Topic: Electrical Problem Diagnosis
bkelly |
posted 10-03-2005 09:17 AM ET (US)
[The navigation lamps, the VHF Marine Band transceiver, and the horn on my 1987 MONTAUK] stopped working at the same time. I [checked the] fuses [and connections], [but cannot] find [the] problem. Any [suggestions] [on how to diagnose the problem or on what it might be?]
Tom W Clark
posted 10-03-2005 09:44 AM ET (US)
Check the circuit breaker or fuse in the stern. |
Chuck Tribolet
posted 10-03-2005 02:55 PM ET (US)
And the connection at the battery. It sounds like everything BUT the motor has quit, right? Chuck
bkelly
posted 10-03-2005 04:17 PM ET (US)
I still have bilge [and] guages, plus combo SONAR/GPS wired directly to battery. All these are working. Replaced one end of red power lead at battery. Cleaned all terminals. [Checked] the [connections] under the cover to fuse (port side). All looked good. |
st
posted 10-03-2005 05:07 PM ET (US)
To have three electrical/electronic devices not working at the same time tells me that something happened that's common to all those three. As Tom and Chuck replies above: check those obvious thing first; also fuses on top your panel (if you have't done so).Next; you're going to need to remove that control panel; turn it upside down if possible, and look again those mentioned above if any (hopefully group of 3) positive or ground/return wires came loose from it's terminal or corroded/frayed or open. If this looks ok; I would trace from either the vhs or horn or light; and trace them backward to the source (usually to the panel above). Basically: any of those needs a battery voltage wire AND a ground/return/neutral wire for them to work. Good luck! Sam. |
Chuck Tribolet
posted 10-03-2005 05:29 PM ET (US)
Guages run off the motor.Bilge pump may be wired direct to battery, or back to the master fuse or CB aft. If tracing the wiring shows nothing obvious, get a multimeter. Turn stuff on and work your way from the battery to console to the devices making sure you have "12V" at each step. When you stop having 12V, look for the problem in the part you added. For example (red means multimeter red lead, black means multimeter black lead, I if don't say where red or black goes, it means same place as previous step. Red to Battery +, Black to Battery -. Red to battery side of master fuse/CB. Red to console side of master fuse/CB. Red to whereever the power wire comes out in the console. You may need to extend the black wire to reach the battery on this one. Black to wherever the ground wire comes out in the console. and so forth. Note that there may be more places to check aft than I listed. CHuck |
bkelly
posted 10-03-2005 08:38 PM ET (US)
Thanks all I'll let you know how I do! |
posted 10-03-2005 11:32 PM ET (US)
Begin your checking at the device which lacks power. Trace the circuit back to the battery. It should be simple to discover where there is a discontinuity.For testing it is often more effective to use a test lamp which will draw some current. Simple voltage measurements with a high-impedance voltmeter may show voltages present which are actually being fed through high resistances and will not power the load. |
Chuck Tribolet
posted 10-03-2005 11:54 PM ET (US)
The high impedance of the multimeter is was I said "turn stuff on".One more thing to check is the bilge pump wiring. Since the bilge pump works, you know that power is good to the point where it ties into the main wiring. Chuck
17 bodega
posted 10-04-2005 05:38 PM ET (US)
you might also try stripping off some of the affected wire ends... if you see brown or black wires, (like I did!) then you see that something shorted. I have had some bizzare things happen like turning on the stern light and having to wait one minute and then it goes on. |
steelhead5
posted 10-04-2005 05:50 PM ET (US)
Check the connection(s) to the negative bus bar. Otherwise pull out your multimeter and start tracing for voltage. |
c_mccann
posted 10-04-2005 06:24 PM ET (US)
How old is the boat's wiring? Montauk's are known as pounders and a bit wet, and the wiring takes a beating in the years- loose connections, corrosion, etc. I'd start with the grounds and work to the buss pannel. |
posted 10-04-2005 09:07 PM ET (US)
[Edited and moved this article.] |
