  Yamaha 703 shifter 7 pin / adapter for 10 pin ?
Author Topic:   Yamaha 703 shifter 7 pin / adapter for 10 pin ?
JOHN W MAYO posted 04-10-2006 08:45 PM ET (US)   Profile for JOHN W MAYO   Send Email to JOHN W MAYO
I have a New Yamaha 703 shifter that is 7 pin. The unit is (old stock) with 7 pin, and was wondering if there is some plug and play 10 wire adapter that the new engines uses.
Also,
could this unit be rewired with a new 10 pin harness. I payed $100 or so for it on ebay and did not realize it was the wrong pin combination for the engine. It may be cheaper to buy a new shifter, wired with the correct wireing harness.
Thanks.
jimh posted 04-10-2006 11:36 PM ET (US)     Profile for jimh  Send Email to jimh
If all the wires are in the harness, you may be able to just change the connector to the new configuration. If you need to add wires to the harness, it might be better to look into a whole new gizmo.
Sometimes those e-Bay bargains have a catch.
JOHN W MAYO posted 04-11-2006 11:21 PM ET (US)     Profile for JOHN W MAYO  Send Email to JOHN W MAYO
Jim you are probably right. I doubt that the wire has the ten wire's. I need to check and see if there is some type of adapter plug if anyone knows about one.
I did learn to ask questions when buying parts on ebay.
tmackr posted 03-13-2007 11:28 PM ET (US)     Profile for tmackr  Send Email to tmackr
check out this yamaha part number. Maybe it will help.
703-8258A-00-00
JOHN W MAYO posted 03-18-2007 03:48 PM ET (US)     Profile for JOHN W MAYO  Send Email to JOHN W MAYO
Thanks tmackr for the tip on the part number, that looks like that would do it.
