posted 08-03-2005 09:19 AM ET (US)
Alternator noise and ignition noise are two separate problems. You must use different techniques to reduce the interference.Alternator noise is a audible whine whose pitch varies with engine speed, roughly from about 1,000-HZ and higher. This type of noise is conveyed by the power supply connections. It can be reduced by use of a filter in the power leads between the radio and the battery.
Ignition noise is a staccato popping noise. It sounds like a rough modulation of the signal. The rate of the popping also varies with engine speed. This type of interference is generally conveyed by radio propagation. In some cases it may also be conveyed by the power line. It cannot be filtered out using power line filter techniques. It cannot be filtered out using antenna filters. The only way to suppress this interference is to eliminate it at its source.
To determine the source of the interference, disconnect the antenna from the radio and open the squelch. If the noise stop, it was probably being conveyed by the antenna.
The source of most ignition noise is from the spark plug sparking itself. If the spark plugs do not contain ignition noise suppressors, the noise will radiate from the spark plug wires, too. The first step in reducing this noise is to use spark plugs which contain radio frequency suppressors.
Spark plugs intended to suppress radio frequency interference (RFI) are generally made in two styles, resistive and inductive. Resistive plugs contain a small series resistance in the plug body to suppress RFI. The resistance also affects the spark slightly, tending to reduce it. Inductive plugs have a small coil or inductor in the plug body which is more effective at suppressing RFI. Inductive plugs do not affect the spark as much.
The spark plug gap affects the generation of RFI. As the gap increases, the amount of RFI increases. Check your spark plug gap. On some OMC engines the specified spark plug gap has been reduced to 0.030-inch from the original 0.040-inch dimension in part because of a desire to reduce RFI from the ignition system.
In general, older motors were designed with not a moment's concern for RFI and most small boats did not have a great deal of radio or electronic equipment. Modern motors have a great deal of electronics under their cowling and thus are designed to suppress RFI from their ignition systems.
If you motor is an old motor with a very hot spark, you may not be able to suppress the RFI to the point of making AM radio reception interference free. The AM modulation technique is especially prone to such interference. This vulnerability is inherent and cannot be avoided.
