  Are certain Lowrance cables interchangeable?
Author Topic:   Are certain Lowrance cables interchangeable?
Marsh posted 01-02-2006 12:48 PM ET (US)   Profile for Marsh   Send Email to Marsh
Anybody know whether the 'ducer cable connector from one late-model Lowrance sonar/fishfinder would likely fit another late model Lowrance sonar/FF?
I am thinking about upgrading from my Lowrance LMS-332C with a 5" screen to an LCX-110C having a 10" screen. (My eyes are not up to the challenge of the small screen). I REALLY do not want to have to ever re-snake a 'ducer cable throught the rigging tunnel. That was one chore I was glad to be done with!
If the cables are not interchangeable, maybe I'll just splice the ends.
I sent an email to Lowrance, but with the holidays, no word back.
Thanks,
Marsh
Bulldog posted 01-02-2006 03:05 PM ET (US)     Profile for Bulldog  Send Email to Bulldog
Marsh, I think using the old cable as a pull string would be easier then trying to splice the cables. I'm waiting to see a reply if they are compatible, as I'm thinking of upgrading my depth finder to a GPS/ depth. Here's hoping for our sake that they are compatible!.............Jack
Marsh posted 01-02-2006 03:21 PM ET (US)     Profile for Marsh  Send Email to Marsh
Bulldog:
It's not the pull string that's a problem...it's the nearly 1-inch diameter connector terminal on the end that's the problem. Took my tugging on and off, every evening for over a week, plus 1/2 bottle of dish soap, to get the 'ducer cable through my tunnel the first time. I'll be danged if I'll ever do that again!!! I'd rather take a beating... or just trade boats. Well...maybe that's a bit extreme, but you know what I mean.
Go Dogs, beat WVU!
Marsh
WT posted 01-02-2006 03:45 PM ET (US)     Profile for WT  Send Email to WT
I do not believe transducers are interchangeable.
I have a Lowrance LCX 19C. I have had the transducer replaced twice. The last time it was replaced was because Lowrance said I had an upgraded LCX 19C which did not work with the old LCX 19C transducer.
Warren
whalerwanter posted 01-02-2006 11:47 PM ET (US)     Profile for whalerwanter
Looks like some are same part number, as long as they are either both color, or both monochrome. Can't go from mono to color with same ducer. Got info from Lowrance site.
whalerwanter posted 01-02-2006 11:52 PM ET (US)     Profile for whalerwanter
Sorry, Marsh I didn't see the models you posted. Looks like you're good to go. Both 332C and 110C use pn 106-71, transom mounted skimmer-type.
deepwater posted 01-03-2006 06:40 PM ET (US)     Profile for deepwater  Send Email to deepwater
when i had to snake something through the tunnel i found it was easer if i went strait up through the drain plug no bending or pushing a wire under a control cable mine are all nice and loose laying ontop of eachother
