posted 05-01-2009 09:51 AM ET (US)
quote:
I heard the voltmeter can put a drain on the battery if it is on all the time, anyone have an opnion?
When the dial pointer of a meter is moved upscale, a small amount of work is done. The energy to do that work is provided by the electrical current that has flowed through the meter. When a battery is providing the electrical current to do that work, the electrical energy is being drained from the battery. This is not really a matter of dispute or opinion, nor should it come as a surprise.
When I mentioned above that a typical voltmeter would be built using a 1-milliampere meter, that may not be true of inexpensive voltmeters sold for recreational boats. In general, a meter becomes more expensive as it becomes more sensitive, so a boat voltmeter might really be based on a 10-milliampere meter which is probably less expensive than a 1-milliampere meter would be.
Also, if the meter is any kind of meter other than a D'Arsonval or Weston type meter, for example, if it were a digital meter, it will draw much more current than I suggest above. A digital meter needs power to illuminate its display and to run the electronics which are performing the measurement. Thus a digital meter could consume 100-milliamperes or more of current.
For a voltmeter that is being used to monitor a battery to determine its state of charge, the accuracy should be in the 3-percent range. The terminal voltage on a battery varies only a small amount as its state of charge changes. If the state of charge is to be determined with any accuracy, the meter used to make the measurement has to be properly calibrated and have a known accuracy.
In many cases the voltmeter installed on the helm panel of a small boat is not particularly accurate or well calibrated, but it does provide a rough indication of the battery condition. Such a meter is useful to see if the battery is
--being charged, if the voltage is greater than 13-volts, or
--being overcharged, if the voltage is greater than 14.5-volts, or
--not being charged, if the voltage is less than 13-volts when the engine is running.
Many voltmeters do not contain any kind of scale markings that provide an indication of less than 1-volt of resolution, or they just contain fields of green and red colors to indicate good and bad voltage levels. This does not mean they are of no value, but they are just not accurate enough to determine the battery state of charge with much resolution.
I prefer to carry with me a portable voltmeter with good calibration and accuracy. If I have worries about the battery condition I can use the portable meter to measure the battery directly on its terminals. I can also use the portable meter as diagnostic tool for investigating other electrical problems in the boat or in the engine.
