ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Small Boat Electrical Trailer Wiring
Author | Topic: Trailer Wiring |
17 bodega |
posted 06-18-2006 02:56 AM ET (US)
Two tailights were badly corroded and needed replacement. I bought new tailights, but they don't have a ground wire that grounds to the chassis like the old lights. After connecting the wires according to the instructions, the right tail light does not light, but the right blinker and brake light work fine. All other lights on the trailer seem fine. The right bulbs are good. What would cause only the right tail lamp to fail to light? Thanks. |
jechura |
posted 06-18-2006 07:55 AM ET (US)
Somewhere on your trailer the one wire that powers the tail lamps is split to go to both sides. From that split to the bulb is the problem. Check at your tail light with a 12 volt tester to see if there is power in the wire where you made the connection. If there is power it's the new taillight. No power it's in the wiring. Jerry |
posted 06-18-2006 08:53 AM ET (US)
You did not mention the trailer wiring arrangement. We assume you have the common "flat four" arrangement. The standard wiring color code is as follows: FLAT FOUR TRAILER WIRING WHITE = battery negative or trailer chassis ground BROWN = tail lights and clearance lights YELLOW = left turn light and left brake light GREEN = right turn light and right brake light To help remember the color code: RIGHT and GREEN both have an "R". If the lamp for your right tail light does not illuminate: --it is not receiving current from the BROWN conductor, or --it is not returning current to the WHITE conductor, or --there is a problem with the light bulb or its socket in the lamp Here is a good article from the fine folks at TRAILER BOAT MAGAZINE on diagnoses and repair of trailer lighting problems: http://www.trailerboats.com/images/elements/1075501_trailerlights.pdf |
17 bodega |
posted 06-18-2006 12:37 PM ET (US)
Thanks for that info. It is the flat four wiring system in my EZ LOADER. Based on your responses, I should be able to correct the problem. I'm guessing the brown on the right tail lamp is the problem. |
17 bodega |
posted 06-18-2006 02:09 PM ET (US)
problem fixed. it was the brown wire and the culprit was a poor plug connector. My gripe about "WESBAR" and "EZ LOADER" is that I would expect better corrosion resistant connectors so the tailights can be easily removed and replaced. This is actually true, but the connectors behind those went bad and then there are no replacements available other than the ANCHOR connectors you crimp yourself. Thanks again Jim and Jerry for the tips on wire colors... I'm back on the road with all lights firing. Steve |
17 bodega |
posted 06-18-2006 02:13 PM ET (US)
Another thing I notice when stripping the wires on these connecions is the wire appears burnt and charred, with charcoal residue, as if the wire has suffered a short or overheating. I notice this often with boat wiring even in cases where there has been no short on the wires. What gives? Thanks for all the electrical help from the forum lately. As I resore my old boat to full operating condition, it seems my latest adventures have been in the 12 volt wiring systems of my car, boat and trailer. Happy Fathers Day to all the Dads out there! Steve |
Chuck Tribolet |
posted 06-18-2006 07:56 PM ET (US)
The copper wire looks burnt and charred? Or the "rubber" insulation looks burnt and charred? If it's just the wire, it's not burnt and charred, it just If it's the insulation, it probably got too hot due to a
17 bodega |
posted 06-19-2006 01:26 AM ET (US)
Chuck, It's the copper. It looks kind of blackish and it does appear more brittle than before. All the new wire I use is the corrosion resistant wire, which seems to hold up much better and has less tendency to turn color. |
