ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Small Boat Electrical Navman 4350 Problem
Author | Topic: Navman 4350 Problem |
dmeswi |
posted 11-11-2008 12:10 PM ET (US)
I have a Navman 4350 fishfinder which has output power up to 200W RMS. It works fine out in the Gulf and in the Pensacola Pass where the bottom is primarily sand, but when I get into the shallower bay areas it sometimes fails to indicate the dept of the water. If I lose the bottom reading for a short period and then get it back, I'll lose it again if I make a u-turn and go over the same area. This leads me to believe the unit can't read certain bottom types. Can someone tell me what's going on and if there is something that can be done to improve the performance of this unit. Would a different unit perform any better? Thanks, |
Casco Bay Outrage |
posted 11-11-2008 02:07 PM ET (US)
Dennis - Garmin has pretty good/excellent customer service. I suggest you contact them. |
SJUAE |
posted 11-14-2008 04:21 PM ET (US)
dmeswi I have exactly the same problem in shallow water mainly sand I thought it was a loose connection or failing sender I've tried auto gain and manual full gain it's just intermittant readings and worse at speed Sometimes the tracking also stops more often than not it just cant find the bottom so shows --.-- |
dmeswi |
posted 11-17-2008 07:00 PM ET (US)
First, I don't think Garmin has anything to do with Navman. It is also interesting someone else is having the same problem and I suspect many people are having this problem. Does anyone have a solution? Dennis |
kamie |
posted 11-17-2008 08:44 PM ET (US)
I would suggest you contact Northstar as they are servicing the Navman brand now. I believe their Northstar 435 is the product you own, or rather their rebranded version. http://www.northstarnav.com/en/Support/ The were very helpful when my Navman 3100 fuel flow went on the fritz. |
dmeswi |
posted 11-18-2008 04:36 PM ET (US)
Kamie, Thanks for the suggestion. I sent an email to Northstar customer service and hopefully I'll hear from them soom. Dennis |
SJUAE |
posted 11-18-2008 07:45 PM ET (US)
dmeswi Let us know what they advise I noticed this week if I swicth on and off a few times it seems to work at slow speeds Note my one was OEM/BW installed Rgds |
