posted 11-19-2005 06:15 PM ET (US)
The VIOLET wire is a switched 12-volts which has voltage when the ignition key is in RUN or START position.I am not familiar with the 90-HP OMC engine, and I don't have the service manual, so I cannot be of too much help.
If the rectifier/regulator is working properly you should obtain a voltage reading on its output (red wire) of 14 to 15 volts output depending on engine speed.
The battery charging output and the tachometer pulse output are derived from the AC voltage present in the STATOR winding associated with the YELLOW and YELLOW/GRAY lead. Disconnect these leads and check for:
--any continuity to ground; there should be none.
--continuity between YELLOW and YELLOW/GRAY; should be continuity. I don't know the exact resistance; on the V6 stator it is 0.16-ohm. The V4 stator is 0.7-ohm on the 125-HP motor.
If there is a problem with the battery charger winding of the stator, the rest of the engine will still operate. It runs off different windings. However you charger output will be bad and often the tachometer will be affected. This may be your situation.
