ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Small Boat Electrical Bonding System
Author | Topic: Bonding System |
sternorama |
posted 07-25-2007 06:12 PM ET (US)
The [bonding system of c.1980 Boston Whaler OUTRAGE 18 boats] was pointed out to me by an experienced CW member. I have not seen [bonding systemss] on other similar sized boats. I would appreciate if someone could explain the intent and importance of [the bonding system used on classic Boston Whaler boats]. Thank you. |
Bella con23 |
posted 07-25-2007 07:02 PM ET (US)
All depends on what your looking to accomplish. Try this article - http://members.cox.net/pc-usa/station/marine%20grounding.htm |
posted 07-25-2007 08:11 PM ET (US)
The bonding system on classic Boston Whaler boats like the OUTRAGE 18 connects all metal components of the fuel system with 8-AWG copper wire as well as connecting a sintered bronze anode on the transom. The purpose of this bonding system is to prevent accumulation of static voltages on any component of the fuel system. |
sternorama |
posted 07-26-2007 11:48 AM ET (US)
Thank you for the replies, Gentlemen. More questions: is this more of a fresh water vs. salt water concern? Do many other small boats operate without this feature? Thanks agian. |
sternorama |
posted 07-26-2007 11:49 AM ET (US)
Bella con23 |
posted 07-26-2007 01:51 PM ET (US)
Is your concern lightning protection? |
sternorama |
posted 07-30-2007 04:40 PM ET (US)
not particularly-just wondering if it is overkill (not that overkill is a bad thing). |
Bella con23 |
posted 07-30-2007 08:19 PM ET (US)
I wouldn't concern myself adding to the existing bonding system unless your looking to accomplish something. As Jimh pointed out, The existing bonding system is adequate for it's intended purpose. I would just go over the green wire and connectors to make sure there aren't any loose ends. |
sternorama |
posted 08-01-2007 11:42 AM ET (US)
Thanks Bella. I was actually wondering how much of a priority it should be to replace the bonding system in the case of assuming ownership of an Outrage that has (unfortunately) had the system removed by a previous owner. |
Bella con23 |
posted 08-01-2007 02:29 PM ET (US)
Again, I would spend the hour or so labor and reestablish the existing bonding if for no other reason then to have "ground" continuity when fueling up. Joe |
