  Best Deep-cycle Battery
Author Topic:   Best Deep-cycle Battery
macdougall70 posted 02-19-2007 10:23 AM ET (US)   Profile for macdougall70   Send Email to macdougall70
I am replacing two house batteries in my BW 27 and will be using a solar panel charging system. There are several brands of gel deep cycle batteries but which is the better and at the better price?
davej14 posted 02-19-2007 01:36 PM ET (US)     Profile for davej14  Send Email to davej14
First of all do NOT use a gel cell battery. The typical charging voltage of outboard motors it too high for a gel cell. Note that an absorbent glass mat (AGM) type battery is ok for use.
Check out Cabelas AGM batteries:
Link
bluewaterpirate posted 02-19-2007 02:25 PM ET (US)     Profile for bluewaterpirate  Send Email to bluewaterpirate
Ditto on the Cabelas AGM. I switched over from the Optima bluetop because the Cabelas are cheaper and more cost effective. I've got two Cat 24 on my Whaler.
macdougall70 posted 02-19-2007 06:06 PM ET (US)     Profile for macdougall70  Send Email to macdougall70
Thanks for the input, All the hype with the gels I figured they are the best. The motors I have are 1998 yamahas, I beleive the the motors that have higher charging power are the newer models.
Thanks,
Rob
jimh posted 02-19-2007 06:09 PM ET (US)     Profile for jimh  Send Email to jimh
Why the interest in a gel battery? You can find deep cycle batteries in flooded cell lead-acid and in valve regulated absorbent glass mat. I am curious why you think you need a gel battery?
The best deep-cycle battery is probably a Rolls. They have a seven year warranty and typically last for 10 years.
http://www.rollsbattery.com/
What is the warranty on the Cabela's AGM cell? Only ONE YEAR?
macdougall70 posted 02-19-2007 07:07 PM ET (US)     Profile for macdougall70  Send Email to macdougall70
I know my outboards will not support the charge I need for my four batteries (2 cranking and 2 house), my house batteries are responsible for a lot on the boat. flood lights, Hydroglow, radar, gps, livewell and assorted other lights. My cranking batteries are independent (thru an isolator) but I am installing a solar system to maintain a full charge on the house batteries. I assumed that the gel batteries were the best but a seven year warranty speaks for itself. It's funny that Rolls is located in Nova Scotia because that is where I bought my boat. I looks like a great battery. My batteries and charging system must be second to none. Thanks for the response.
Rob
