| Author | Topic: OMC Wiring Color Codes |
| davidestel |
Hi, Davide from Italy here. I'm trying to fit a 225 V6 Evinrude dated 1988 on my boat, after 3 weeks finally everything done but now I want to install all the indicators RPM/Temp/Volt/Trim and so on; How can I find the correct cable on the connector (there are a lot of cables: black, gray, purple, red/yellow, etc.)? At the moment I know only the gound (black) Could somebody help me? |
You may be able to deduce what wire is for what function from this color code chart (see link below). Or, obtain a factory service manual with the wiring diagrams. http://continuouswave.com/whaler/reference/wireColorCode.html#OMC |
| kingfish |
Goood morning Davide- Try this link to Boston Whaler and outboard motor wiring color codes that our moderator, Jim Hebert, has published in a different area of this website: http://continuouswave.com/whaler/reference/wireColorCode.html You will probably find your answers there, and you will have the opportunity to gain a better understanding of typical wiring color standards in general. Please come back here and tell us if that helped, or if you still have questions. Good luck- John |
| kingfish |
Sorry Jim- I was typing while you were posting and didn't know you had already answered Davide's question. John |
| Chuck Tribolet |
David may be along ways from a manual in Italy. From my 1997 service manual: Black: Ground throughout. Trim-tilt switch: Trim guage: Alarm beeper ("horn"): Ignition switch: 7 pin connector. SystemCheck TachL 8 pin connector. If you are using OMC gauges it should just plug in.
| davidestel |
Thanks to everybody, connections done. Now I suppouse that the gauges don't work properly. Trim: moves only for the last 1/4 of the scale from full down. Tach: when the engine run the indicator is at about 200/250 RPM. Is that normal? I don't thìnk this. |
| Tom W Clark |
Davide, You probably need to adjust the sender for the trim gauge. You also probably need to set the dial on the back of the tach to the correct pulse setting for that motor. |
| WhalerAce |
Chuck, On the power trim: UP is Blue (think the blue sky) |
| WhalerAce |
| WhalerAce |
Sorry, hit the enter button to create CR/LF, did not realize I was already in the name/pw field. And I think that purple just means SWITCHED +12vdc Ace out! |
| banff22 |
In my 1990 Evinrude/Johnson service manual for 120 thru 140, 185 thru 225, 300 Models, I have a number of fold out colour wiring diagrams. Are these not what davidestel is looking for? I scanned them all about a year into my computer for someone else. I could email them. They're fairly large files so I need to know your not on dial up. Peter |
| Chuck Tribolet |
You're right, purple is +12 with ignition on. Lights are blue. If you take those scans, and convert them to an indexed
| Joe Kriz |
I am certainly not going to argue with Chuck or his manual, but let's take a look at the tach he shows above... ------ From the above, where does the tach get its electrical power...??? As soon as you turn the key ON, the tach moves slightly to show there is power. The tach does not work until the engine is started and then the gray wire for signal kicks in. Without power from the purple wire, the tach would still do nothing. I have always known OMC to use Purple as "Power when Key Switch ON"... The BLUE wire has always been used for lights in every OMC instrument I have ever seen. |
| davidestel |
Let's go, the engine runs, the instruments light is ok; Instruments Lights: Black= common ground Trim gauge: Black and white= groung I mean that purple is ever +12V!! |
OMC often misidentifies the color of the VIOLET wire as PURPLE in their literature. In the jargon of electronics, wire insulation is colored violet, not purple. Purple is the color of certain candy mints and children's toys. The use of a BLUE wire for +12-volt power associated with lighting is very common. This is not particularly a feature of the ENGINE but more related to the BOAT. The engine seldom contains any illumination wiring. In the color code reference I mentioned above, you will find that the BLUE conductor is listed as being associated with various lighting or illumination functions. |
From what I can tell, just about all the advice given above in this discussion regarding interpretation of wire color codes is consistent with the listing I mentioned earlier. I again refer you to it as I think it is quite comprehensive: http://continuouswave.com/whaler/reference/wireColorCode.html |
