  Bilge pump electrical problem (now solved)
Author Topic:   Bilge pump electrical problem (now solved)
gss036 posted 07-10-2008 01:45 PM ET (US)   Profile for gss036   Send Email to gss036
I had an interesting problem this week. Had a 50 ft motor yacht throw a large wake inside Obstruction Pass and got caught w/stern into the wake and took water into the motor well, which ended up in the bilge due to bad bad seal on a new access cover. ( I spent yesterday resealing it). The PROBLEM: when the float switch activated the bilge pump, it did not work, or at least not well, the switch and indicator ligh on the dask showed power as well as the two accesory switches next to it and the fuel guage pegged to "0-".
I recently has a new 225 Honda installed and figured they had messed up the wiring when redoing the guages,"WRONG" assumption. So, I took it back to the dealer and after some trouble shooting, the tech was a little stumped, then went in a made a phone call to someone, then came back and started cutting wires on the "RULE 1500 GPH Pump". That made the other lights go out and the fuel guage go back to normal operation. The guy whome he called told him the Rule pump has an internal short and was "BACK FEEDING" the electrical system. Not being an electrician, seemed plausable. The short and long of the fix was a new bilge pump which solved the problem.
I am posting this just for information in caase someone elses runs into this type of situation. It only cost me an hours labor to find and fix the problem, so I don't feel bad about that.
fishgutz posted 07-10-2008 05:59 PM ET (US)     Profile for fishgutz  Send Email to fishgutz
Good Info!
How will I ever retrieve that from the memory banks when I need it?
jimh posted 07-10-2008 06:02 PM ET (US)     Profile for jimh  Send Email to jimh
If the electric pump had a short, it should have blown the fuse in the branch circuit which supplies power to the pump. If the battery supply to the pump was not fused, that is an error in the installation.
gss036 posted 07-10-2008 06:11 PM ET (US)     Profile for gss036  Send Email to gss036
There is a breaker right under the switch but didn't pop it, must have just been a trickle on the back feed.
Chuck Tribolet posted 07-17-2008 08:52 PM ET (US)     Profile for Chuck Tribolet  Send Email to Chuck Tribolet
A trickle wouldn't have caused that.
This smells like the "trailer lights with a bad ground" bug
that turns up over and over.
gss036 posted 07-17-2008 10:47 PM ET (US)     Profile for gss036  Send Email to gss036
I've been out 3 times since the change and everything is still normal. Probably go again on Saturday. Maybe when I was down I will flood the deck and let water get do below deck by pulling the plug from the bait tank and see if it works w/o a problem.
