  Standard Horizon FF520 Transducer Choice
Author Topic:   Standard Horizon FF520 Transducer Choice
The Mexican posted 02-27-2007 07:26 AM ET (US)   Profile for The Mexican   Send Email to The Mexican
I recently purchased a Boston Whaler Newport 17, and I am intalling electronics on it. I purchased a [Standard-Horizon] CP-180 [Chart-Plotter and GPS]. I want to install the [external SONAR module] FF520, but I do not know which [transducer to use]. I am hesistant to put one in thru the hull. Will a [SONAR transducer] attached to the [transom] work as well?
Chuck Tribolet posted 02-27-2007 07:50 AM ET (US)     Profile for Chuck Tribolet  Send Email to Chuck Tribolet
I don't think a Newport has a place to mount a through hull
transducer. Only a few of the bigger whalers do.
jimh posted 02-27-2007 09:10 AM ET (US)     Profile for jimh  Send Email to jimh
Transom-mount SONAR transducers generally do not work as well as transducer's installed on the hull bottom. I believe that has more to do with the generally larger size of the transducers designed for mounting on the hull bottom, although the location is probably more advantageous.
In general, all small boats and particularly small Boston Whaler boats use transom mounted transducers. If you are interested in more information about transducer location choices with Boston Whaler boats there is a good article in the REFERENCE section on this topic.
SONAR Transducers
http://continuouswave.com/whaler/reference/sonarTransducer.html
The article concludes with links to more articles on this topic.
