  LOWRANCE 332 Won't Shut Off
Author Topic:   LOWRANCE 332 Won't Shut Off
fleeted posted 03-04-2006 05:20 PM ET (US)   Profile for fleeted   Send Email to fleeted
I have a LOWRANCE 332 GPS SONAR unit that will not stay turned off. It cycles back on after about 10 seconds and the screen blinks in and out. Anyone seen this problem before?
Thanks,
Mike
jimh posted 03-06-2006 01:08 AM ET (US)     Profile for jimh  Send Email to jimh
To answer your survey question, I have not see this problem before. But it sounds like the device is defective. I would contact the manufacturer for advice on repair or replacement. LOWRANCE has a good reputation for being very reasonable on repairs and replacements under warranty.
Marsh posted 03-09-2006 02:29 PM ET (US)     Profile for Marsh  Send Email to Marsh
My Lowrance 332 appears to stay turned off, however it will drain my battery after only 2-3 weeks. Consequently, I disconnect the power cable after I turn it off. The real cure would be to re-route the power away from the direct-wired battery connection to an accessory switch on my console panel. Instructions that came with the unit said this might be necessary; I guess they were right.
Marsh
