posted 03-31-2009 07:56 AM ET (US)
The answer to this, I think: it depends.Operating two SONAR units simultaneously, one using 50-KHz and the other 200-KHz, may be possible, but the nature of the two SONAR devices would have a great deal of influence. The frequencies are separated by a 4:1 ratio, but the response of the SONAR receivers may be quite broad. The 200-KHz unit might be sensitive to echoes from the 50-KHz unit, and vice versa.
If using typical recreational SONAR units, there won't likely be any synchronization between the two devices. The transmit pulse of one unit may occur at a time when the other unit is listening for echoes. The signal level of the transmit pulse is likely to be very much stronger than the bottom echo or any target echoes, so it would likely interfere.
I can't offer any practical experience. I have seen some smaller fishing boats which have two sounders on them, so I imagine there must be some potential for running them simultaneously. Perhaps one of our readers who is an avid fisherman and has more than one sounder aboard can give us some real world experience.
