posted 04-05-2008 09:30 AM ET (US)
To many of their sounders and electronic chart display devices, LOWRANCE have added a new feature which permits the user to capture the screen display to a file which is stored on a removable Multi-Media Card-Secure Data (MMC/SD) memory card. The MMC/SD memory card can then be removed from the Lowrance device and mounted in the file system of a computer with an appropriate memory card reader hardware device. This new feature allows users to make recordings of SONAR echograms.The SONAR echogram files are stored using a JPEG image compression algorithm.
The screen capture feature is provided in the latest software update from Lowrance.
--begin excerpt from Lowrance--
What changes are made in this update?
--Added Lowrance HD radar support via serial communications
--Added Greek language
--Added Polish language
--Added ability to take a screenshot capture of the display on the unit and save to a card/hard drive – In Screen Snapshot mode, use the power key to capture the screenshot
--Added Navionics Platinum support including 3D view and panoramic photos
--Added support for the Lowrance Broadband Sounder-1
--Updated language translations
--Improved sonar digital depth tracking in weeds and over bluffs
--Improved Navionics support
--Changed Map/Sonar/Radar page to be resizeable
Includes all features from previous updates, including:
--Modified backlighting properties
--Improved ethernet stability
--Moved the Cancel Navigation menu item to the top of the system menu
--Many modifications to radar settings and features
--Modified SD/MMC data storage properties
--Added support for HDM NMEA0183 sentence
--Improved Navionics card support
--Added sonar sharing over ethernet
--Modified Auto-Sensitivity feature
--Modified memory card reading functionality
--Enhanced Navionics support
--Enhanced NauticPath electronic chart support
--Enhanced sonar noise detection
--end excerpt from Lowrance--
Previously Lowrance SONAR devices were able to make sophisticated recordings of long series of echograms, but unfortunately this feature required use of a binary executable which was only available for users of the Windows operating system. The new screen capture feature works with any operating system that can display a JPEG image and can mount the file system on the MMC/SD card.
The ability to make a screen capture of a SONAR echogram will be of interest to many users of Lowrance sounders. Lowrance joins other manufacturers of recreational boat echo sounders who also offer this feature.
More Support for Non-Windows Operating Systems
In addition, Lowrance appears to be recognizing the existence of non-Windows operating systems computers. They have provided the update software package as a JAVA program that performs the download and transfer of the update package. The JAVA applet is provided as part of a web page link on the Lowrance web site. I tested this feature with my MacOS 10.4 system. It appeared to work perfectly, and the update package was transferred to my computer. If during the JAVA execution you have a MMC/SD read-write memory card mounted in a memory card writer, the JAVA program will store the file onto the MMC/SD memory card.
To upgrade the Lowrance device, you install the MMC/SD memory card in the slot on the sounder or electronic chart display device. When the device is turned on the upgrade is automatically executed.
By using a JAVA approach, Lowrance has made the upgrade process available to users of LINUX or the MacOS, in addition to its usual Windows software users.
I have a Lowrance LMS-520C on my bench for some testing, and I hope to be able to install the upgrade and obtain some screen captures.
