ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Small Boat Electrical SONAR Transducer Mounting
Author | Topic: SONAR Transducer Mounting |
Capt Dutch |
posted 09-18-2006 01:43 PM ET (US)
I just purchased a 1984 13-foot Boston Whaler boat. I would like some information on mounting a depth gauge transducer. Will a transom mount work well at speed? Can a through hull be installed with the foam core construction? Will the transducer shoot through the foam core from inside the hull? ex: through a glob of silicone Any ideas to share? Capt' Dutch |
Plotman |
posted 09-18-2006 04:06 PM ET (US)
A transom mount will work on a whaler as well as it will work on any boat when properly installed - which is to say it should work just fine. Just don't put it directly in like with one of the strakes on the bottom. Whatever you do, don't go cutting holes in the bottom of a 13 to install a transducer. I doubt that installing a transducer on the inside of the hull would work well because all that foam is going to be an excellent insulator of sound. |
posted 09-18-2006 04:31 PM ET (US)
Read my article in the REFERENCE section on this topic: SONAR Transducers |
posted 09-18-2006 04:44 PM ET (US)
You can also read the original instructions provided by the Boston Whaler company regarding installation of a transducer on your boat. I have reproduced the original owner's manual for your convenience. Please see: Owner's Manual |
Capt Dutch |
posted 09-20-2006 08:18 PM ET (US)
Thanks all. I appreciate all the help. Capt Dutch |
posted 09-20-2006 08:32 PM ET (US)
You are welcome. Let us know how it works out for you with a follow up posting to this discussion. |
