| Author | Topic: 13 40 hp Yamaha electrical system |
| PeteB88 |
We just got a sweet late 70s 13 with 1992 Yam 40. I am wondering if I should install an main power switch on this boat? It has two pull switches on the dash - nav lights and bilge, fish finder direct wired to terminal block, tilt on throttle. I guess the system is always hot. Should I install a shut off for the main power buss? Where is best to locate it? thanks |
See: Necessity of Battery Switch http://continuouswave.com/ubb/Forum6/HTML/000608.html for discussion about your inquiry regarding whether or not you should install a main battery switch. |
The best place to locate a battery main disconnect is as close to the battery as possible. This prevents long runs of unprotected high-current capacity cable. |
| PeteB88 |
Thanks Jim, I saw that thread. I just don't know what to get and where to mount - one of those red switches? I assume best mounting is behind the seat or frame but not sure. Thanks for your help and hard work on the site. Best |
