  Garmin 498 Installation
Author Topic:   Garmin 498 Installation
Andrewdavis34 posted 02-28-2008 12:11 AM ET (US)   Profile for Andrewdavis34   Send Email to Andrewdavis34
Hi All. My 498 Garmin chart plotter arrived today. I have been playing around with it a quite a bit this evening driving my wife crazy. Seems pretty similar in operation to my handheld.
How do I waterproof the hole that is going to be drilled in the top of my console for the power and transducer cable? Is it better to drill a hole for each cable or try to fit both cables in the same hole?
How do I set the baud rate to 4800 which is the setting that my standard horizon VHF requires?
Thanks,
Andrew
bluewaterpirate posted 02-28-2008 09:51 AM ET (US)     Profile for bluewaterpirate  Send Email to bluewaterpirate
Refer to pages 68 - 70 of your Owners Manual. From page 68 right side (middle) you'll select the NMEA In/NMEA Out Menu.
Tom
Casco Bay Outrage posted 02-28-2008 09:51 AM ET (US)     Profile for Casco Bay Outrage  Send Email to Casco Bay Outrage
Andrew -
For the wiring through the console, you have two options:
A) Drill a single hole for both wires, add a dab of caulk and then cover with a clamshell vent. Like this http://store.hamiltonmarine.com/browse.cfm/4,8179.htm
B) Do same as above with a grommet like http://store.hamiltonmarine.com/browse.cfm/4,2407.htm
CBO
