  Garmin 3006 - Hooking up antenna to power
Author Topic:   Garmin 3006 - Hooking up antenna to power
littleblue posted 06-23-2007 11:12 AM ET (US)   Profile for littleblue   Send Email to littleblue
Trying to hook up a Garmin 3006. The wires from the antenna are super thin. I don't know if my wire cutter/crimping tool is bad but the smallest size is 18-22AWG and thats too big for the wires. Am I suppsed to directly hook up the power wires to the distribution panel or am I supposed to tap them into the garmin power wires which then directly connect to the distribution panel?
Chuck Tribolet posted 06-23-2007 10:50 PM ET (US)     Profile for Chuck Tribolet  Send Email to Chuck Tribolet
If the wires are too small for your crimper, solder, and
cover with Ancor glue-lined heat shrink. But are you using
crimps for 16-22 ga? (should be red in color) I'd solder
in any event where possible.
The Antenna doesn't care whether the power comes direct from
the battery, the distribution panel, or picks it up further
along, as long as power and ground gets there. I would pick
up power and ground close together. (In other words, don't
run the ground to battery and +12V to the distribution panel).
I'd also make sure the GPS and Antenna were on the same Acc
(or whatever) switch and fuse.
jimh posted 06-25-2007 09:34 AM ET (US)     Profile for jimh  Send Email to jimh
Does the owner's manual offer any advice on how to install the device?
