posted 08-14-2007 08:55 PM ET (US)
Sunlight viewable without a problem. Mine was one of the first batch made (ordered it through Consumers Marine after seeing the prototype at Miami International Boat Show, Feb. '06, they didn't start shipping to retailers until April/May '06, but Consumers was sitting on my order from February). My CP180i actually replaced a CP150 which still works and uses the same plug on the dash. I simply swapped the C-map chip from the old CP150 to the CP180i, plugged it into the same cable on the console and mounted it to my removable mounting plate.
Things I love about the CP180i, the internal antenna (my father had rigged the external antenna to mount to the rear of the CP150 so it was all one piece, but 30' of cable was hideous on the back of the unit). Color! Having become accustomed to the B/W CP150, the CP180i is so much more striking with colors on the display. Size: it's not so big that it takes up the entire dash, but it's large enough that you should be able to see it without pulling out the reading glasses.
The interface is actually quite good, but it will take some getting used to initially. Remembering where certain functions are in the flow chart style drop down fly out structure is a little challenging at first, but you get familiar with it after a short time. Their warranty is excellent, as is their staff.
As for the charts: I have only ever used the charts around Palm Beach, FL. If you didn't get the chart you want already, the higher end electronics retailers catering to yachts sometimes have "burners" that they can use to burn the chart you need onto a blank chip.
