| Author | Topic: Plug/recepticle for kicker battery hookup |
| tesija |
I've got a 9.9 hp. Yamaha outboard that I use as a kicker motor on a 21' Conquest. It came with a long battery cable, that is difficult to run to the battery enclosure-under the aft seat-it doesn't fit through the main cable port that serves the big motor. Has anyne installed a plug-recepticle system for easy plug-in conection, for a set up like this. I see various plug and recepticle options at West Marine but would like to hear any other ideas, solutionsor problems out there, before commiting to one. |
Are you asking about a weather proof battery connector? Do you plan on installing and removing the 9.9-HP auxiliary motor on a frequent basis? |
| tesija |
Yes to both. The connector has to stand up to salt water use. And yes, the kicker is removed a couple of times during the season. |
| andygere |
Consider a trolling motor connector plug, but be sure it is rated for at least as much amperage as your starter motor. I'm using them for my electric downriggers. http://photobucket.com/albums/v408/andygere/Whaler%20details/?action=view¤t=IMG_0697.jpg |
| whalercop |
I just put a charging kit on my kicker, and I ran the wires to the main motor and hooked them up onto it. I just ordered a Ancor dry seal connector to use so that I can disconnect the two. This thing is pricey, but it looks like it will work well. The connector is rated to 400V AC and to 15 amps, so I think that will handle the 4 amp charger on the kicker. I am planning on leaving them hooked up most of the time, but I like the idea of being able to disconnect the two easily if I need to take off the kicker. I will let you know how I like this connector when I get it. I might use the same connector for my stern light if it proves to be good enough. |
| tesija |
OK thanx-please let me know how it works. Any other ideas will be appreciated. |
| Chuck Tribolet |
whalercop: is the starter current going through that plug? If so, it will be over 15A, even for the little kicker.
| whalercop |
just charging, no starter |
