posted 06-04-2006 04:54 PM ET (US)
To review the situation:Question:
A remote fuel level indicator having an dial pointer meter-type indicator shows the fuel level in the tank as below the "E" calibration on the dial face. Is this an indicator of a malfunction?
Answer:
It depends upon the type of meter and its calibration. Normally these remote indicators measure the flow of electrical current through a sensor consisting of a variable resistor which is linked to a float arm in the tank. As the fuel level varies in the tank, a linkage mechanism operates the variable resistor. Battery current flows through the indicator meter and to the tank sensor resistor. There are several possible configurations.
One configuration is for the resistance in the tank sensor to be maximum when the tank is empty and minimum when the tank is full. The tank level meter is calibrated so that when the current flow is high the meter reads full scale (calibrated "F"), and, when the current flow is at its lowest, the meter reads near the resting position, corresponding to an empty tank )and calibrated "E").
The opposite condition is also possible, that is, the current flow is maximum when the tank is empty. This usually requires a special meter in which the resting position of the pointer (with no current at all) will be at the FULL end of the scale.
If the meter points below E, you could assume two possible situations:
--there is a problem with the circuit and there is no current flowing at all, and the meter was calibrated so that the E position was indicated when there was some current flow. With no current at all, the pointer goes below E. This is a sign of a problem in the circuit; or,
--the meter has sustained damage and its calibration has been moved so that the resting position or no current position is now off-calibration. This is a sign of damage to the meter itself.
So please inform us as to which type of indicator you have. Was the resting position of the indicator on the electrical meter normally at the E or F end of the scale when no current was applied (such as occurs when the battery is switched to OFF)? If you supply this information, we can proceed further with solution of the problem.
