  Transom Mount Transducer Location
Author Topic:   Transom Mount Transducer Location
blackdog54 posted 02-03-2007 10:13 PM ET (US)   Profile for blackdog54   Send Email to blackdog54
On a 1980's Montauk where should the transom mount transducer be located?
I recently bought a Garmin 498 and am in the process of the permanent installation. The instructions for the transom mount SONAR transducer are very vague. I know air bubbles from the propeller can affect accuracy. The transducer improperly placed can cause cavitation on the propeller. Thanks
jimh posted 02-03-2007 11:40 PM ET (US)     Profile for jimh  Send Email to jimh
The factory instructions from Boston Whaler for the MONTAUK are reproduced in an HTML version I created in the REFERENCE section. See
http://continuouswave.com/whaler/reference/manual9-17/electrical. html#fathometer
Also see
Depthsounder Transducer Mounting
http://continuouswave.com/maintenance-logs/transomTransducer/
blackdog54 posted 02-04-2007 11:18 AM ET (US)     Profile for blackdog54  Send Email to blackdog54
You know, I am very appreciative of these links.
[Complaint about the way the website operates removed. Please use the META-Discussion to raise complaints about the way the website is operated. --jimh.]
jschmidt63 posted 02-11-2007 12:25 AM ET (US)     Profile for jschmidt63  Send Email to jschmidt63
I should have checked the link before I install my transducer, I put it on the starboard side. Mines a humminbird, it said starboard but maybe it would have helped my trim a little on port. Mine also came with a template to help set the exact drop and angle off the bottom of boat.
John
jimh posted 02-14-2007 12:34 AM ET (US)     Profile for jimh  Send Email to jimh
I was at a boat show tonight. On the transom of the Edgewater 22-foot center console the manufacturer has provided a pre-installed tab of King StarBoard for mounting the SONAR transducer of your choice. The location of the transom mount transducer tab was rather interesting: it was on the PORT side and only about 14-inches off the keel centerline.
