posted 08-22-2007 08:47 PM ET (US)
If you are not going to use the System Monitor----
You should be able to run an Analog tach. You can't go wrong with the Mercury brand analog tach. Teleflex gages are also popular, there are several models and prices. I have used both. Check the model you select carefully, you need to be able to use the tachometer with the 12 pole alternator pickup.
This signal should be available at the helm on the gray wire- which is attached at the engine end to one of the pair of charging alternator connections, ahead of or at the rectifier
If you have a Mercury key-switch and harness, the gray wire, along with 12 volts controlled by the key switch and a ground are all connected to a plug. Obtain a Mercury tachometer harness kit-- regardless of the analog tach you use for easy hook-up. Three connectors to the tach, the other end plugs into the harness and you are all set.
