is a very useful tool when trying to fit a propeller to your boat. Every model of propeller will have a range of slip that is typical. If you find, when testing a propeller, that the slip falls outside this normal range, either above or below it, it should be viewed as a notice that something is amiss. Calculating propeller slip is easy. The formula for calculating propeller slip is simple arithmetic. Engine speed is divided by gear ratio to get propeller RPM which is multiplied by pitch to get theoretical boat speed. Propeller slip is the difference between this speed and the actual boat speed expressed as a percentage. You can do this math long hand or with a pocket calculator but there is also ContinuousWave's handy Propeller Calculator that uses this same formula. http://continuouswave.com/cgi-bin/propcalc.pl The value of the slip calculations is no in any way affected by how a particular propeller's pitch is measured or if you make any adjustment to the input pitch, such as adding one inch. You can subtract one inch of pitch just as easily or add 3-1/2" if that makes you happy....so long as you are consistent and make that same adjustment with all your calculations. Remember, it is not the absolute value of slip that matters but the relative value. |
jharrell |
posted 11-18-2011 12:00 PM ET (US)
It seems most information on measuring propeller pitch without a scanning tool come from the model aircraft community, although the techniques would still work for boat propellers. Here is a link describing some approaches: |
jharrell |
posted 11-18-2011 01:02 PM ET (US)
Here is also a text describing pitch in more detail specifically related to slip and thrust in airplane propellers but also mentions marine propellers. It describe's three types of pitch for a propeller and relates to jimh's original post of why there must be some slip to produce thrust: Structural or nominal pitch: determined by the propellers physical dimensions. Effective or experimental pitch: The distance the propeller actually moves forward under certain condition in one revolution o the shaft. Dynamic pitch: The value of effective pitch that would produce zero thrust. Some pertinent quotes:
quote:
quote:
quote:
quote: So some key points here, are that: 1. Propellers stated pitch is usually the nominal pitch since this can be measured. THis is most likely how marine outboard propellers are rated by the manufacturer. 2. Slip can be the difference between effective pitch and nominal pitch or effective pitch and dynamic pitch. 3. Slip need only be positive to produce thrust when compared to dynamic pitch, however when compared to nominal pitch it may be negative. |
Tom W Clark |
posted 11-18-2011 01:40 PM ET (US)
The above citation is from The Air Propeller by Frederick Bedell and published in 1919. It is perfectly applicable to the discussion of outboard propellers today and illustrates well why nominal pitch is merely a starting point in describing how a given propeller may perform and why nominal pitch may vary so greatly between different designs and under different conditions. Mention of the ISO 484 is interesting too. Prop Scan is a proprietary propeller measuring tool that measures a propeller against the ISO 484 standards. http://www.props.com.au/inspection_system/default.htm#presentation I have never had a propeller measured using Prop Scan. I would like to do so some day. I did find one example of outboard propellers being measured by Prop Scan and interestingly enough they were 14-1/4" x 17" Stiletto Advantage propellers which have been much discussed recently. There has even been an accusation that Stiletto somehow, for some reason, gives their propellers an inaccurate nominal pitch. Here is what the owner if these propellers reported: "Prop Scan measured the pitch of my props at three different radii (.5, .7, & .9) of each blade. Both the design mean and measured mean were ~.9" less than the pitch size stamped on the wheel. Closest to the hub (.5) had the most pitch, followed by the far outside measurement (.9), with the middle measurement (.7) having the least amount of pitch." http://www.thehulltruth.com/boating-forum/ 119400-prop-ventilation-problem-cure.html In other words, these Stiletto propellers actually have less than 17 inches of pitch, not more. |
Binkster |
posted 11-18-2011 01:49 PM ET (US)
I don't think this is a cut and dry science. The boat it self,(bottom design, and weight) the water conditions, and the motor setup, both height and angle of attack have alot to do with it. That's why racers are always testing props and setups. I would contact Ron Hill on the forum Boat Racing Facts, He is and has been a prop builder for many years, and is the owner of the site. I would take what he has to say as gospel. What effects race boats also affects pleasure boats, but not to the extreme. |
Tohsgib |
posted 11-18-2011 02:06 PM ET (US)
Ron Hill IS the man. |
dg22 |
posted 11-18-2011 03:35 PM ET (US)
I borrowed a Ron Hill prop after I hit something and broke off a blade in the first heat--talk about prop slip. I thought I lost the entire prop. I agree, it would be neat to hear from someone who builds props like Ron Hill. |
Binkster |
posted 11-18-2011 11:02 PM ET (US)
Here is a link to his forum Boat Racing Facts Ask him yourself. http://www.boatracingfacts.com/forums/index.php |
posted 11-19-2011 10:40 AM ET (US)
Re the PropScan device: As I recall, a few years ago at a boat show there was a fellow with a exhibit booth from a local propeller shop. He had a PropScan. I asked him about doing a scan on an outboard propeller, but he was not too keen on the idea. He said he didn't work on outboard propellers. I suspect he figured the price he was charging for the scan would be too high compared to the cost of an outboard propeller. I think the cost of the scan was in the $100 to $200 range, as best as I can recall. The report of the Stiletto propeller measured pitch being less than the marked pitch is quite interesting. As Tom notes, an accusation was made that the pitch marked on the Stiletto propellers was under the real or effective pitch, and now we hear an actual measurement shows the marked pitch was greater than the measured pitch. Re the influence of the boat and the set-up on the propeller: the boat cannot influence the measured pitch of the propeller, but the boat can influence the slip. If the boat is hard to push, there will be more slip. |
davej14 |
posted 11-19-2011 10:08 PM ET (US)
Is the thrust a prop develops simply a function of the water column it can move or is there a component of lift similar to an airplane wing ? |
jharrell |
posted 11-20-2011 11:51 AM ET (US)
Lift and Thrust are the same force the only difference being the direction it is applied relative to the vehicle. Think of an airplane propeller or a helicopter rotor or a rocket being launched straight up, what is the difference between lift and thrust? If the case of a propeller the force is generated by a foil moving through a liquid or gas and is primarily related angle of attack which changes the momentum of the medium, which would be the water column you reference for a marine propeller. The main difference between air and water is the compressibility of the medium, however marine propellers aren't run through a perfectly in-compressible liquid because entrained air in the water, in fact in case of a surface piercing marine prop the medium is closer to 50/50 air/water and they start to function more like airplane props. |
cooper1958nc |
posted 11-20-2011 02:53 PM ET (US)
Well, not exactly. Few airplane propellers operate when compressibility is an issue. Tip speeds can be transonic even on small airplanes, but for all practical purposes the equations describing airplane propellers assume incompressible flow. Here is a word about "slip." Its an unfortunate word, because it assumes something is slipping. Lets start on land. A tire develops frictional force on the road. The reason it can do so is because the road is connected to the earth. A road has, essentially infinite viscosity. Momentum is always conserved. Forces from the tire are transmitted to the earth. When you accelerate your car you make a momentum change of the earth, equal and opposite to the momentum change of the car. Now lets go to sea. The water, unline the asphalt, is not "connected" to anything, or isn't connected much, anyway. To be sure, water has nonzero viscosity. That means when you pull on the water like with an oar, the water is attached to more water, and so on, until the force acts on the bottom of the lake. Well, that's true, but only for certain masses and speeds is it measurable. If you are a tiny bug, water viscosity is a factor. If you are a boat going 25 mph, water viscosity is pretty much irrelevant. Thus the propeller has no way to "hook up" with the lake bottom and thus change the momentum of the earth. A propeller is not a "screw" because it operates where viscosity effects are tiny. It's like a rocket in space, really. So how to generate force? Newton's third law comes to the rescue. It says you get force from momentum change, so you eject water sternward, chaning its momentum, and you get force from that. Its all about pumping water backward. "Slip" is just an artificial comparison of your speed and the speed of the water column being pumped sternward. Free propellers create momentum change through lift, and at a given boat speed relative to the propeller speed, the angle of attack becomes zero and thus the momentum change is zero. However, If I enclose a propeller in the boat and feed it enough water (a jet), there is no reason the boat can't go faster than the water stream. |
davej14 |
posted 11-21-2011 11:50 AM ET (US)
At the point where the angle of attack is zero or near zero doesn't the shape of the prop still have the potential to create "lift" (in this case thrust)due to a pressure difference caused by the shape of the blades? The shape of an airfoil, for example a sail, creates lift because the higher speed of air over the convex surface has significantly lower pressure than the lower speed air flow on the opposite side. This presumes laminar flow or else we would have a stall. I'm thinking that there may be a component of lift to the thrust generated by a prop, but I'm not proficient enough in fluid dynamics to know if this is a possibility. Perhaps things are always turbulent enough that thrust is generated purely by the amount of water that is displaced. What do you think? |
Tom W Clark |
posted 11-21-2011 12:15 PM ET (US)
There is no question but that the foil shape of a propeller blade creates lift/thrust that is not just the result of the angle of attack. |
jharrell |
posted 11-21-2011 01:10 PM ET (US)
The common description of lift generated over an airfoil through Bernoulli's principle (pressure differences) has been shown to be innaccurate. If this where the case then airplanes would not be able to fly inverted. In order for a plane to maintain level flight elevator trim must be used to change the angle of attack of the main wings to create the proper amount of lift for a given speed, all pilots know this. The better explanation for how a foil creates lift or thrust even if it's measured angle of attack through it's chord line is zero, is the shape of the foil is asymmetric, usually curved on one side and flat on the other. The curve on the top changes what's known as the effective the effective angle of attack. This occurs because of the Coandă effect. The foil of a outboard marine propeller is very thin (unlike an airplane wing), so even if it had some asymmetry the effect would be extremely weak. Either way the lift or thrust generated by a foil is directly related to the effective angle of attack alone. |
cooper1958nc |
posted 11-21-2011 04:17 PM ET (US)
The conventional lift equation is L = 1/2 rho v^2 A Cd(alpha) whhere rho is density, v is speed through the medium, Cd is the coefficient of lift, A is the area (usually the wing area, or it can be the frontal area projection), alpha is the angle of attack. Since alpha is dimensionless, (degrees or radians) it is not multiplied per se but is a function argument to Cd. Nonetheless Cd(alpha) is considered to have a linear range, intersecting zero lift and zero alpha. So yes the blade shape plays a role, but the role would be to influence the shape and steepness of the lift curve. Regardless, there is some point of zero lift, defined by that as zero alpha. The Bernoulli issue is often debated and discussed. Many physical phenomena are understandable in more than one way. Bernoulli's principle can be thought of as an explanation why some wing shapes are very efficient in accelerating air or water downward or sternward. Flat plates are less efficient, but they do create some lift if held in the correct angle. Wings that use Bernoulli effect create more momentum change for a given drag. Airplanes with flat plate wings have a hard time flying, although some can manage. Why marine propellers do not appear to have classic wing shapes, i.e. greater radii of curvature on the leading or upper surface, must be a design compromise of their small size and the consequent need to make rapid blade incidence changes from hub to tip to try and maintain a constant pitch along a given radius. I honestly don't have a better explanation; maybe someone does. |
cooper1958nc |
posted 11-21-2011 04:28 PM ET (US)
Sorry I did not respond to this question:' "Is the thrust a prop develops simply a function of the water column it can move or is there a component of lift similar to an airplane wing ?" Yes and yes. Both thrust of the propeller and lift of the wing are dependent upon accelerating air or water downward or sternward. For very small and slow flying things, like birds possibly, viscous forces in air may contribute to lift, so the total lift would not be entirely newtonian, i.e. dependent on a momentum change of the air downward. Viscosity effects are important at very low Reynolds' numbers (a product of size and speed). Inertial effects, i.e. acceleration of the water or air column, dominate in the world of powerboats and airplanes. |
cooper1958nc |
posted 11-21-2011 04:47 PM ET (US)
One more point. In the initial post, an ambiguity about slip was noted. Slip is two different quantities: 1. The difference between the speed of the water column accelerated backward and the theoretical pitch of the propeller times rpm. 2. The difference between the speed of the water column and the boat speed. These are two different things entirely. Slip #1 is dependent on the propeller design. Ideally it would be zero. A perfect propeller would push a water column at a speed equal to its pitch times RPM. Slip #2 has nothing to do with the propeller and everything to do with the boat. Because we don't usually measure water column speed (we measure boat speed, propeller pitch and RPM), we combine slip #1 with slip #2 and get 3. The difference between the theoretical pitch times RPM and the boat speed. Confusing as can be, because two entirely different processes are responsible. |
OutrageMan |
posted 11-22-2011 06:52 AM ET (US)
Please excuse what might be a silly question. Does the design of the "torpedo" or other parts of the lower unit affect slip? In other words, does the design of the lower unit and the flow of water around it before it gets to the prop affect slip. If so, how do we take that into consideration? Thanks, B- |
Richard Quinlivan |
posted 11-22-2011 09:48 AM ET (US)
Propeller Slip results in the generation of propeller thrust. Thrust accelerates the boat until boat drag increases to balance the thrust. Lower Unit effects cause drag which is part of the total boat drag. Therefore Lower Unit effects play into slip. Dick |
OutrageMan |
posted 11-23-2011 07:29 AM ET (US)
I guess I was wondering what effect the lower unit would have on the disturbance of the water flowing to the prop and its correlation to slip. For example, (assuming I read this correctly) if the lower unit passed more air and/or turbulent water to the prop would that increase slip? Also, with all that in mind, and what has been written in this thread, how would the design of systems like the Volvo IPS drive and conversely the Arneson Surface Drive have on slip. Thanks! B- |
posted 11-23-2011 07:39 AM ET (US)
The VOLVO IPS drive system is significantly different from outboard engines due to the arrangement of the propeller ahead of the gear case. I believe the reason for the IPS arrangement is to have the propeller interact with undisturbed water. I note that on airplanes the more common arrangement of the propeller is for it to be in front of the engine and the engine nacelle, whereas on boats with outboard engines or stern drives the propeller is aft of the gear case. There are a few planes with rear-facing propellers, which I believe are referred to as pusher-propellers, but they seem to be a very small minority of propeller-driven planes. Some ships have had forward facing propellers. The ice breaker MACKINAW (the older ship, now retired) had a forward facing propeller. It was not typically used for regular propulsion. When ice breaking the forward facing propeller could be used to create a powerful thrust current along the hull to help free the ship from ice, and it could also be used to make sternway if stuck in ice. |
dg22 |
posted 11-23-2011 09:18 AM ET (US)
The only downside I see to the Volvo IPS drive is that it puts the propellers closer to the boat but for the type of boats it is designed for, it is a very smart design. I would imagine with dual props and with the props in front of the gearcaes, slip must be minimum. |
Binkster |
posted 11-23-2011 09:40 PM ET (US)
An outboard with a forward facing prop is called tractor drive. I saw one once and an AOMCI meet. http://articles.orlandosentinel.com/1995-11-02/topic/ 9511010095_1_outboard-propeller-oil-injection-bimini-top |
posted 11-23-2011 11:10 PM ET (US)
With all respect due to the author Larry Hutt of the Orlando Sentinel newspaper article from 16 years ago, I don't think the term "tractor drive" is widely used to describe forward facing propellers on outboard engines. I have heard the term "tractor drive" used to describe certain tug boat or vessel assist tug propulsion systems, also called Z-drives or azimuth drives, a reference (I believe) to a propeller on a pod which can be rotated in any direction, 360-degrees relative to the keel centerline. Also there seems to be a tendency to refer to the Z-drive as a tractor drive when the pod is located in the forward part of the hull instead of at the conventional stern location. Compare at: http://www.towingsolutionsinc.com/technology-escort_tugs.html |
Binkster |
posted 11-24-2011 08:38 AM ET (US)
The term "tractor drive" lower units for outboards is not a term that was made up by the author of that article in the Orlando Sentinel. Back in the 1920's to the 1930's a few manufactures of racing outboard motors developed a gear case where the propeller was facing forward, in front of the gearcase. These were commonly called tractor lower units. Like I mentioned I have only seen one at a AOMCI meet, but here are pictures of several restored ones. http://www.quincylooperracing.us/subpage26.html The term might mean the same to some commercial boats too, who knows, tractor might mean alot of things, but I was referring to outboards. The literal meaning of the word "tractor"--I looked this up--is "pulling." |
posted 11-25-2011 09:50 AM ET (US)
quote: No one said that the author made up that term. I said it was not now in common use to mean an outboard engine with a forward facing propeller.
quote: Please give your source. When I look up tractor, I do not see it defined as "pulling." Thanks. |
Binkster |
posted 11-25-2011 12:43 PM ET (US)
THE FREE ONLINE DICIONARY tractor - Traction and tractor trace back to Latin tractus, "drawing, pulling," and trahere, "draw, pull." |
cooper1958nc |
posted 12-04-2011 04:36 PM ET (US)
Airplane propellers mounted in front are called tractor propellers; in back they are called "pushers." Pushers avoid the drag of having the airframe in the slipstream. However the incoming air is turbulent. The effects may be close to a wash. Every so often a new pusher design promising increased efficiency and speed is offered. Few have gained general acceptance. Problems with pushers (in airplanes) include difficulty in finding a place to discharge exhaust, compromised engine cooling, ground clearance issues, and for singles balance problems when the engine is located in back. (None of these problems exists in boats.) There were some early outdrives and I think an outboard or two that used tractor props. None were successful, though probably for other reasons. |
