  Battery Starter
Author Topic:   Battery Starter
V210 posted 08-22-2006 06:40 AM ET (US)   Profile for V210   Send Email to V210
Does anyone have experience with a battery starter like the one at this link and are they recommended to carry on board and safe to use? The batteries on by 210 Ventura frequently don't maintain enough juice to start the motor after using an accessory like the radio or livewell pump even for a short time when the motor is not running and I feel the need to carry a battery starter or equivalent for safety reasons. Switching to "All" power has worked so far, but I need to be prepared for the day it doesn't.
http://www.apexbattery.com/marine-battery-starter-up-battery-chargers-cordless-jump-start-chargers.html
jimh posted 08-22-2006 08:25 AM ET (US)     Profile for jimh  Send Email to jimh
Separate the house battery and its loads from the engine starting battery and the engine. Continued use of some auxiliary battery to jump start the engine is a very bad plan.
HAPPYJIM posted 08-22-2006 09:34 AM ET (US)     Profile for HAPPYJIM  Send Email to HAPPYJIM
I carry one in my truck and it goes with me or in any other boat that I go out in. I consider it just as important as my handheld GPS and VHF radio. It will charge my VHF radio also. I got mine at Sam's Club for around $45. It has the jump start, tire inflator, 12 volt plug for cell phone charging/use and a LED light that puts out just enough light to rig lures while night fishing or inflating tires at night. I can't say enough good things about it. It has started my diesel truck on a warm morning. Not sure how it would do on a cold morning on that diesel. My brother just bought one for his truck after using mine to start his truck.
Sam's lists this new one but it is much larger than mine but has more features including an 120 volt inverter. The inverter would be great for home use when power is out or just to listen to a radio while working in the yard. Still much cheaper than calling SeaTow for a jump.
http://www.samsclub.com/shopping/navigate.do?catg=535&item=196004& prDeTab=2#A
Chuck Tribolet posted 08-22-2006 09:55 AM ET (US)     Profile for Chuck Tribolet  Send Email to Chuck Tribolet
A VHF radio that's not transmitting shouldn't run down the
battery for at least a couple of days. They pull about
a half amp or less, and 60AH is a typical battery size.
Do the math.
davej14 posted 08-22-2006 10:00 AM ET (US)     Profile for davej14  Send Email to davej14
You should have your batteries tested and probably replaced. They shouldn't run down with minimal usage. Carrying around a bootstrap solution is not the way to go.
HAPPYJIM posted 08-22-2006 10:24 AM ET (US)     Profile for HAPPYJIM  Send Email to HAPPYJIM
Livewell pumps will draw down a battery and some motors won't start without a fully charged battery. I would do a full charge/load test to be sure of battery condition. Charge both of the batteries with a good charger. Test the batteries with a load tester like this one. If you have more than 4 batteries in your household, this little device will pay for itself in short order.
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=90636
If the batteries are more than 3 years old and you venture off shore, new batteries should be at the top of your replacement list.
