posted 11-05-2005 04:51 PM ET (US)
98 Dauntless 15 with Merc 60HP 2 stroke. Boat has been flawless from maintenance perspective to date - do all mechanicals myself but not an electrician.Last time out, the tach and voltage gauges were fluctuating.....tach at idles would not go below 1000 RPM. Trouble starting from anchor. When I got back to ramp - totally dead at restart - no ignition kickover, not even tilt/trim on button at the motor. I had to manually raise.
Once back home however, kicks over but the tach is still off.
I recently replaced battery and two years ago installed an Eagles finder/plotter at local dealer with no problems. Checked the fuse under the cowling - not blown. Unscewed gauge panel off center console, some verdigris, but no noticeable disconnects.
Six years is a long time...mostly indoors storage in NE, outdoors covered last year in FL. Is there only some many years before wiring replacement/instrument panel replacement is a given?
Any troubleshooting tips and techniques welcome!
