Kelly |
posted 08-09-2005 05:25 PM ET (US)
If you have a battery isolator, do you need a battery switch, except maybe an on/off switch for electronics and other things that might drain the battery? Also, if you have a battery isolator, can you have a deep cycle and starting battery connected to the same isolator? Is the isolator able to use the starting battery for starting, or does it just use which ever battery has the greatest charge? Is the isolator kind of like a smart automatic battery switch? Kelly
