  Guest Battery Chargers
Author Topic:   Guest Battery Chargers
Ferdinando posted 02-16-2008 09:02 PM ET (US)   Profile for Ferdinando   Send Email to Ferdinando
Are Guest Battery Chargers good or bad? West Marine has 15 reviews on them with 14 being negative. Poor durability was the major complaint. Any feedback is welcome.
Fred
bluewaterpirate posted 02-16-2008 10:43 PM ET (US)     Profile for bluewaterpirate  Send Email to bluewaterpirate
Have a Guest 2620A installed on the Ventura .... terrific charger.
http://bluewaterpirate.phanfare.com/show/external/196006/617057/ 11878848/file.jpg
http://bluewaterpirate.phanfare.com/show/external/196006/617057/ 12787663/file.jpg
Tom
Moe posted 02-16-2008 11:15 PM ET (US)     Profile for Moe  Send Email to Moe
We have a Guest 2611A with the two 5 amp outputs paralleled for 10 amps (per the owners manual) to our single Group 24 battery that sits on the keel. No problems with it.
Moe
sitotis posted 02-16-2008 11:26 PM ET (US)     Profile for sitotis  Send Email to sitotis
What is the purpose/advantage of these chargers?
I have a portable charger I plug in with an extension cord and then clip it onto the battery terminals. It runs until the battery is charged. I usually do not need it over the summer, but I put it on a few times over the winter.
How are these type different?
Jefecinco posted 02-17-2008 10:09 AM ET (US)     Profile for Jefecinco  Send Email to Jefecinco
Tom,
I have two Optimas installed. What charger do you recommend for permanent installation to charge and maintain these batteries? TIA.
Jefecinco posted 02-17-2008 11:03 AM ET (US)     Profile for Jefecinco  Send Email to Jefecinco
Sitotis,
The purpose of having a permanently mounted battery charger is to be able to conveniently charge the boat's batteries without having to open the console, remove the battery box cover, connect the charger I've had to carry to the boat, place a rag on the deck on which to place the charger, then to reverse the process when the batteries are fully charged. After which, for those of us who are anally challenged, the charger terminal wires must be properly wound and secured and the charger placed in the proper place in the work/storage shed.
With a mounted charger I can simply connect a power cord to the receptacle installed on the console. If I choose I can leave the cord connected to "maintain" the charge on the batteries between trips. My choice would probably be to connect the charger a couple of days before planned outings. In that case I would only have to deal with the power cord and the boat cover.
Ferdinando posted 02-18-2008 07:20 AM ET (US)     Profile for Ferdinando  Send Email to Ferdinando
Jefecinco:
According to the owners manual the Guest charger is recommended for use on Lead Acid, Gel & AGM batteries. I also purchased an Optima battery but I charged it with a regular charger and screwed it up. Luckily Costco replaced the battery for me at no cost.
I purchased the Guest charger at the Mia Boat Show and already installed it. I even have the console plug which makes it a cinch to just plug in and forget about it.
What worried me was the reviews the Guest rcvd in the West Marine catalog. As I mentioned out of 15 comments 14 were negative. Anyway I purchased the extended warranty just in case and hope for the best, so far so good.
Fred
Jefecinco posted 02-18-2008 09:11 AM ET (US)     Profile for Jefecinco  Send Email to Jefecinco
Fred,
Good luck. If I hear from Tom (or not) I'll probably join you in the reliability experiment.
bluewaterpirate posted 02-18-2008 10:15 AM ET (US)     Profile for bluewaterpirate  Send Email to bluewaterpirate
I would go with the Guest 2620a. Gives you the best options.
As mentioned above you install a remote plug to make it easier to use. Here's my complete installation.
http://bluewaterpirate.phanfare.com/show/external/196006/617057/ 12787657/file.jpg
http://bluewaterpirate.phanfare.com/show/external/196006/617057/ 12787656/file.jpg
Tom
Jefecinco posted 02-18-2008 07:14 PM ET (US)     Profile for Jefecinco  Send Email to Jefecinco
Tom,
Thanks for the recommendation. Looks like a pretty straight forward installation.
