Topic: Why are trailers grounded using the frame?
Chuck Tribolet |
posted 11-14-2005 02:36 PM ET (US)
Other than simple cheapness, why are trailer lights grounded using the frame? It's been a reliability problem for me. Chuck
derf
posted 11-14-2005 02:40 PM ET (US)
Because cars and trucks are. You can easily run a ground wire and connect it to your vehicle frame. |
derf
Oh, BTW, trailer lights are a reliability issue for just about everyone.
Chuck Tribolet
posted 11-14-2005 03:39 PM ET (US)
You don't need to tell me that. I'm getting ready to replace all the wiring in my trailer. I plan to run a separate gound wire from each light to a common point (up inside the winch stand). Connections will be soldered and sealed with Ancor hot melt lined heat shrink.The ground connection has been one of the ongoing points of failure. Chuck
derf
posted 11-14-2005 06:38 PM ET (US)
That Ancor adhesive lined heat shrink is good stuff. I think most grounding problems with trailers relate to dirty hitches and balls. |
Jerry Townsend
posted 11-14-2005 08:56 PM ET (US)
Chuck - I don't see any problems with using the trailer frame as a grounding conductor.The biggest problem that many have is using the hitch/ball as the ground connector - which has proven to be very unreliable and flat guaranteed to cause problems. The best way, in my mind, is to use a solid ground connection to the vehicle frame, a connector providing a conductor pair for the ground, and a solid ground connection to the trailer frame. Protect the ground connections against corrosion on the vehicle and the trailer. Then, simply running a ground connection from each fixture to the frame will suffice - it is not necessary to run all grounds to a common point. ---- Jerry/Idaho |
where2
posted 11-14-2005 11:09 PM ET (US)
For all the boating that Chuck does, I am surprised he has not upgraded to runnnig wired grounds prior to this. The Trailer for my 15' Sport has been wired with additional ground wires ever since my father converted it to LED trailer lights as a Christmas present several years ago (it's nice when dad lives 4 houses down the street). I no longer wonder whether the lights will work. They simply work. Don't forget to add ground wires to the side marker lights. Regular trailer wire is CHEAP wire. Why it has not been upgraded to tinned wire is an unanswered question of cost versus added benefit. Do yourself a favor Chuck, locate a spool of 4 conductor tinned marine wire, then rewire your trailer. |
Chuck Tribolet
posted 11-14-2005 11:36 PM ET (US)
The ground problem is NOT the ball. The ground conductor comes off the four pin connector, and goes to a screw under the bow. All the lights have their ground conductor screwed to the frame. That screw has been problematic.What's really crazy is that the side marker lights on the fender have their ground go all the way back to the tail lights. It would actually be shorter to run the wire forward to the connector ground screw. I've been procrastinating the all wired ground for some time, waiting for some decent LED tail lights in the right form factor, which have finally appeared. They aren't the perfect size, but they'll bolt up. SS bolts built in. Tinned marine grade wire. White LEDs for the license plate. West Marine brand!! Now that they have appeared, it's time to get serious. Four conductor would be the wrong answer. There are seven lights. Only one gets left, only one gets right. I'm goint to run Ancor 16 ga. primary wire. All seven lights get ground (white) and tail (brown). Left and right tail lights get left and right (green and yellow, or is it yellow and green (don't worry, I'll check before I start pulling wire. About 250' of wire total for a 17' boat. Oh yes, a Jet Connex plug, soldered on. Chuck
Backlash
posted 11-15-2005 08:48 AM ET (US)
Chuck,I agree with Jerry that it's not necessary to run all grounds to a common point, just ground at each light. I also think using marine grade tinned wire on a trailer is overkill if you use the Anchor hot-melt heat shrink connectors which effectively seal the exposed bare wire ends. Equally important is to use split loom to protect the wiring where any chaffing may occur. I also used all SS fasteners when connecting lights, grounds, etc. I think you will love the LED lights. Steve |
posted 11-15-2005 09:17 AM ET (US)
Use a star washer on the ground screws. This will end your problem. |
Backlash
posted 11-15-2005 09:34 AM ET (US)
Chuck,About 10 years ago I "bit the bullet" and bought an Anchor ratcheting crimper - around $40 back then as I recall. The ratcheting mechanism will not release until a perfect crimp is formed. This crimper not only crimps the wire, but also the plastic collar on the connector. This tool produces professional factory looking crimps and is highly recommended. Steve |
Chuck Tribolet
posted 11-15-2005 10:52 AM ET (US)
There is a star washer. It's still been troublesome.And I do have the Ancor racheting crimper. Nice. About $100 now. There are (at least) two. One for single crimp (ie, the hot melt heat shrink, one for double crimp where the crimp has a metal collar that crimped around the insulation for strain relief. Mmmm, and there's probably a third for no insulation. I'm going to throw some overkill at this. The original wiring has wire cancer, so needs to be replaced. It will be a bunch of work (I figure a day) so I'm going to do it very right. Chuck
Bulldog
posted 11-15-2005 01:30 PM ET (US)
Chuck as you originally stated, 12 volt systems use the frame, because they can and it is cheaper! You will be better off using copper as an electrical conductor in a sealed wiring system instead of the steel frame of a trailer that is starting to rust the first day you use it!....Jack |
andygere
posted 11-16-2005 12:07 AM ET (US)
Chuck, if you want to get the boat off the trailer while you work on it, you are welcome to use my slip in Santa Cruz. My boat is in the driveway, and will be for a while. |
Chuck Tribolet
posted 11-16-2005 04:05 AM ET (US)
Thanks for the offer, Andy, but it can all be done with the boat on the trailer. Now, when the time comes to replace the bunk boards, I may take you up on that offer. Chuck
andygere
posted 11-16-2005 02:09 PM ET (US)
The offer stands Chuck. If you just want to use it to do some diving in the area, you're welcome to do that as well. Since my boat is in the water most of the time, I've gotten used to doing all my dreaded trailer maintenance with the boat completely out of the way. It's a small luxury... |
Chuck Tribolet
posted 11-16-2005 02:32 PM ET (US)
The consensus in the local dive community is that the diving is lots better on the south end of the bay. There are a few hunters with secret spots off Santa Cruz. But thanks. Chuck
