  Mercury Start Switch Problem
Author Topic:   Mercury Start Switch Problem
windsurferwill posted 09-22-2007 08:48 PM ET (US)   Profile for windsurferwill   Send Email to windsurferwill
I have a 2003 Mercury 90-HP four-stroke. Normally the boat runs great but now I can't even turn the key to start the engine. It seems stuck and won't turn or even click one position.
So far I've checked to see if the shifter is in neutral and it is. I've already shifted it a couple of times and put it back in neutral but the key still won't turn.
Please help me.
Will
jimh posted 09-22-2007 09:23 PM ET (US)     Profile for jimh  Send Email to jimh
As far as I know, there is no mechanical interlock between the ignition key and the remote throttle and shift controls. There is an electrical interlock which suppresses cranking if the remote throttle and shift is not in neutral. Your problem sounds like a mechanical problem in the key ignition switch.
Chuck Tribolet posted 09-22-2007 11:24 PM ET (US)     Profile for Chuck Tribolet  Send Email to Chuck Tribolet
If you do some searching you will find that vintage Merc
switch has lots of problem. A buddy of mine had his stick
on and burn up the starter. Merc replaced switch and starter
on warrantee.
I'd start by squirting some lock lube in the lock.
