  Splitter for AM/FM and VHF Antenna
Author Topic:   Splitter for AM/FM and VHF Antenna
Graphiterod posted 08-12-2008 01:46 PM ET (US)   Profile for Graphiterod   Send Email to Graphiterod
I'm installing an am/fm/cd radio on my Outrage 18'. I have an 8' antenna for my vhf. Is a splitter worth the cost? Some reviews on westmarine.com indicate that they do not enhance fm reception at all.
If not a splitter, what is the consensus on amplified am/fm antennas? Are they worth the installation time and hook up to the electric panel?
Or, should I install the least expensive 16" flexible antenna and be done with it?
Thanks.
Graphiterod
jmorgan40 posted 08-12-2008 01:54 PM ET (US)     Profile for jmorgan40  Send Email to jmorgan40
Graphiterod,
On my old Montauk, I tried both an inexpensive AM/FM antenna and then I added a splitter to my VHF. The splitter definitly worked better until I got a ways offshore than I would have trouble with reception. On my Outrage, since I have a T-top I added a 4 ft Digital AM/FM antenna whic has no trouble picking up reception anywhere. I was 25 mles out in the gulf last week and the stereo worked great.
Hope this helps
Joe
jimh posted 08-12-2008 11:00 PM ET (US)     Profile for jimh  Send Email to jimh
There are several problems in using a VHF Marine Band antenna as a receive antenna for an AM Broadcast Band and FM Broadcast Band receiver. The principal problem is when transmitting on the VHF Marine Radio.
On receive, the vessel's antenna will not be resonant on the broadcast frequencies. This will reduce its efficiency. The situation looks like this:
VHF Marine = 156-MHz
FM Broadcast = 88 to 108 MHz
AM Broadcast = 0.5 to 1.5 MHz
A non-resonant antenna is better than no antenna, however in the case of AM Broadcast, the antenna may not have much efficiency at all due to the very short electrical length.
On transmit you have to keep the 25-watt transmission from blowing out the other two receivers. The best way to do that is to use an active device. Typically a relay is actuated when the transmitter power is sensed, and it disconnects the other devices. If the splitter is passive, it can use high-pass, low-pass, and band-pass filters to attempt to isolate the three device ports from each other.
Personally, I would rather not add something to my VHF Marine Band radio system that might have any negative effect. The radio is very important, particularly if you go offshore any distance. I'd do with a separate AM/FM antenna for the broadcast receivers.
bluewaterpirate posted 08-13-2008 08:26 AM ET (US)     Profile for bluewaterpirate  Send Email to bluewaterpirate
Installed a splitter on my Ventura in 2003 and been using it ever since. It has in no way affected either the receive or send side of my VHF radio. I run two ICOM 504 one uses the splitter configuration and the other is connected straight to the vhf antenna. The input/output is the same on both radios.
Over the LINE posted 08-13-2008 09:42 AM ET (US)     Profile for Over the LINE  Send Email to Over the LINE
I do not use my VHF for anything more than race management (close in work), but I have seen no ill effects from having a splitter. I do not listen to AM so I can not comment on reception quality.
I can tell you it is one less antenna on my 18' Outrage and helped to keep my electrical panel clean. My FM reception is just fine.
My splitter was not hard to install but I put it on my wiring panel before installing it. It is not an amplified splitter and did not require power.
http://smg.photobucket.com/albums/v442/OTL4343/18%20Outrage/ ?action=view¤t=OutrageElecPanel.jpg
davej14 posted 08-13-2008 09:14 PM ET (US)     Profile for davej14  Send Email to davej14
I am using a Shakespeare Model 4357 splitter with satisfactory results. Two years and counting.
swist posted 08-14-2008 10:46 AM ET (US)     Profile for swist  Send Email to swist
I agree with jimh. I would never add another source of failure to a critical safety component, just for the purpose of supporting an (optional) entertainment component.
