Topic: Evinrude Charging Current
montauk steve |
posted 05-12-2006 02:36 PM ET (US)
What is the specified charging current output from a 1983 Evinrude 90-HP V4 two-stroke. I have seen some numbers varying from 6 to 12-amperes.When I was looking for what creates this output, the stator, I saw that they range from 6 to 25 amperes. Someone--Help me out. I have been looking for this specification for the longest time. I hope someone will have the specifications on this or the similar Johnson. Thanks steve
bsmotril
posted 05-12-2006 05:11 PM ET (US)
My book reads "Johnson and Evinrude motors through 1985 (that means earlier in this context) come with a 4,5, or 6 amp unregulated, or a 6, 10 15, or 35 amp regulated alternator charging system. The 35 amp is used with the 185-235 hp V6 motors. The 6, 10, 0r 15 amp systems are used with most V4-V6 models. Check your owners manual to determine the exact system rating on your motor." Not very helpful is it....?I'd get my exact model number off the tag, and go to www.ishopmarine.com. Choose Parts Lists, then browse, then choose Evinrude, then the yr outboard, then the HP of the outboard, and finally select your exact model number. The parts list for the electrical system should call out which alternator you have. If your motor has power tilt and trim, look up the description of the voltage regulator. That should include the amp rating for the charging system in that description. BillS |
montauk steve
posted 05-12-2006 07:12 PM ET (US)
Bill,helps, didnt know of that site. funny thing is that when i checked the model number to the evinrude/johnson list i didnt get either. the first letter is an L90tlcte. i have no clue of the first and last letter stand for. L=lame in my books lol |
Joe Kriz
posted 05-12-2006 11:02 PM ET (US)
Steve,The first letter is an "E", it is just worn or you need to get a magnifying glass and the right light... E = Evinrude 90 = HP T = Tilt & Trim L = Long Shaft C = 8 (first digit of the year model) T = 3 (second digit of the year model) E = (where it was manufactured?) So, you have an Evinrude 90 HP Tilt & Trim Long Shaft 1983 Model I am not sure where it was manufactured with the "E". The "B" is Belgium. |
seahorse
posted 05-14-2006 02:43 AM ET (US)
The last letter on the model number is not where it was manufactured but a production code. Sometimes there are mid-year changes on a motor and the code is used to tell the parts person that there may be different styles of parts for the same year. |
seahorse
posted 05-14-2006 02:49 AM ET (US)
The 1983 90hp had 2 types of charging systems, 6 amp and 10 amp.Power Trim factory equipped motors had a 10 amp stator and a separate regulator. The plain 90 had a 6 amp unregulated charging system. Some engines may have had the accessory tilt-trim kit added, but the motor still may have the 6 amp system. |
Joe Kriz
posted 05-14-2006 08:55 PM ET (US)
Thanks Seahorse...I wasn't sure that's why I put the question mark after the last digit... (where it was manufactured?) above... |
montauk steve
posted 05-15-2006 01:42 PM ET (US)
I re checked the number again and it is an E90.....it does have power tilt and trim. 10 amp it is. thanks again
