ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Small Boat Electrical Downrigger outlets
Author | Topic: Downrigger outlets |
dcritch |
posted 06-05-2006 03:27 PM ET (US)
I'm thinking about buying an electric trolling motor for my 170. I would use it infrequently and was thinking about a stern mount which I could use from my boat step or attatch to a kicker bracket. I have outlets for Scotty electric downriggers mounted near the starboard inspection plate on the front face of the splashwell. Could a 54lb thrust trolling motor be set up to plug into one of my downriiger plugins. My downriggers are attatched to group 24 AGM dual purpose batteries which I purchased form Cabellas.
bsmotril |
posted 06-05-2006 07:14 PM ET (US)
You'll need to find out what the current rating specification is for the connector plugs and sockets. A trolling motor draws substantially more current than a downrigger and may well smoke and burn a connector not rated for that current level. BillS |
dcritch |
posted 06-05-2006 07:55 PM ET (US)
Thanks I called Scotty's who thought they would handle 18amps but suggested I contact the manufacterer Hellamarine.I've emailed technical support. |
Chuck Tribolet |
posted 06-05-2006 08:45 PM ET (US)
You should be able to get the info you need at http://www.hellamarine.com/?t=3&pcid=46 Chuck |
dcritch |
posted 06-06-2006 06:16 PM ET (US)
Hellamarine emailed me back: The socket # 87124, Model # 4123 is rated for 12V\ 16Amp. |
