ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Small Boat Electrical SONAR: Humminbird 987
Author | Topic: SONAR: Humminbird 987 |
highanddry |
posted 08-25-2005 04:33 AM ET (US)
Anyone with direct experience with the Humminbird 987 side scan sonar unit please reply: I would be using Hummingbird 987 mostly for finding dive locations in both salt and fresh water. How well does it work on small Whalers? Thanks in advance. |
Chuck Tribolet |
posted 08-25-2005 11:04 AM ET (US)
No info, but I've been drooling over it. Note that max depth for the SS is 100', and the SS doesn't image the area under the boat.
highanddry |
posted 08-25-2005 01:22 PM ET (US)
Yes, I noticed the info you mention, 100 feet and not directly under the boat but it also has a conventional dual frequency sonar for use under the boat. I figure the depth limit of 100 feet would cover most dive uses. I see it used in conjunction with GPS to locate the general site, standoff with the side scan and locate the wreck or reef etc and then move in with the conventional sonar and set anchor. You could also cruise along a jetty or reef and view it to locate the best dive areas. I figure the depth limit of 100 feet might be pushing it in salt water. I figure 80-100 feet but then that covers most Gulf diving and fresh water lake diving. |
handn |
posted 08-26-2005 10:08 AM ET (US)
Consider the Interphase Twin scope. It is a moderately priced forward and side seeking sonor. I have one to look for navigation hazards in the poorly charted Sea of Cortez. It works well to pick up big objects. The color model is about $2000 and black and white model is less. You have your choice of thru hull or transom mounted transducers. |
posted 08-26-2005 08:25 PM ET (US)
[Corrected the spelling of the product manufacturer. When asking about brand name products it is important to get the name of the manufacturer correct.] |
posted 08-26-2005 08:40 PM ET (US)
For information about the HUMMINBIRD 987 see: http://www.humminbird.com/products.asp?ID=512 I do not see anything about a Boston Whaler boat which would prevent this SONAR device from operating. I assume it uses a transom mounted transducer. |
posted 08-26-2005 08:48 PM ET (US)
This box costs $2,000. That is more than the hull of most small Whalers is worth! |
Chuck Tribolet |
posted 08-26-2005 11:05 PM ET (US)
Deep discount street price, with transducer, is about $1825. for the version that includes GPS.
highanddry |
posted 08-28-2005 02:15 AM ET (US)
Other boxes recommended on this board cost in that range. I was hoping somone would have practical experince with it. Frankly, I think it is beyond my budget. I could buy one, sure, but do I want to put that much money in one box. It would have to be a Jim Dandy thus my wondering about just how well it works. Can you see underwater ledges, reefs, rocks in say 80 feet of salt water? Something like three to 10 foot ledges? The unit I have is the Lowrance 332 or is it 337. It is color, dual frequency, medium size screen, under 800 dollars or quite a bit less, uses Navionics charts etc. It will be several more years before we begin to see side scan units in lower price ranges and smaller sizes. The Nantucket has a roomy console but I can see it getting crowded with a radio, maybe a second low end sonar unit, my handheld Magellon perched on a swivel mount on the top and all that. |
Chuck Tribolet |
posted 09-30-2005 02:29 PM ET (US)
Anybody ever find out any more about this unit? I did google up someone who had one on Lake Lanier and liked I'm interested in the 60-100' range in salt water.
highanddry |
posted 10-02-2005 09:59 PM ET (US)
Chuck, what little else I have found out about this unit is that it probably has about an 80 foot depth limit in saltwater. You have to remeber it is sending a high frequency sonar out on both or one side depending on the mode. Thus in the side looking mode it is trying to shoot through quite a bit of water--horozontally as well as vertical. Iimagine quite a bit more power wold be needed to reach deeper depths. Still, I can see a lot of use for this diving and it does have a conventional vertical mode and a huge screen. |
Chuck Tribolet |
posted 10-03-2005 02:57 PM ET (US)
Thanks, ;-( There's a big difference between 80' and 100' for diving: And BTW, I'm not interested in fish, just structure.
srax6 |
posted 10-13-2005 07:30 AM ET (US)
I have the Humminbird 987 side scan unit on my 22 outrage. Unfortunately this summer was tight with work and other commitments so I did not get to "search" with the unit as much as I wanted to, probably only 8 - 10 hours of dedicated time. I will say that from my experience (salt water, scuba and fishing) if you are looking for wrecks they had better be big at a depth of 60 feet or greater. If you are looking for structure to dive or fish it is definitely a great aid. The only wreck that I found was a "new" boat in 25 feet of water. It appeared on the screen even better than the Humminbird examples on their website. The unit does work better in shallow water where you can decrease the left and right scan fields to get more definition. Overall I am happy with the purchase, the chartplotter is much better than the old raytheon version i had, and the standard fish finder works well too. Feel free to ask more questions about your particular application, finding Spanish galleons or rocks to fish, and I will try to answer as best I can. Steve |
posted 10-13-2005 11:13 PM ET (US)
Side-scan SONAR images can be quite amazing. When this image was published of the EDMUND FITZGERALD some people thought it was a photograph taken by a diver: |
srax6 |
posted 11-02-2005 08:25 PM ET (US)
Chuck, Feel free to ask any questions about the unit and I will try to answer. Saw you post in another thread about the 987 and thought I would revive this one to notify you, I think you missed my previous post. Steve |
Chuck Tribolet |
posted 11-03-2005 12:31 AM ET (US)
Your description of it says it wouldn't meet my needs. There's not a lot in Monterey in less than 60', and the specific area I'm interested in is 70-100+. What I really need to do is see one, on structure I know and
srax6 |
posted 11-03-2005 08:35 AM ET (US)
I guess it depends on what "structure" your looking for. Wrecks will need to be modern and large(100 ft +?), but ledges do show up well at greater depths. I was primarily looking in 40-60 feet for smaller targets (older wrecks) in a rocky area. I think the difficulty that I had was that the unit was so good at reading the bottom that every rock pile looked like it could be ballast. You do need to see one in your area to really decide but I would think that if you are looking for wrecks at 70-100ft depth you will be unhappy, but if you are looking for structure like ledges, drop offs etc. you will be very happy. Good luck. Steve |
Larry |
posted 11-07-2005 01:30 PM ET (US)
Has anyone been able to pick out pilings and tree stumps in water up to 25 feet? |
srax6 |
posted 11-08-2005 03:41 PM ET (US)
Larry, Pilings, rocks, and other features look better in person than on the website. I am in saltwater so not a lot of stumps, but in 25 or so feet of water when I passed a buoy I could see the block anchoring it and the chain coming off the block to the buoy. Pilings show up clear as day, lobster traps, rocks...you name it. At that depth the unit works better than advertised. |
Larry |
posted 11-09-2005 10:59 AM ET (US)
WOW! (Now to find the cash) |
bhampton |
posted 11-13-2005 10:12 AM ET (US)
hey guys I am new here but I am an owner of a 987c I currantly have myine mounted on my 16ft zodak with a 50hp outboard. I took it out in the columbia river and played with the buttons and knobs:) I know nothing about the bottom of the river here the boat launch was close. the water runs about 4mph with lots of boils miny whirlpools ect. the water is about 40 feet deep. it was easy to get the 987 to start producing images right away. the Humminbird sight shows sidescans with a 100-150 range to the side of the boat this does give very good performance. for what ever range you choose you set a window of time for each ping(each line on the scan) I think max range is like 350feet to the side of the boat now dont quote me on this but I think that is a round trip of about 1/8 of a second or only 8lines per second. also at that range the angle that the sonar strikes the bottom is very low giving a weeker return, and the signal strength will also be weeker from shear distance, the beems reaching out to 350ft to each side of the boat makes it very very sensitive to any minor changes in heading, and lastly the beem will also spread out a 1 degree angle extended out to 350(it is accually further than that to the bottom) will be in the multi foot range at least. Ith looks like I have painted a pretty crudy picture but that is not the case at all. most side scan sonars rin 6-10,000 and they use a towed fish to overcome the problems I have just talked about. as far as scanning under the boat the sonar sincs out a ping then starts drawing a line on the screen this line starts at the transducer and goes down through the water(so if you have a setting of 100 feet to the side then the water will extend halfway accrost your scan)then it hits the bottom and starts to draw a profile of the bottom tell it gets to 100feet then starts over it is all based on time not distance. for scanning deeper water the limitation is the way information is displayed lets say that your using the 150 foot setting and your scanning a flat bottom of 100feet deep what you will get is a scan of the bottom only 50 feet wide that starts 100 feet to the side of your boat and extends to 150 feet some people may not feel that is usefull I say BAH! it is simply the best sidescan sonar for the price. Transom mount, some say that the lower unit blocks one of the side beems or reduces the performance on that side so plan on scanning mainly on one side this gives better performance, the screen size is constant weather your looking 200feet to the left only or weather your looking 200 feet to both sides if you want to see the details use one side. |
bhampton |
posted 11-17-2005 11:46 PM ET (US)
sorry about the spelling it was a late night. I did a little test. on the river in 55feet of water i ret the sidescan at 360 feet(max range) I could see bottom returns pretty good to 180 feet and weeker ones to 200 feet this is using the 455Khz side scan. the math works out that a beam traveling out to 200feet to a depth of 55feet is accually traveling 207.4246851 feet :) a setting of 150 feet with a depth of 150 feet would work out to 212 I think this represents near max performance for the 455Khz freq. |
RJG |
posted 11-22-2005 05:36 PM ET (US)
I am going to ask Santa to bring me one of these:) |
bhampton |
posted 12-03-2005 10:36 PM ET (US)
here are a few 987 sidescans for you to lok at the site is very simple I'll work on that. enjoy brad http://webpages.charter.net/bhamptonkc7mrp/ |
Chuck Tribolet |
posted 12-03-2005 11:08 PM ET (US)
http://webpages.charter.net/bhamptonkc7mrp/ Chuck |
srax6 |
posted 12-05-2005 03:50 PM ET (US)
Brad, how did you get the images off the unit? I think I may need to re-read the manual. Thanks - Steve |
bhampton |
posted 12-06-2005 12:57 AM ET (US)
the images are stored on an SD chip I have a thing that looks like a mouse that plugs into the USB port it has slots in the front for the differant memory ships and sticks. once I incert the SD chip the computer sees it just like another hard drive. the images are 1.2meg bitmaps |
srax6 |
posted 12-06-2005 07:43 AM ET (US)
Brad, I may have to take this offline but, the slots where the chart chips go can also be used to store images? What exactly do I need to buy to do this, and how to you get the unit to store specific images when you want it to? I am completely in the dark on this one so any help would be appreciated. Thanks - Steve |
bhampton |
posted 12-06-2005 01:40 PM ET (US)
No Problem, assuming you have an SD chip installed, I use slot #2 the bottom one for capture.you need to have it set up for advances user which is the right most pull down menu. then one of the advanced options is screen capture you want that on. now when ever you see something on your screen you want to save just hit button MARK it takes about 10 seconds to save the screen and what you see on the screen is what you get, Brad, #1. For the chartplotter and fishfinder you can select between white, blue or black background. Black will help dim the screen for night time viewing. You make this adjustment by pressing the power button quickly one time. It will bring up two menus ( light and background). In the background menu you can set it to either white, black or blue. Again I believe the black setting will help for nighttime. You can also go into the light menu and adjust the backlight brightness to dim the screen further, if necessary, for night time viewing. #2. If I understand #2 correctly you are looking for a features to allow you to create a continuous scrolling capture like sonar recording. At this time we aren’t able to do this. I have used a 256 SD card with no problems. I haven’t tried a 512 but I think it would work fine. The unit will not switch between the two different cards. You would need to use up one and then install the other. Thanks again and let me know if you have any questions. |
d_kingsr |
posted 01-27-2006 08:19 AM ET (US)
I saw mention that the 987 would scan deeper than the 100 foot max by using a shorter range. Is that so? My need would be mostly in the 75' to 150' deep range and I would love to know I might be able to get some use deeper than its rated max depth. My targets would be wrecks with 5'+ of profile and 50'+ of length. Could I expect anything beyond the rated limits? |
daddyhooch |
posted 01-28-2006 01:08 PM ET (US)
Has anyone built a towfish for the 987c transducer to access deeper water. I fish and dive in the Gulf of Mexico and was concerned that the movement of the boat would make it difficult to find ledges in water 50'-100'. |
highanddry |
posted 02-20-2006 02:52 AM ET (US)
Leaving the side scan issue aside, how does it perform as a GPS and standard mode sonar/finder? J |
bhampton |
posted 03-10-2006 08:54 PM ET (US)
987 GPS/bottom sounder. I have not worked to much with the built in GPS on the 987. The [digital chart cartography] available [for] central Washington is very poor, so it is not much more than a plotter for me. The bottom sounder looks to be first rate. Color. Maximum depth like 2500 feet. So far I have only used it to 200 feet fresh water, and it seems to work ok. The maximum depth on side scan. On the 466-kHz side scan, the beam travels out at a 45° angle. If the bottom is 100-feet down it will not strike the bottom until it is also 100 feet to the side of the boat. If you have the side scan range set at 100 feet all you will see is the water. On a flat bottom, [a depth sounding of] 160-feet is the greatest I have tried the side scan<. I had it set on 360-left-right. You lose a bit scanning such a large area with a small screen. The 262 did provide much better punch, but I am looking at 200-feet being the maximum you get a useable return off a flat bottom. There were no targets. I expect they would show up better. I am using a transom clamp-type mount where there is a clamp at the top end and a transducer mount at the bottom. This fixture is 36 inches down from the top of the transom. This allows me to transplant the system from boat to boat, including friends that are going trolling for the day (uber sidescan speed) and the police boat. |
PStang |
posted 05-16-2006 05:42 AM ET (US)
A buddy of mine has one of these and can't read the hotspot maps, any ideas? Could it be a software upgrade already? I know in my LOWRANCE or a friend's unit wouldn't recognize the HotSpot map/chip until the firmware was updated. Any ideas? |
srax6 |
posted 05-16-2006 03:10 PM ET (US)
I have a chip (Navionics I think) for my specific area so I don't have any experience with the hotspot function. I will check out the manual tonight. Steve |
Sean7531 |
posted 05-16-2006 11:59 PM ET (US)
I'm actually [planning] to give [a HUMMINBIRD side-image SONAR] a try myself for the upcoming fishing season. I'll let you know what I think. |
highanddry |
posted 05-17-2006 04:31 AM ET (US)
I am itching to buy one but cannot figure out even after reading the manual if it has a built in or provided GPS reciever/antenna with the unit? The manual says it supports Navionics Hot Maps and Navionics Gold maps. I am beginning to think you have to hook it up to a stand alone GPS such as a Sport Track Magelleon or similar to get the GPS and cartography function and use the navionics maps. Is this correct? |
srax6 |
posted 05-17-2006 07:23 AM ET (US)
The unit comes with a GPS receiver. You do need to buy a chip for your area, I think they are $200 or so. |
Sean7531 |
posted 05-17-2006 03:42 PM ET (US)
DaveRead |
posted 05-26-2006 11:41 PM ET (US)
Just received my 987 a couple weeks ago. I've been out a couple times since I got it installed it works great and I love it. Works great so far. I will also mention the outfit I got it from due to the exceptional service I got from them Scuba Steve's Marine Outlet http://www.scubasteve.biz. The prices were as good or better than anywhere else I found. What they did better than anyone else was communicated answered my emails promptly and even returned my phone call. I knew I could trust them the way they handled customer service. Had the unit overnight for only $15.00 on a yellow DHL truck. |
highanddry |
posted 05-27-2006 01:48 PM ET (US)
Dave, have you used it in saltwater and at what depths. My main use would be scouting dive locations in saltwater between 60 and 100 feet. Of course it would also be used for fishing duty and other such things. How does the Navigation functions work especially with the chart chips? Also, several emails to Humminbird were never answered---not a good sign. |
highanddry |
posted 06-25-2006 02:11 AM ET (US)
Finally decided to go ahead and purchase a 987 and currently am working through the installation. Unit looks fantasic and I will be able to salavage the hole from the Lowrance in my console panel. The screen is huge and despite my fears the transducer is not nearly as large as I had been led to think. All in all it appears to be a promising installation. It will likely be several weeks before I can put it to work and see what it can do for real. |
highanddry |
posted 06-25-2006 03:34 AM ET (US)
videorov |
posted 07-20-2006 09:04 PM ET (US)
I am thinking of buying one of the 987 units, too. I wonder if anyone has seen the a transom mount system that lets you slide your transducer up out of the way when you load it on the trailer? I did see such a thing in a flyer. I would like to find that product again because that would be the way I would mount my transducer for the Humminbird on my Seachaser Cat230. |
bhampton |
posted 07-22-2006 12:30 PM ET (US)
All of the extendable transom mounts I have found are about 28-inches long and most boats have a 20-inch transom so that will get your transducer 8-inches below the boat, which buries the transducer in the water nicely but you arestill blocked on one side by the outboard. Some people find only scanning one side fustrating, in effect getting only 50-percent of the total capability of the unit. I purchased a store-bought [mount?], used the hardware from the top and bottom of the unit, used a length of 1x2-inch square aluminum tubing instead, and it is long enough to reach below the outboard. This works great and allows me to transplant the side scan system from boat to boat. |
highanddry |
posted 07-24-2006 02:22 AM ET (US)
I have had mone on the water only once due to an unusual number of comittments this summer--oh well. BUT, I have been getting returns from both sides in side scan mode. If the engine is tilted all the way in it shows shadowing but if I tilt it out it seems to do fine.Not out so far it is a problem or in danger of exposing the prop--not like that. Since the side scan mode is used only at slow speeds this does not seem to be a problem to me. In higher speed ops with the conventional sonar running it holds well into the 30s. I know I need to tweak on it some more and who knows with stuff like this that next time out the engine will blank me---lol. In that case I will just scan to the right. I must admit, I think I see the engine on th left side--so I know it is something to be delt with. I would imagine if you have a teeply Veed bottom and the transducer is mounted less than optimum you will probably loose that side in side scan. If you had a set back plate---I bet that might cure the problem. I believe the ss mode sends out a horozontally narrow beam but of course very wide verticaly. Perhaps--counter intuitively--if the transducer is mounted closer to the hull center line it has less chance to see the engine lower unit in ss mode. Much to be learned yet. |
bhampton |
posted 08-12-2006 03:38 PM ET (US)
I finally took my boat out on the Columbia River. The weather has been nice here in Washington and the boat ramps have been a mad house. I launch and recover my boat solo so I need a bit of room. I hate the rat race. I had a sheriff friend tell me about drifting down river and nearly getting stuffed into a hand rail of an old concrete stairs that ended up in the river. So I set out to find them [using SONAR and the Humminbird 987]. I set up a massive search area that ran along one shore of the river, and pounded the bottom. I was about 100 ft from shore and had the [side-scan SONAR] looking 150 feet both ways. I did not spot anything at first glance so I will have to look much closer at the scans to see if I can pick anything out. |
highanddry |
posted 08-15-2006 01:58 PM ET (US)
bhampton, are you getting returns on both sides? I am increasingly impressed with this unit. No, it will never replace a high dollar towed side scan but for a multi purpose navigation, sonar and side scan unit with map card capabilities and wide and clear screen, how can you beat it? |
marshall1776 |
posted 08-21-2006 06:25 PM ET (US)
Has anyone used a thru hull for the Humminbird 981 or 987?The thru hall is plastic... does that present a problem? I am intrested in what the salt water performance of the unit is in various modes of operation in salt water. What is the maximum depth the machine reads bottom and fish as a depht finder?...Thanks |
Sean7531 |
posted 12-06-2008 09:49 PM ET (US)
I'm [planning] to give [a HUMMINBIRD side-image SONAR] a try myself for the upcoming fishing season. I'll let you know what I think. |
Sean7531 |
posted 12-14-2011 09:41 AM ET (US)
[Three years later, and for the fourth time...] I'm actually [planning] to give [a HUMMINBIRD side-image SONAR] a try myself for the upcoming fishing season. I'll let you know what I think. |
posted 12-15-2011 08:56 AM ET (US)
Sean--Many thanks for reviving the six-year-old discussion to let us know for the fourth time that you are still in the planning stages of trying the device under discussion. |
