  Bad Battery Wiring Stops Motor
Author Topic:   Bad Battery Wiring Stops Motor
pokeyjoe posted 01-07-2008 09:04 AM ET (US)   Profile for pokeyjoe   Send Email to pokeyjoe
I have a 115-HP OMC outboard motor. Not sure the year. The boat will run fine then all of a sudden just stop. It stops like the switch has been shut off and the power has been turned off. I have an idea it's due to some of the wiring to the battery because if I move the terminals the motor will start. Do these motors require power from the motor to run all the time?
Peter posted 01-07-2008 10:05 AM ET (US)     Profile for Peter  Send Email to Peter
Sound like you have a problem somewhere within your wiring harness.
There are two cables that lead into your motor. One is a battery cable that simply runs from the battery to the motor and connects to the starter solenoid. The other is the wiring harness which runs from the motor to the dashboard and has connections for the tachometer, key switch, the lanyard activated kill switch and trim/tilt switch. If your motor is shutting off like someone turned the key, I would check the connections at your key switch and the connections to the lanyard kill switch. Also, pull the big red connector at the motor apart and take a look at the internals of the connectors, both sides, to make sure the connections are clean and then reconnect.
Also, make sure that the battery cable is secured to the battery with regular hex nuts and locking washers, not wing nuts.
pokeyjoe posted 01-07-2008 05:57 PM ET (US)     Profile for pokeyjoe  Send Email to pokeyjoe
THANKS I'LL TRY THAT AND LET YOU KNOW
pokeyjoe posted 01-08-2008 07:39 AM ET (US)     Profile for pokeyjoe  Send Email to pokeyjoe
I went home and worked for a few hours on the wiring I can't get the motor to fire off at all now I pulled a plug and grounded it to the block and got no fire to it at all I put new terminal ends on the wires that looked bad and the thing still won't do anything IS IT TIME TO GIVE UP?
seahorse posted 01-08-2008 08:02 AM ET (US)     Profile for seahorse  Send Email to seahorse
pokeyjoe,
Does your 115 have the motor mounted trim switch on the port or starboard side of the motor?
Do you have the gauge or the tach that has 4 red lights that turn on then off when you first turn the key to ON?
This will help narrow down the type and year of your motor. Of course, telling us the model number would be the biggest help.
pokeyjoe posted 01-08-2008 08:29 AM ET (US)     Profile for pokeyjoe  Send Email to pokeyjoe
The trim/tilt switch is on the shifter. I've been informed by the guy that GAVE me the boat that the motor is an 1984. I hope this will help.
jimh posted 01-08-2008 09:22 AM ET (US)     Profile for jimh  Send Email to jimh
Your outboard motor is a spark-ignition motor, and it needs electrical energy to create the spark. The motor generates its own electrical energy for the spark. It should maintain spark even if the battery becomes disconnected.
quote:
I have an idea it's due to some of the wiring to the battery....
If the motor cranks over with the electric starter, that's a good indication that the wiring to the battery is making a good connection. If there is no spark during cranking, the problem is likely not related to the battery connection.
If you want to perform service on your motor, I recommend getting the service manual. In the service manual there will be a long diagnostic process which will help you isolate which component is causing a loss of spark.
Chuck Tribolet posted 01-08-2008 04:32 PM ET (US)     Profile for Chuck Tribolet  Send Email to Chuck Tribolet
If you get the model number (will begin with E (Evinrude) or
J (Johnson)), we can figure out the model year.
Get the factory service manual, not an aftermarket manual.
pokeyjoe posted 01-09-2008 07:45 AM ET (US)     Profile for pokeyjoe  Send Email to pokeyjoe
Thanks Chuck for the info. I still have not been able to get the motor to fire off. I know for a fact that it does run. I guess I'll be taking it to someone more boat motor friendly. Also, the mod. # is 893610
Chuck Tribolet posted 01-09-2008 08:57 AM ET (US)     Profile for Chuck Tribolet  Send Email to Chuck Tribolet
That sounds like the serial number, not the model number.
Model number will begin with E or J (assuming it's a 1980 or later motor),
and if it's really an '83 it will have a CT as probably the
the third or fourth characters.
contender posted 01-13-2008 09:31 PM ET (US)     Profile for contender  Send Email to contender
Not sure but wont the engine run with the battery disconnected if the alternator, can produce enought electric to fire the plugs?, I would check your alternator. Place a new battery on the engine with short cables, if the engine starts and runs disconnect the battery if it still runs it was your old battery or cables, if the engine quits I would check the alternator...good luck
