  Splice Connectors in Trailer light kit
Author Topic:   Splice Connectors in Trailer light kit
richvi posted 11-20-2006 05:21 PM ET (US)   Profile for richvi   Send Email to richvi
I'm considering using the blue colored Splice Connector and then completley sealing with an Ancor Adhesive Lined Heat Shrink Tubing? Have any you tried this setup? I need to splice into the wire for the side marker lights. On this forum, members have advised: "Throw away the Splice Connectors that come with the kits".
rich
Chuck Tribolet posted 11-20-2006 05:49 PM ET (US)     Profile for Chuck Tribolet  Send Email to Chuck Tribolet
You mean the 3M connectors that have a slot that cuts through
the insulation that makes contact? Walk directly to the
garbage can. Those things are junk even if the they don't
get wet. And the hot melt heat shrink that's big enough to
cover them won't shrink enough to seal to the wire (not even
close).
What's wrong with those connectors:
- No significant strain relief.
- Major stress wire where the slot contacts (and cuts) the
wire.
- Sharp edge on the wire.
- Slot must be precisely size matched to wire size and strand
size
Here's how to splice it right:
http://continuouswave.com/ubb/Forum3/HTML/012169.html .
contender posted 11-21-2006 09:26 PM ET (US)     Profile for contender  Send Email to contender
Chuck is correct, those connectors are crap, I don't think they are even worth the material they are made from. Use a butt connector, crimp the connector, solder the connector, use heat shrink, then coat it with some type of silicon. Unless you physically pull it apart it will pretty much last forever...good luck
swist posted 11-24-2006 11:42 AM ET (US)     Profile for swist  Send Email to swist
Pet peeve of mine. You buy a big-bucks boat with high-quality wiring, but you can't spend any amount of money for decent trailer wiring unless you do ALL of it yourself to marine wiring standards. And even then you can't make your own lights from scratch and you'll have to buy some elcheapo so-called-waterproof lights made of thin plastic on a par with kid's toys.
The boating public is known to pay for quality goods.What is the big issue producing quality trailer electrical parts ? They would sell with no problem.
Chuck Tribolet posted 11-24-2006 03:12 PM ET (US)     Profile for Chuck Tribolet  Send Email to Chuck Tribolet
Hear, hear, what swist said, at least mostly. There are some
decent lights out there. The problem is figuring out which is
decent.
jimh posted 11-24-2006 04:10 PM ET (US)     Profile for jimh  Send Email to jimh
You can get very high quality trailers and with high quality lighting systems, but they come with a steep price. I tracked down the manufacturer of the trailers used on commercial Boston Whalers, looking for a quote on getting one for my boat. The price was quite a shock, over $6,000 as I recall. I bet the wiring was probably nicely done.
