  GarminGPSMAP298 tp RayMarine54E
Author Topic:   GarminGPSMAP298 tp RayMarine54E
Ferryman posted 07-18-2007 04:32 PM ET (US)   Profile for Ferryman   Send Email to Ferryman
Hi
I want to connect my Garmin GPSMAP298 to my RayMarine 54E
VHF/DSC
In the GARMIN Book they show
NMEA Out (Blue)
NMEA In (Brown)
Ground Black
The RayMarine book shows
GPS
NMEA Out + to GPS + Yellow
NMEA Out - to GPS - Green
Has anyone done these connections.
Also the RayMarine VHF/DSC has a water resistant socket
Where can I get the corresponding Male plug to put on the Garmin Cables.
Thanks in advance
Ferryman posted 07-18-2007 04:35 PM ET (US)     Profile for Ferryman  Send Email to Ferryman
Sorry but
The RayMarine54E has the male plug, I need the corresponding female socket
Chuck Tribolet posted 07-18-2007 10:46 PM ET (US)     Profile for Chuck Tribolet  Send Email to Chuck Tribolet
Wire GPS NMEA OUT to VHF NMEA +. Whre VHF NMEA - to Ground.
Dunno about the connector. It should have come with the
Radio. Check with RayMarine.
Ferryman posted 07-19-2007 12:44 PM ET (US)     Profile for Ferryman  Send Email to Ferryman
Hi Chuck
I contacted my RayMarine dealer where I got the VHF/DSC and sure enough they had left the female socket and wiring tail out of the box.
Anyway now I have that it does not look so ominous.
I just have to decide if I connect the blue or brown NMEA cable. The book says the blue but on another forum a guy reckons he had to switch over to the brown to get it to work.
Anyway no big deal as I will set it all up and test before installing it
YTBhand posted 07-19-2007 03:12 PM ET (US)     Profile for YTBhand  Send Email to YTBhand
Howdy, I would assume you are trying to put GPS data into your Ray 54E radio. If this is true, then the hook-up would be as follows:
GARMIN GPS Connections Ray 54E Connections
NMEA OUT (blue wire) to GPS+ (yellow wire)
Ground (black wire) to GPS- (green wire)
I found this link to the owner's manual for the Ray 54E radio. View chapter 2.6 for picture of the hook-up.
http://www.raymarine.com/raymarine/SubmittedFiles/Handbooks/ Communications/81232_3www.pdf
Good luck
YTBhand posted 07-19-2007 03:44 PM ET (US)     Profile for YTBhand  Send Email to YTBhand
Hello again, This is another post to clarify the wire connections that I stated in my previous post.
GPSMAP 298 Connections______to_______Ray 54E Connections
NMEA Out (blue wire)________to_______GPS+ (yellow wire)
Ground (black wire)_________to_______GPS- (green wire)
I found the link to the Garmin unit's owner's manual and on page 92 is another picture of the correct hook-up.
http://www8.garmin.com/manuals/1067_OwnersManual.pdf
YTBhand
Ferryman posted 07-20-2007 02:52 PM ET (US)     Profile for Ferryman  Send Email to Ferryman
YTBhand
Thanks yes those were the connections. I just wish GARMIN had run the cables for about 12" before splitting the transducer cabling off. then I could have got away with just one hole and one stainless steel gland in the console for the cables
It would have made for a much neater look
