posted 07-18-2005 07:25 PM ET (US) Is there a fuse on an outboard motor? On a 1999 Johnson 115-HP?
posted 07-18-2005 08:19 PM ET (US)
Yes, typically there is a fuse under the cowling of most outboard motors which protects against over-current in branch circuits from the main battery cable.
LHG
posted 07-19-2005 03:08 PM ET (US)
Mercury puts a 20 amp fuse on both the starter circuit and the power trim. Aways carry a spare fuse this size on board.
bsmotril
posted 07-21-2005 07:04 PM ET (US)
On an Opti, you'll find several more 20 amp fuses under the cowl for the injectors and ECU too. BillS
Chuck Tribolet
posted 07-21-2005 10:36 PM ET (US)
Pull the cover off and look. On my 96ish 90 HP Evinrude (same basic motor), it's real obvious with the cover off, and there's even a spare fuse.
