ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Small Boat Electrical Battery Charge Low
Author | Topic: Battery Charge Low |
bdubbs |
posted 06-22-2007 02:58 PM ET (US)
[I] [please spell the personal pronoun "I" with a capital letter] need some help with the diagnosis of a failure somewhere in my electrical system. [H]ere [please begin each sentence with a capital letter] are the facts: boat: 1984 Montauk with 1984 70-HP [Y]amaha Could the battery be toast and not accepting a charge? During the 1.5 hours of running, [I] also ran my fishfinder and GPS. Why not fish while recharging? Maybe there wasn't enough [current] left to charge? Battery connections are bad? Battery cable shot? Alternator bad? The only reason this [problem] appeared is because the dash lights were left on for three days. [I] guess [I]'ll be spending a better part of the weekend trying to figure out my [problem], but any insight would be appreciated. |
Bella con23 |
posted 06-22-2007 04:00 PM ET (US)
I don't think that I would look much further then the battery itself. I believe the charging circuit require a small amount of current in to produce a larger current out. It's called and exciter field in the alternator. If the battery is older then a couple of years, and or has been discharged completely before this, then replace the battery and work from that point. I think you will find the new battery will solve your problems. After installing the battery, check the voltage with the engine off and again with the engine running. |
bdubbs |
posted 06-22-2007 04:23 PM ET (US)
[I] tend to agree with your reasoning that a new batt[ery] would solve this [problem], but now [I]'m curious about the other [problems]. [W]hat is the best [easiest] way to test an alternator? [W]hat should [I] expect from my alternator? [S]hould [I] be concerned about the battery cable in the bilge? |
Bella con23 |
posted 06-22-2007 06:30 PM ET (US)
There is a great article pertaining marine electrical systems in the reference section of this site - http://continuouswave.com/whaler/reference/electrical.html The quick and easy of it is, you should have somewhere around 12 to 12.5 volts engine off and 14 to 15.5 volts with the engine running at an elevated idle. There are many variables as JimH has pointed out such as outboard age, manufactures, RPM, etc. |
Chuck Tribolet |
posted 06-22-2007 09:33 PM ET (US)
Fishfinder and GPS use almost no current (tenth of an amp or so) But a lot of early outboard alternators are pretty wimpy. Was it just the dash lights? Usually they are wired with Chuck |
acseatsri |
posted 06-23-2007 11:48 AM ET (US)
One of the reasons I repowered was because my 150 Evinrude didn't put out enough juice to keep up with my electronics at normal cruise and idle (max of 9 amps). It was a great excuse for getting an engine that burns 1/2 the fuel I used to burn. :) |
posted 06-25-2007 10:35 PM ET (US)
In any battery operated system, when there is a problem, the first component to check is the battery. Connect the battery to an external charger. Charge it until its terminal voltage rises to over 12.9-volts. Load test the battery with an external load. Once you have verified that the battery is in proper condition, examine other components in the charging system. Of course proper connections are needed. Electrical current does not flow through oxidized and corroded connections. This is fundamental to electrical circuit operation. You can easily check the alternator output by measuring the voltage at the battery terminals. When the alternator is working properly it should raise the terminal voltage at the battery to about 14 to 14.5 volts when the engine is running at fast idle or higher speed. |
posted 06-26-2007 08:39 AM ET (US)
On most lead-acid flooded cell cranking batteries, if the battery is several years old and you completely discharge it, your chances of recharging the battery to full capacity and having a reliable battery are not very good. Go to some discount retailer and get a new 12-volt marine cranking battery for $35. It is a rather modest investment compared to the overall cost of operating a boat for the season. |
