ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Small Boat Electrical Class D or No Class D VHF radios
Author | Topic: Class D or No Class D VHF radios |
WT |
posted 10-16-2007 07:38 PM ET (US)
I need another VHF because my ICOM 402 has been having problems receiving calls. My understanding is that class D radios monitor channel 70 FULL time. Some of the newer non-class D radios also monitor channel 70 but not full time, so in theory you could miss a DSC call. Both radios receive and send gps data and they both plot locations of your callers. My current radio is the "normal" size and is flush mounted. I've noticed that the Class D radios are larger than the "normal" size by about 1.25 inches in height. I'm not thrilled about having a larger hole cut out of my console for the Class D VHF. Class D radios: http://icomamerica.com/en/products/marine/mountedvhf/m504/default.aspx Non-class D but monitors channel 70 and does position request and reporting with an external GPS: http://icomamerica.com/en/products/marine/mountedvhf/m422/default.aspx
Oh yeah, there's about a $200 price difference between the class D and non-class D radios. Thanks, Warren |
Chuck Tribolet |
posted 10-16-2007 08:01 PM ET (US)
None of them display the position of your caller. Some will display the position of someone to whom you have sent a position request call, and to which their radio has replied with their position (not all radios will reply, and they can often be programmed to not reply without human intervention (I guess to keep fishing holes secret). I'm not sure sending and receiving position request (don't Every DSC radio I've ever seen could send and receive a digital The non-class D radios scan Ch 70. They aren't listening on Chuck |
Chuck Tribolet |
posted 10-16-2007 08:02 PM ET (US)
Also, try a different antenna (I've got one you can borrow if we can figure out how to get it up there to you), and check Icom's flat rate repair price if that doesn't help.
posted 10-16-2007 08:38 PM ET (US)
If there is a $200 difference between a Class-D radio and a non-Class-D radio, then the non-Class-D radio would be free and you'd get $75 cash for taking it! You can get a nice Class-D radio from Standard-Horizon for about $125, the GX1500S. It is a bit larger than some of the ICOM radios. |
WT |
posted 10-16-2007 09:08 PM ET (US)
Thanks Jim. On the Standard Horizon website the only class D radio is the GX5500S. The rest of the units do not indicate class D classification. Warren |
WT |
posted 10-16-2007 09:15 PM ET (US)
Oooops. I was wrong about the Standard Horizon GX5500S being the only class d radio. I didn't read the fine print of the other radios. :-O
BellBoyBob |
posted 10-17-2007 08:46 AM ET (US)
Thought I would chime in. The Icom 402 - a radio I have owned - is a class D DSC radio with NMEA in only. It cannot plot a caller's position on a GPS plotter. This is the reason I replaced it with the Standard Horizon GX3000S class D DSC radio. This one has a hailer and NMEA in and out. It plots on a GPS. The 402 WILL give a DSC caller's position (lat \ lon) on the radio's lcd and I had it in for service before selling it to remove the MMSI number and check on a faulty mic wire. The service was great and the warranty repair went smoothly and quickly. This new technology in marine radios neccessitates very careful researching before purchase. Jim's suggestion of the GX1500S would suit your needs perfectly. It has all of the features of the Icom 504, is built as well and is MUCH cheaper to buy online. My GX3000S was $169 online Best, Bob |
bluewaterpirate |
posted 10-17-2007 10:46 AM ET (US)
The ICOM 402 is not a Class D VHF DSC radio. It has DSC capability but only has one receiver. The 402/402a/402sa/502 can only receive NMEA data from a GPS and the 422/502A/504/506 can send and receive NMEA data. Tom |
BellBoyBob |
posted 10-17-2007 11:29 AM ET (US)
Oops, you are right. Does the fact that the 402 can only receive and not transmit polling info to the GPS define its status as not being Class D? |
bluewaterpirate |
posted 10-17-2007 12:18 PM ET (US)
A true class D radio has two receivers has nothing to do with NMEA input/output. There you go. Tom |
posted 10-18-2007 09:32 PM ET (US)
I do not believe that the ICOM M-402 is qualified as a Class-D DSC Marine Band Radio. ICOM was one of the last manufacturers to bring a Class-D radio to market. Only their most recent models have earned that rating. My article in the REFERENCE section gives the specifications for a VHF Marine Band radio to have a DSC Class-D rating. Please see: http://continuouswave.com/whaler/reference/dscClassD.html Note that the specification does not require any particular NMEA-0183a serial data interface provisions on the radio. The interfacing of the radio to other devices via NMEA-0183a serial data communication links is a feature added by the manufacturers to facilitate linking to a data source for position information such as a GPS receiver, and to a position plotting display such as a digital chart plotter for display of received information More information about DSC radio classifications can be found at |
where2 |
posted 10-20-2007 11:46 PM ET (US)
Get a Standard Horizon PS2000 bundled with a Ram+ microphone for $150. http://continuouswave.com/ubb/Forum6/HTML/001606.html Mount the radio Inside your console. Find something else to fill the gaping hole with the extra $50. Maybe a little black cutting board from Wal-mart or the dollar store cut down to fit over the hole. |
